[Liblas-commits] hg: Tidy up testing emptiness and indentation.
liblas-commits at liblas.org liblas-commits at liblas.org
Tue Aug 17 17:24:48 EDT 2010
changeset 5de82dbc68a8 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=5de82dbc68a8
summary: Tidy up testing emptiness and indentation.
diffstat:
 src/lasreader.cpp |  43 +++++++++++++++++--------------------------
 1 files changed, 17 insertions(+), 26 deletions(-)
diffs (94 lines):
diff -r 35036dd06ad7 -r 5de82dbc68a8 src/lasreader.cpp
--- a/src/lasreader.cpp	Tue Aug 17 14:56:48 2010 -0500
+++ b/src/lasreader.cpp	Tue Aug 17 22:17:47 2010 +0100
@@ -176,9 +176,7 @@
     if (m_transforms != 0 ) {
         bHaveTransforms = true;
     try {
         // m_point = m_pimpl->ReadNextPoint(m_header).get();
         m_point = const_cast<Point*>(&(m_pimpl->ReadNextPoint(m_header)));
@@ -193,22 +191,20 @@
         if (bHaveTransforms) {
-        if (m_transforms->size() != 0) {
-            // Apply the transforms to each point
+            if (!m_transforms->empty()) {
+                // Apply the transforms to each point
-            for (ti = m_transforms->begin(); ti != m_transforms->end(); ++ti) {
-                liblas::TransformI* transform = *ti;
-                transform->transform(*m_point);
+                for (ti = m_transforms->begin(); ti != m_transforms->end(); ++ti) {
+                    liblas::TransformI* transform = *ti;
+                    transform->transform(*m_point);
         return true;
     } catch (std::out_of_range) {
         m_point = 0;
         return false;
 bool Reader::ReadPointAt(std::size_t n)
@@ -228,21 +224,18 @@
     try {
         m_point = const_cast<Point*>(&(m_pimpl->ReadPointAt(n, m_header)));
         return true;
         m_point = 0;
         return false;
 bool Reader::seek(std::size_t n)
@@ -349,10 +342,8 @@
     // list if *that* isn't there).
     TransformI* possible_reprojection_transform = 0;
-    if (m_transforms != 0) {
-        if (m_transforms->size() > 0) {
-            possible_reprojection_transform = m_transforms->at(0);
+   if (m_transforms != 0 && !m_transforms->empty()) {
+        possible_reprojection_transform = m_transforms->at(0);
     if (m_reprojection_transform.get() == possible_reprojection_transform && m_reprojection_transform.get() != 0) {
@@ -365,7 +356,7 @@
     m_reprojection_transform = TransformPtr(new ReprojectionTransform(m_in_srs, m_out_srs));
             // Insert the new reprojection transform to the beginning of the
             // vector there are already transforms there.
             m_transforms->insert(m_transforms->begin(), m_reprojection_transform.get());
More information about the Liblas-commits mailing list
