[Liblas-commits] hg: remove autoconf stuff
liblas-commits at liblas.org liblas-commits at liblas.org
Mon Aug 23 11:24:46 EDT 2010
changeset 7666f34417e4 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=7666f34417e4
summary: remove autoconf stuff
diffstat:
 m4/ax_boost_base.m4     |  221 --------------------------------
 m4/ax_lib_oracle_oci.m4 |  331 ------------------------------------------------
 m4/check_zlib.m4        |  129 ------------------
 3 files changed, 0 insertions(+), 681 deletions(-)
diffs (truncated from 694 to 300 lines):
diff -r fff045c17a3f -r 7666f34417e4 m4/ax_boost_base.m4
--- a/m4/ax_boost_base.m4	Mon Aug 23 10:04:38 2010 -0500
+++ /dev/null	Thu Jan 01 00:00:00 1970 +0000
@@ -1,221 +0,0 @@
-#          http://www.nongnu.org/autoconf-archive/ax_boost_base.html
-# SYNOPSIS
-#   AX_BOOST_BASE([MINIMUM-VERSION])
-# DESCRIPTION
-#   Test for the Boost C++ libraries of a particular version (or newer)
-#   If no path to the installed boost library is given the macro searchs
-#   under /usr, /usr/local, /opt and /opt/local and evaluates the
-#   $BOOST_ROOT environment variable. Further documentation is available at
-#   <http://randspringer.de/boost/index.html>.
-#   This macro calls:
-#     AC_SUBST(BOOST_CPPFLAGS) / AC_SUBST(BOOST_LDFLAGS)
-#   And sets:
-#     HAVE_BOOST_API
-# LICENSE
-#   Copyright (c) 2008 Thomas Porschberg <thomas at randspringer.de>
-#   Copying and distribution of this file, with or without modification, are
-#   permitted in any medium without royalty provided the copyright notice
-#   and this notice are preserved.
-AC_DEFUN([AX_BOOST_BASE],
-AC_ARG_WITH([boost],
-	AS_HELP_STRING([--with-boost@<:@=DIR@:>@], [use boost (default is no) - it is possible to specify the root directory for boost (optional)]),
-    if test "$withval" = "no"; then
-		want_boost="no"
-    elif test "$withval" = "yes"; then
-        want_boost="yes"
-        ac_boost_path=""
-    else
-	    want_boost="yes"
-	    ac_boost_path="$withval"
-	fi
-    [want_boost="no"])
-AC_ARG_WITH([boost-libdir],
-        AS_HELP_STRING([--with-boost-libdir=LIB_DIR],
-        [Force given directory for boost libraries. Note that this will overwrite library path detection, so use this parameter only if default library detection fails and you know exactly where your boost libraries are located.]),
-        if test -d $withval
-        then
-                ac_boost_lib_path="$withval"
-        else
-                AC_MSG_ERROR(--with-boost-libdir expected directory name)
-        fi
-        [ac_boost_lib_path=""]
-if test "x$want_boost" = "xyes"; then
-	boost_lib_version_req=ifelse([$1], ,1.20.0,$1)
-	boost_lib_version_req_shorten=`expr $boost_lib_version_req : '\([[0-9]]*\.[[0-9]]*\)'`
-	boost_lib_version_req_major=`expr $boost_lib_version_req : '\([[0-9]]*\)'`
-	boost_lib_version_req_minor=`expr $boost_lib_version_req : '[[0-9]]*\.\([[0-9]]*\)'`
-	boost_lib_version_req_sub_minor=`expr $boost_lib_version_req : '[[0-9]]*\.[[0-9]]*\.\([[0-9]]*\)'`
-	if test "x$boost_lib_version_req_sub_minor" = "x" ; then
-		boost_lib_version_req_sub_minor="0"
-    	fi
-	WANT_BOOST_VERSION=`expr $boost_lib_version_req_major \* 100000 \+  $boost_lib_version_req_minor \* 100 \+ $boost_lib_version_req_sub_minor`
-	AC_MSG_CHECKING(for boostlib >= $boost_lib_version_req)
-	succeeded=no
-	dnl first we check the system location for boost libraries
-	dnl this location ist chosen if boost libraries are installed with the --layout=system option
-	dnl or if you install boost with RPM
