[Liblas-commits] hg: 3 new changesets
liblas-commits at liblas.org liblas-commits at liblas.org
Tue Aug 31 22:19:35 EDT 2010
changeset b8b7ada4ea23 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=b8b7ada4ea23
summary: make failures more descriptive
changeset 0153fadb9214 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=0153fadb9214
summary: switch off schema in C API for now, this is broken and will be fixed
changeset 0a9071b292e9 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=0a9071b292e9
summary: initial rewrite of liblas::Schema
diffstat:
 include/liblas/lasheader.hpp |   15 +-
 include/liblas/lasschema.hpp |  193 +++++++++---
 src/detail/reader/header.cpp |    8 +-
 src/las_c_api.cpp            |  320 ++++++++++----------
 src/lasheader.cpp            |  148 ++++----
 src/lasschema.cpp            |  671 +++++++++++++++++++++++++++++++++++-------
 test/unit/common.cpp         |   50 +-
 7 files changed, 974 insertions(+), 431 deletions(-)
diffs (truncated from 1734 to 300 lines):
diff -r 3a3b6dc77e12 -r 0a9071b292e9 include/liblas/lasheader.hpp
--- a/include/liblas/lasheader.hpp	Sat Aug 28 22:26:29 2010 -0500
+++ b/include/liblas/lasheader.hpp	Tue Aug 31 21:19:25 2010 -0500
@@ -45,7 +45,6 @@
 #include <liblas/guid.hpp>
 #include <liblas/lasbounds.hpp>
-#include <liblas/lasheader.hpp>
 #include <liblas/lasschema.hpp>
 #include <liblas/lasspatialreference.hpp>
 #include <liblas/lasvariablerecord.hpp>
@@ -237,10 +236,10 @@
     /// \todo To be documented
     boost::uint16_t GetDataRecordLength() const;
-    /// Set the length of the point format.  Evidently, there are
-    /// LAS files in the wild that contain point formats of sizes that
-    /// are different than the prescribed set specified in the specification.
-    void SetDataRecordLength(boost::uint16_t v);
+    // /// Set the length of the point format.  Evidently, there are
+    // /// LAS files in the wild that contain point formats of sizes that
+    // /// are different than the prescribed set specified in the specification.
+    // void SetDataRecordLength(boost::uint16_t v);
     /// Get total number of point records stored in the LAS file.
     boost::uint32_t GetPointRecordsCount() const;
@@ -372,7 +371,7 @@
     void Init();
     void ClearGeoKeyVLRs();
-    void UpdateSchema();
+    // void UpdateSchema();
     // Private data members
@@ -393,8 +392,8 @@
     boost::uint16_t m_headerSize;
     boost::uint32_t m_dataOffset;
     boost::uint32_t m_recordsCount;
-    boost::uint8_t m_dataFormatId;
-    boost::uint16_t m_dataRecordLen;
+    // PointFormatName m_dataFormatId;
+    // boost::uint16_t m_dataRecordLen;
     boost::uint32_t m_pointRecordsCount;
     RecordsByReturnArray m_pointRecordsByReturn;
     PointScales m_scales;
diff -r 3a3b6dc77e12 -r 0a9071b292e9 include/liblas/lasschema.hpp
--- a/include/liblas/lasschema.hpp	Sat Aug 28 22:26:29 2010 -0500
+++ b/include/liblas/lasschema.hpp	Tue Aug 31 21:19:25 2010 -0500
@@ -42,102 +42,191 @@
 #ifndef LIBLAS_SCHEMA_HPP_INCLUDED
 #define LIBLAS_SCHEMA_HPP_INCLUDED
+#include <liblas/lasversion.hpp>
 // boost
 #include <boost/cstdint.hpp>
 #include <boost/any.hpp>
+#include <boost/shared_ptr.hpp>
 // std
 #include <iosfwd>
 #include <limits>
 #include <string>
+#include <vector>
 namespace liblas {
+// class Schema
+// public:
+//     Schema(boost::uint8_t major, boost::uint8_t minor, boost::uint16_t size);
+//     Schema(boost::uint8_t major, boost::uint8_t minor, boost::uint16_t size, bool bColor, bool bTime);
+//     Schema& operator=(Schema const& rhs);
+//     Schema(Schema const& other);
+//     ~Schema() {};
+//     /// Fetch byte size
+//     boost::uint16_t GetByteSize() const;
+//     /// Set the total byte size of the point record
+//     void SetByteSize(boost::uint16_t const& value);
+//     /// Get the base size (only accounting for Time, Color, etc )
+//     /// This is equivalent to the point format's base byte size
+//     boost::uint16_t GetBaseByteSize() const;
+//     boost::uint8_t GetVersionMajor() const;
+//     void SetVersionMajor(boost::uint8_t const& value);
+//     boost::uint8_t GetVersionMinor() const;
+//     void SetVersionMinor(boost::uint8_t const& value);
+//     bool HasColor() const;
+//     void Color(bool const& bColor); // updatesize(); }
+//     bool HasTime() const;
+//     void Time(bool const& bTime); // {m_hasTime = bTime; updatesize(); }
+// protected:
+//     boost::uint16_t m_size;
+//     boost::uint8_t m_versionminor;
+//     boost::uint8_t m_versionmajor;
+//     bool m_hasColor;
+//     bool m_hasTime;
+//     boost::uint16_t m_base_size;
+// private:
+//     void updatesize();
