[Liblas-commits] laszip: remove all std:: explicit calls and instead put 'using n...
liblas-commits at liblas.org liblas-commits at liblas.org
Wed Dec 15 09:51:48 EST 2010
changeset 14b8703b0c4c in /Volumes/Data/www/liblas.org/laszip
details: http://hg.liblas.orglaszip?cmd=changeset;node=14b8703b0c4c
summary: remove all std:: explicit calls and instead put 'using namespace std;' in place to allow for usage by vc6
diffstat:
 include/laszip/lasunzipper.hpp |   4 +++-
 include/laszip/laszipper.hpp   |   5 +++--
 src/bytestreamin_istream.hpp   |   8 +++++---
 src/bytestreamout_ostream.hpp  |  14 ++++++++------
 src/lasunzipper.cpp            |   3 ++-
 src/laszipper.cpp              |   3 ++-
 tools/laszippertest.cpp        |  34 ++++++++++++++++++----------------
 7 files changed, 41 insertions(+), 30 deletions(-)
diffs (239 lines):
diff -r 74cc4311b468 -r 14b8703b0c4c include/laszip/lasunzipper.hpp
--- a/include/laszip/lasunzipper.hpp	Wed Dec 15 08:39:58 2010 -0600
+++ b/include/laszip/lasunzipper.hpp	Wed Dec 15 08:51:42 2010 -0600
@@ -52,6 +52,8 @@
 #include "laszip.hpp"
+using namespace std;
 class ByteStreamIn;
 class LASreadPoint;
@@ -60,7 +62,7 @@
 public:
   bool open(FILE* file, unsigned int num_items, const LASitem* items, unsigned int compression=0);
-  bool open(std::istream* stream, unsigned int num_items, const LASitem* items, unsigned int compression=0);
+  bool open(istream* stream, unsigned int num_items, const LASitem* items, unsigned int compression=0);
   bool read(unsigned char** point);
   bool close();
diff -r 74cc4311b468 -r 14b8703b0c4c include/laszip/laszipper.hpp
--- a/include/laszip/laszipper.hpp	Wed Dec 15 08:39:58 2010 -0600
+++ b/include/laszip/laszipper.hpp	Wed Dec 15 08:51:42 2010 -0600
@@ -48,12 +48,13 @@
 #include <stdio.h>
-#if _MSC_VER < 1300
+#if _MSC_VER < 1300
 #include <ostream.h>
 #else
 #include <fstream>
 #endif
@@ -65,7 +66,7 @@
 public:
   bool open(FILE* outfile, unsigned int num_items, LASitem* items, unsigned int compression=0);
-  bool open(std::ostream* outstream, unsigned int num_items, LASitem* items, unsigned int compression=0);
+  bool open(ostream* outstream, unsigned int num_items, LASitem* items, unsigned int compression=0);
   bool write(unsigned char** point);
   bool chunk(LASchunk* chunk);
   bool close(LASchunk* chunk=0);
diff -r 74cc4311b468 -r 14b8703b0c4c src/bytestreamin_istream.hpp
--- a/src/bytestreamin_istream.hpp	Wed Dec 15 08:39:58 2010 -0600
+++ b/src/bytestreamin_istream.hpp	Wed Dec 15 08:51:42 2010 -0600
@@ -52,10 +52,12 @@
 #include <fstream>
 #endif
 class ByteStreamInIstream : public ByteStreamIn
 public:
-  ByteStreamInIstream(std::istream* stream);
+  ByteStreamInIstream(istream* stream);
 /* read a single byte                                        */
   unsigned int getByte();
 /* read an array of bytes                                    */
@@ -63,10 +65,10 @@
 /* destructor                                                */
   ~ByteStreamInIstream(){};
 private:
-  std::istream* stream;
+  istream* stream;
-inline ByteStreamInIstream::ByteStreamInIstream(std::istream* stream)
+inline ByteStreamInIstream::ByteStreamInIstream(istream* stream)
   this->stream = stream;
diff -r 74cc4311b468 -r 14b8703b0c4c src/bytestreamout_ostream.hpp
--- a/src/bytestreamout_ostream.hpp	Wed Dec 15 08:39:58 2010 -0600
+++ b/src/bytestreamout_ostream.hpp	Wed Dec 15 08:51:42 2010 -0600
@@ -52,10 +52,12 @@
 #include <fstream>
 #endif
 class ByteStreamOutOstream : public ByteStreamOut
 public:
-  ByteStreamOutOstream(std::ostream* stream);
+  ByteStreamOutOstream(ostream* stream);
 /* write a single byte                                       */
   bool putByte(unsigned char byte);
 /* write an array of bytes                                   */
@@ -67,11 +69,11 @@
 /* destructor                                                */
   ~ByteStreamOutOstream(){};
 private:
-  std::ostream* stream;
-  std::ios::pos_type start;
+  ostream* stream;
+  ios::pos_type start;
-ByteStreamOutOstream::ByteStreamOutOstream(std::ostream* stream)
