[Liblas-commits] hg: notes about OCI on windows and back down the minimum boost v...
liblas-commits at liblas.org liblas-commits at liblas.org
Thu Aug 26 21:33:38 EDT 2010
changeset b7bbdf3c4604 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=b7bbdf3c4604
summary: notes about OCI on windows and back down the minimum boost version to 1.38, which is what cmake is enforcing currently
diffstat:
 doc/compilation.txt |  9 +++++++--
 1 files changed, 7 insertions(+), 2 deletions(-)
diffs (31 lines):
diff -r 13fbb7708583 -r b7bbdf3c4604 doc/compilation.txt
--- a/doc/compilation.txt	Thu Aug 26 20:32:48 2010 -0500
+++ b/doc/compilation.txt	Thu Aug 26 20:33:30 2010 -0500
@@ -64,13 +64,15 @@
 if it cannot find your libraries.
 .. warning::
-    You need Boost version 1.41.0 or higher to build libLAS 1.6.
+    You need Boost version 1.38.0 or higher to build libLAS 1.6.
 .. note::
     If you are building on Windows, http://www.boostpro.com/download/ has
     an excellent installer.  Make sure to select the program_options
-    library to install when prompted.
+    library, and select static + multithreaded as the types.  If you want to
+    link in a different way, you will have to change your CMakeLists.txt
+    file accordingly.
 .. _optional_libraries:
@@ -135,6 +137,9 @@
         ln -s libclntsh.so.10.1 libclntsh.so
         ln -s libociei.so.10.1 libociei.so
+.. note::
+    MSVC should only require the oci.lib and oci.dll library and dlls.
 * Oracle 11g is recommended, but OCI for 10g will work.
 .. _`libgeotiff`: http://www.remotesensing.org/geotiff/geotiff.html
More information about the Liblas-commits mailing list