+//     void updatesize(boost::uint16_t new_size);
+//     boost::uint16_t calculate_base_size();
+class DimensionI;
+typedef boost::shared_ptr<DimensionI> DimensionPtr;
 class Schema
 public:
-    Schema(boost::uint8_t major, boost::uint8_t minor, boost::uint16_t size);
-    Schema(boost::uint8_t major, boost::uint8_t minor, boost::uint16_t size, bool bColor, bool bTime);
+    // Schema();
+    Schema(PointFormatName data_format_id);
     ~Schema() {};
     /// Fetch byte size
-    boost::uint16_t GetByteSize() const;
+    boost::uint32_t GetByteSize() const;
-    /// Set value of the red image channel
-    void SetByteSize(boost::uint16_t const& value);
+    boost::uint32_t GetSize() const;
-    boost::uint16_t GetBaseByteSize() const;
+    boost::uint32_t GetBaseByteSize() const;
+    PointFormatName GetDataFormatId() const { return m_data_format_id; }
+    void SetDataFormatId(PointFormatName const& value);//{ m_data_format_id = value; }
-    boost::uint8_t GetVersionMajor() const;
-    void SetVersionMajor(boost::uint8_t const& value);
+    bool HasColor() const;
+    // void Color(bool const& bColor);
+    bool HasTime() const;
+    // void Time(bool const& bTime);
-    boost::uint8_t GetVersionMinor() const;
-    void SetVersionMinor(boost::uint8_t const& value);
-    bool HasColor() const;
-    void Color(bool const& bColor); // updatesize(); }
-    bool HasTime() const;
-    void Time(bool const& bTime); // {m_hasTime = bTime; updatesize(); }
+    void AddDimension(boost::shared_ptr<DimensionI> dim);
+    boost::shared_ptr<DimensionI> GetDimension(std::string const& name) const;
+    void RemoveDimension(DimensionPtr dim);
+    std::vector<std::string> GetDimensionNames() const;
 protected:
-    boost::uint8_t m_versionminor;
-    boost::uint8_t m_versionmajor;
-    bool m_hasColor;
-    bool m_hasTime;
-    boost::uint16_t m_base_size;
+    PointFormatName m_data_format_id;
 private:
-    void updatesize();
-    void updatesize(boost::uint16_t new_size);
-    boost::uint16_t calculate_base_size();
+    std::vector<DimensionPtr> m_dimensions;
+    void add_record0_dimensions();
+    void add_time();
+    void add_color();
+    void update_required_dimensions(PointFormatName data_format_id);
-class Dimension
+class DimensionI
 public:
-    Dimension(std::string const& name, uint32_t size_in_bits) : m_name(name), m_bitsize(size_in_bits) {};
+    DimensionI(std::string const& name, boost::uint32_t size_in_bits) :
+        m_name(name),
+        m_bitsize(size_in_bits)
+    virtual ~DimensionI() {};
     std::string const& GetName() { return m_name; }
     /// bits, logical size of point record
-    virtual std::size_t GetSize() const = 0;
+    std::size_t GetSize() const
+        return m_bitsize;
     /// bytes, physical/serialisation size of record
-    virtual std::size_t GetByteSize() const = 0;
+    std::size_t GetByteSize() const
+        return m_bitsize / 8;
-    virtual bool IsRequired() const = 0;
+    /// Is this dimension required by PointFormatName
+    bool IsRequired() const { return m_required; }
+    void IsRequired(bool v) { m_required = v; }
+    bool IsActive() const { return m_active; }
+    void IsActive(bool v) { m_active = v; }
+    std::string GetDescription() const { return m_description; }
+    void SetDescription(std::string const& v) { m_description = v; }
-    virtual void IsRequired(bool bRequired) = 0;
 private:
     std::string m_name;
     boost::uint32_t m_bitsize;
+    bool m_required;
+    bool m_active;
+    std::string m_description;
 template <typename T>
-class NumericDimension : public Dimension
+class NumericDimension : public DimensionI
 public:
-    NumericDimension(T type, std::string const& name ) : Dimension(name),
+    NumericDimension(std::string const& name,
+                     T type,
+                     boost::uint32_t size_in_bits ) :
+        DimensionI(name, size_in_bits),
+        m_min(std::numeric_limits<T>::min()),
         m_max(std::numeric_limits<T>::max()),
-        m_min(std::numeric_limits<T>::min()),
         m_type(type)
     NumericDimension& operator=(NumericDimension const& rhs);
-    NumericDimension(Dimension const& other);
+    NumericDimension(DimensionI const& other);
     ~NumericDimension() {};
@@ -148,17 +237,7 @@
     T const& GetMax() { return m_max; }
     void SetMin(T const& min) { m_min = min; }
-    /// bits, logical size of point record
-    std::size_t GetSize() const
-        return sizeof(m_type) * 8;
-    /// bytes, physical/serialisation size of record
-    std::size_t GetByteSize() const
-        return sizeof(m_type);
 private:
@@ -168,7 +247,25 @@
More information about the Liblas-commits mailing list