-	if test "$ac_boost_path" != ""; then
-		BOOST_LDFLAGS="-L$ac_boost_path/lib"
-		BOOST_CPPFLAGS="-I$ac_boost_path/include"
-	else
-		for ac_boost_path_tmp in /usr /usr/local /opt /opt/local ; do
-			if test -d "$ac_boost_path_tmp/include/boost" && test -r "$ac_boost_path_tmp/include/boost"; then
-				BOOST_LDFLAGS="-L$ac_boost_path_tmp/lib"
-				BOOST_CPPFLAGS="-I$ac_boost_path_tmp/include"
-				break;
-			fi
-		done
-	fi
-    dnl overwrite ld flags if we have required special directory with
-    dnl --with-boost-libdir parameter
-    if test "$ac_boost_lib_path" != ""; then
-       BOOST_LDFLAGS="-L$ac_boost_lib_path"
-    fi
-	CPPFLAGS_SAVED="$CPPFLAGS"
-	CPPFLAGS="$CPPFLAGS $BOOST_CPPFLAGS"
-	export CPPFLAGS
-	LDFLAGS_SAVED="$LDFLAGS"
-	LDFLAGS="$LDFLAGS $BOOST_LDFLAGS"
-	export LDFLAGS
-	AC_LANG_PUSH(C++)
-     	AC_COMPILE_IFELSE([AC_LANG_PROGRAM([[
-	@%:@include <boost/version.hpp>
-	#if BOOST_VERSION >= $WANT_BOOST_VERSION
-	// Everything is okay
-	#else
-	#  error Boost version is too old
-	#endif
-        AC_MSG_RESULT(yes)
-	succeeded=yes
-	found_system=yes
-	AC_LANG_POP([C++])
-	dnl if we found no boost with system layout we search for boost libraries
-	dnl built and installed without the --layout=system option or for a staged(not installed) version
-	if test "x$succeeded" != "xyes"; then
-		_version=0
-			if test -d "$ac_boost_path" && test -r "$ac_boost_path"; then
-				for i in `ls -d $ac_boost_path/include/boost-* 2>/dev/null`; do
-					_version_tmp=`echo $i | sed "s#$ac_boost_path##" | sed 's/\/include\/boost-//' | sed 's/_/./'`
-					V_CHECK=`expr $_version_tmp \> $_version`
-					if test "$V_CHECK" = "1" ; then
-						_version=$_version_tmp
-					fi
-					VERSION_UNDERSCORE=`echo $_version | sed 's/\./_/'`
-					BOOST_CPPFLAGS="-I$ac_boost_path/include/boost-$VERSION_UNDERSCORE"
-				done
-			fi
-		else
-			for ac_boost_path in /usr /usr/local /opt /opt/local ; do
-	               					best_path=$ac_boost_path
-						fi
-					done
-				fi
-			done
-			BOOST_CPPFLAGS="-I$best_path/include/boost-$VERSION_UNDERSCORE"
-            if test "$ac_boost_lib_path" = ""
-            then
-               BOOST_LDFLAGS="-L$best_path/lib"
-            fi
-	    		if test "x$BOOST_ROOT" != "x"; then
-				if test -d "$BOOST_ROOT" && test -r "$BOOST_ROOT" && test -d "$BOOST_ROOT/stage/lib" && test -r "$BOOST_ROOT/stage/lib"; then
-					version_dir=`expr //$BOOST_ROOT : '.*/\(.*\)'`
-					stage_version=`echo $version_dir | sed 's/boost_//' | sed 's/_/./g'`
-			        	stage_version_shorten=`expr $stage_version : '\([[0-9]]*\.[[0-9]]*\)'`
-					V_CHECK=`expr $stage_version_shorten \>\= $_version`
-                    if test "$V_CHECK" = "1" -a "$ac_boost_lib_path" = "" ; then
-						AC_MSG_NOTICE(We will use a staged boost library from $BOOST_ROOT)
-						BOOST_CPPFLAGS="-I$BOOST_ROOT"
-						BOOST_LDFLAGS="-L$BOOST_ROOT/stage/lib"
-					fi
-				fi
-	    		fi
-		fi
-		export CPPFLAGS
-		export LDFLAGS
-		AC_LANG_PUSH(C++)
-		#else
-		#endif
-		succeeded=yes
-		found_system=yes
-	fi
-	if test "$succeeded" != "yes" ; then
-		if test "$_version" = "0" ; then
-			AC_MSG_ERROR([[We could not detect the boost libraries (version $boost_lib_version_req_shorten or higher). If you have a staged boost library (still not installed) please specify \$BOOST_ROOT in your environment and do not give a PATH to --with-boost option.  If you are sure you have boost installed, then check your version number looking in <boost/version.hpp>. See http://randspringer.de/boost for more documentation.]])