+ByteStreamOutOstream::ByteStreamOutOstream(ostream* stream)
   resetCount();
@@ -91,8 +93,8 @@
 unsigned int ByteStreamOutOstream::byteCount() const
-  std::ios::pos_type end = stream->tellp();
-  std::ios::off_type size = end - start;
+  ios::pos_type end = stream->tellp();
+  ios::off_type size = end - start;
   return static_cast<unsigned int>(size);
diff -r 74cc4311b468 -r 14b8703b0c4c src/lasunzipper.cpp
--- a/src/lasunzipper.cpp	Wed Dec 15 08:39:58 2010 -0600
+++ b/src/lasunzipper.cpp	Wed Dec 15 08:51:42 2010 -0600
@@ -49,6 +49,7 @@
 #include "bytestreamin_istream.hpp"
 #include "lasreadpoint.hpp"
 bool LASunzipper::open(FILE* infile, unsigned int num_items, const LASitem* items, unsigned int compression)
   count = 0;
@@ -61,7 +62,7 @@
   return true;
-bool LASunzipper::open(std::istream* instream, unsigned int num_items, const LASitem* items, unsigned int compression)
+bool LASunzipper::open(istream* instream, unsigned int num_items, const LASitem* items, unsigned int compression)
   count = 0;
   stream = new ByteStreamInIstream(instream);
diff -r 74cc4311b468 -r 14b8703b0c4c src/laszipper.cpp
--- a/src/laszipper.cpp	Wed Dec 15 08:39:58 2010 -0600
+++ b/src/laszipper.cpp	Wed Dec 15 08:51:42 2010 -0600
@@ -48,6 +48,7 @@
 #include "bytestreamout_file.hpp"
 #include "bytestreamout_ostream.hpp"
 #include "laswritepoint.hpp"
 bool LASzipper::open(FILE* outfile, unsigned int num_items, LASitem* items, unsigned int compression)
@@ -61,7 +62,7 @@
   return true;
-bool LASzipper::open(std::ostream* outstream, unsigned int num_items, LASitem* items, unsigned int compression)
+bool LASzipper::open(ostream* outstream, unsigned int num_items, LASitem* items, unsigned int compression)
   count = 0;
   stream = new ByteStreamOutOstream(outstream);
diff -r 74cc4311b468 -r 14b8703b0c4c tools/laszippertest.cpp
--- a/tools/laszippertest.cpp	Wed Dec 15 08:39:58 2010 -0600
+++ b/tools/laszippertest.cpp	Wed Dec 15 08:51:42 2010 -0600
@@ -57,6 +57,8 @@
 #endif
 #include <stdio.h>
 #include <stdlib.h>
@@ -66,16 +68,16 @@
   unsigned int i, j;
   unsigned int num_points = 100000;
   unsigned int num_errors = 0;
-  std::filebuf ofb1;
-  std::filebuf ofb2;
-  std::ostream* ostream1 = 0;
-  std::ostream* ostream2 = 0;
+  filebuf ofb1;
+  filebuf ofb2;
+  ostream* ostream1 = 0;
+  ostream* ostream2 = 0;
   FILE* ofile1 = 0;
   FILE* ofile2 = 0;
-  std::filebuf ifb1;
-  std::filebuf ifb2;
-  std::istream* istream1 = 0;
-  std::istream* istream2 = 0;
+  filebuf ifb1;
+  filebuf ifb2;
+  istream* istream1 = 0;
+  istream* istream2 = 0;
   FILE* ifile1 = 0;
   FILE* ifile2 = 0;
@@ -122,16 +124,16 @@
   if (use_iostream)
-    ofb1.open("test1.lax", std::ios::out);
-    ostream1 = new std::ostream(&ofb1);
+    ofb1.open("test1.lax", ios::out);
+    ostream1 = new ostream(&ofb1);
     if (!laszipper1->open(ostream1, num_items, items, LASZIP_COMPRESSION_NONE))
       fprintf(stderr, "ERROR: could not open laszipper1\n");
       exit(1);
-    ofb2.open("test2.lax", std::ios::out);
-    ostream2 = new std::ostream(&ofb2);
+    ofb2.open("test2.lax", ios::out);
+    ostream2 = new ostream(&ofb2);
     if (!laszipper2->open(ostream2, num_items, items, LASZIP_COMPRESSION_ARITHMETIC))
       fprintf(stderr, "ERROR: could not open laszipper2\n");
@@ -195,15 +197,15 @@
   if (use_iostream)
-    ifb1.open("test1.lax", std::ios::in);
-    istream1 = new std::istream(&ifb1);
+    ifb1.open("test1.lax", ios::in);
+    istream1 = new istream(&ifb1);
     if (!lasunzipper1->open(istream1, num_items, items, LASZIP_COMPRESSION_NONE))
       fprintf(stderr, "ERROR: could not open lasunzipper1\n");
       exit(1);
-    ifb2.open("test2.lax", std::ios::in);
-    istream2 = new std::istream(&ifb2);
+    ifb2.open("test2.lax", ios::in);
+    istream2 = new istream(&ifb2);
     if (!lasunzipper2->open(istream2, num_items, items, LASZIP_COMPRESSION_ARITHMETIC))
       fprintf(stderr, "ERROR: could not open lasunzipper2\n");
More information about the Liblas-commits mailing list
