[Liblas-commits] hg: 2 new changesets
liblas-commits at liblas.org liblas-commits at liblas.org
Fri Dec 10 15:49:54 EST 2010
changeset cc73e7b29b2a in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=cc73e7b29b2a
summary: Add filtering to CachedReader
changeset c4ea88ef881a in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=c4ea88ef881a
summary: Fix #196 liblas::Header's reserved flags not being preserved
diffstat:
 src/detail/reader/cachedreader.cpp |  24 ++++++++++++++++++++++++
 src/detail/reader/header.cpp       |   2 +-
 test/unit/lasheader_test.cpp       |   2 ++
 test/unit/laswriter_test.cpp       |   2 ++
 4 files changed, 29 insertions(+), 1 deletions(-)
diffs (78 lines):
diff -r 28fec51dfcd4 -r c4ea88ef881a src/detail/reader/cachedreader.cpp
--- a/src/detail/reader/cachedreader.cpp	Thu Dec 09 16:17:11 2010 -0600
+++ b/src/detail/reader/cachedreader.cpp	Fri Dec 10 14:49:47 2010 -0600
@@ -233,6 +233,30 @@
     // PointPtr ptr = ReadCachedPoint(m_cache_read_position, header);
     ReadCachedPoint(m_cache_read_position);
     ++m_cache_read_position;
+    // Filter the points and continue reading until we either find
+    // one to keep or throw an exception.
+    bool bLastPoint = false;
+    if (!FilterPoint(*m_point))
+        ReadCachedPoint(m_cache_read_position);
+        ++m_cache_read_position;
+        while (!FilterPoint(*m_point))
+            if (m_current == m_size)
+                bLastPoint = true;
+                break;
+    if (bLastPoint)
+        throw std::out_of_range("ReadNextPoint: file has no more points to read, end of file reached");
diff -r 28fec51dfcd4 -r c4ea88ef881a src/detail/reader/header.cpp
--- a/src/detail/reader/header.cpp	Thu Dec 09 16:17:11 2010 -0600
+++ b/src/detail/reader/header.cpp	Fri Dec 10 14:49:47 2010 -0600
@@ -90,8 +90,8 @@
     m_header->SetFileSourceId(n2);
     // 3. Reserved
-    // This data must always contain Zeros.
     read_n(n2, m_ifs, sizeof(n2));
+    m_header->SetReserved(n2);
     // 4-7. Project ID
     uint32_t d1 = 0;
diff -r 28fec51dfcd4 -r c4ea88ef881a test/unit/lasheader_test.cpp
--- a/test/unit/lasheader_test.cpp	Thu Dec 09 16:17:11 2010 -0600
+++ b/test/unit/lasheader_test.cpp	Fri Dec 10 14:49:47 2010 -0600
@@ -138,6 +138,8 @@
         liblas::Header h;
         ensure_equals(h.GetReserved(), 0);
+        h.SetReserved(1);
+        ensure_equals(h.GetReserved(), 1);
     // Test Set/GetProjectId
diff -r 28fec51dfcd4 -r c4ea88ef881a test/unit/laswriter_test.cpp
--- a/test/unit/laswriter_test.cpp	Thu Dec 09 16:17:11 2010 -0600
+++ b/test/unit/laswriter_test.cpp	Fri Dec 10 14:49:47 2010 -0600
@@ -202,6 +202,7 @@
             test_default_header(hdr_default);
             // update some header data and overwrite header block
+            header.SetReserved(1);
             header.SetFileSourceId(65535);
             header.SetSystemId("Unit Test libLAS System");
             header.SetSoftwareId("Unit Test libLAS Software");
@@ -224,6 +225,7 @@
             liblas::Reader reader(ifs);
             liblas::Header const& header = reader.GetHeader();
+            ensure_equals(header.GetReserved(), 1);
             ensure_equals(header.GetFileSourceId(), 65535);
             ensure_equals(header.GetSystemId(), std::string("Unit Test libLAS System"));
             ensure_equals(header.GetSoftwareId(), std::string("Unit Test libLAS Software"));
More information about the Liblas-commits mailing list