-		else
-			AC_MSG_NOTICE([Your boost libraries seems to old (version $_version).])
-		fi
-	else
-		AC_SUBST(BOOST_CPPFLAGS)
-		AC_SUBST(BOOST_LDFLAGS)
-		HAVE_BOOST="yes"
-		AC_SUBST(HAVE_BOOST)
-		AC_DEFINE(HAVE_BOOST_API,,[define if the Boost library is available])
-	fi
-        CPPFLAGS="$CPPFLAGS_SAVED"
-       	LDFLAGS="$LDFLAGS_SAVED"
-fi
diff -r fff045c17a3f -r 7666f34417e4 m4/ax_lib_oracle_oci.m4
--- a/m4/ax_lib_oracle_oci.m4	Mon Aug 23 10:04:38 2010 -0500
@@ -1,332 +0,0 @@
-dnl @synopsis AX_LIB_ORACLE_OCI([MINIMUM-VERSION])
-dnl
-dnl @summary Find Oracle OCI API.
-dnl
-dnl This macro provides tests of availability of Oracle OCI API of
-dnl particular version or newer. This macros checks for Oracle OCI
-dnl headers and libraries and defines compilation flags.
-dnl
-dnl Macro supports following options and their values:
-dnl
-dnl 1) Single-option usage:
-dnl
-dnl     --with-oci         -- path to ORACLE_HOME directory
-dnl
-dnl 2) Two-options usage (both options are required):
-dnl
-dnl     --with-oci-include -- path to directory with OCI headers
-dnl     --with-oci-lib     -- path to directory with OCI libraries
-dnl
-dnl NOTE: These options described above do not take yes|no values. If
-dnl 'yes' value is passed, then WARNING message will be displayed, 'no'
-dnl value, as well as the --without-oci-* variations will cause the
-dnl macro to not check enything.
-dnl
-dnl This macro calls:
-dnl
-dnl   AC_SUBST(ORACLE_OCI_CFLAGS)
-dnl   AC_SUBST(ORACLE_OCI_LDFLAGS)
-dnl   AC_SUBST(ORACLE_OCI_VERSION)
-dnl
-dnl And sets:
-dnl
-dnl   HAVE_ORACLE_OCI
-dnl
-dnl @category InstalledPackages
-dnl @category Cxx
-dnl @author Mateusz Loskot <mateusz at loskot.net>
-dnl @version 2007-11-30
-dnl @license AllPermissive
-AC_DEFUN([AX_LIB_ORACLE_OCI],
-    AC_ARG_WITH([oci],
-        AC_HELP_STRING([--with-oci=@<:@ARG@:>@],
-            [use Oracle OCI API from given Oracle home (ARG=path); use existing ORACLE_HOME (ARG=yes); disable Oracle OCI support (ARG=no)]
-        if test "$withval" = "yes"; then
-            if test -n "$ORACLE_HOME"; then
-                oracle_home_dir="$ORACLE_HOME"
-            else
-                oracle_home_dir=""
-            fi
-        elif test -d "$withval"; then
-            oracle_home_dir="$withval"
-        else
-        fi
-        else
-        fi
-    AC_ARG_WITH([oci-include],
-        AC_HELP_STRING([--with-oci-include=@<:@DIR@:>@],
-            [use Oracle OCI API headers from given path]
More information about the Liblas-commits mailing list
