[Liblas-commits] hg: Replaced uint8_t with uint32_t for input of Classification i...
liblas-commits at liblas.org liblas-commits at liblas.org
Wed Aug 25 19:53:06 EDT 2010
changeset e830e28ab4d6 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=e830e28ab4d6
summary: Replaced uint8_t with uint32_t for input of Classification index. Larger type allows more robust validation and helps to avoid potential integer overflow. uint8_t left as Classification::GetClass return type according to the spec.
diffstat:
 include/liblas/lasclassification.hpp |  19 +++++--------------
 src/lasclassification.cpp            |  24 +++++++++++++++++++-----
 2 files changed, 24 insertions(+), 19 deletions(-)
diffs (117 lines):
diff -r 30eae0160989 -r e830e28ab4d6 include/liblas/lasclassification.hpp
--- a/include/liblas/lasclassification.hpp	Wed Aug 25 23:31:37 2010 +0100
+++ b/include/liblas/lasclassification.hpp	Thu Aug 26 00:52:52 2010 +0100
@@ -70,7 +70,7 @@
     /// @note Currently, libLAS does not support classification based on table
     /// stored in variable-length record. Only Standard ASPRS classification
     /// table is supported.
-    static std::size_t const class_table_size;
+    static boost::uint32_t const class_table_size;
     /// Values of indexes in the set of bit flags.
     enum BitPosition
@@ -106,7 +106,7 @@
     /// @param k [in] - If set, this point is considered to be a model keypoint and
     /// thus generally should not be withheld in a thinning algorithm.
     /// @param w [in] - If set, this point should not be included in processing.
-    Classification(boost::uint8_t cls, bool s, bool k, bool w)
+    Classification(boost::uint32_t cls, bool s, bool k, bool w)
         SetClass(cls);
         SetSynthetic(s);
@@ -123,7 +123,7 @@
     /// Assignment operator.
     Classification& operator=(Classification const& rhs)
-        if (&rhs != this )
+        if (&rhs != this)
             m_flags = rhs.m_flags;
@@ -155,7 +155,7 @@
     /// @exception Theoretically, may throw std::out_of_range in case index
     /// value is not in range between 0 and class_table_size - 1.
-    void SetClass(boost::uint8_t index);
+    void SetClass(boost::uint32_t index);
     /// Sets if this point was created by a technique other than LIDAR
     /// collection such as digitized from a photogrammetric stereo model.
@@ -207,16 +207,7 @@
     bitset_type m_flags;
-    void check_class_index(std::size_t index) const
-        if (index > (class_table_size - 1))
-            std::ostringstream msg;
-            msg << "given index is " << index
-                << ", but must fit between 0 and " << (class_table_size - 1);
-            throw std::out_of_range(msg.str());
+    void check_class_index(boost::uint32_t index) const;
 /// Equal-to operator implemented in terms of Classification::equal.
diff -r 30eae0160989 -r e830e28ab4d6 src/lasclassification.cpp
--- a/src/lasclassification.cpp	Wed Aug 25 23:31:37 2010 +0100
+++ b/src/lasclassification.cpp	Thu Aug 26 00:52:52 2010 +0100
@@ -45,6 +45,7 @@
 #include <boost/cstdint.hpp>
 // std
 #include <cstddef>
+#include <limits>
 #include <string>
 using namespace boost;
@@ -91,11 +92,11 @@
 namespace liblas {
-std::size_t const Classification::class_table_size = detail::static_array_size(g_class_names);
+uint32_t const Classification::class_table_size = detail::static_array_size(g_class_names);
 std::string Classification::GetClassName() const
-    std::size_t const index = GetClass();
+    uint32_t const index = GetClass();
     check_class_index(index);
     return g_class_names[index];
@@ -121,13 +122,14 @@
 #endif
     bits &= mask;
-    uint8_t const index = static_cast<uint8_t>(bits.to_ulong());
+    uint32_t const index = static_cast<uint32_t>(bits.to_ulong());
     assert(index < class_table_size);
+    assert(index <= std::numeric_limits<uint8_t>::max());
-    return index;
+    return static_cast<uint8_t>(index);
-void Classification::SetClass(uint8_t index)
+void Classification::SetClass(uint32_t index)
@@ -139,4 +141,16 @@
     m_flags &= ~mask;
     m_flags |= mask & binval;
+void Classification::check_class_index(boost::uint32_t index) const
+    if (index > class_table_size - 1 || !(index <= std::numeric_limits<uint8_t>::max()))
+        std::ostringstream msg;
+        msg << "given index is " << index
+            << ", but must fit between 0 and " << (class_table_size - 1);
+        throw std::out_of_range(msg.str());
 } // namespace liblas
More information about the Liblas-commits mailing list
