[Liblas-commits] hg: use 'liblas' as the VLR id for OGR OGC WKT, set descriptions...
liblas-commits at liblas.org liblas-commits at liblas.org
Wed Dec 15 12:05:20 EST 2010
changeset f8621a69bd83 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=f8621a69bd83
summary: use 'liblas' as the VLR id for OGR OGC WKT, set descriptions for GeoTIFF tags
diffstat:
 src/lasspatialreference.cpp |  17 +++++++++++------
 1 files changed, 11 insertions(+), 6 deletions(-)
diffs (72 lines):
diff -r d086d7325aa5 -r f8621a69bd83 src/lasspatialreference.cpp
--- a/src/lasspatialreference.cpp	Wed Dec 15 10:54:05 2010 -0600
+++ b/src/lasspatialreference.cpp	Wed Dec 15 11:05:08 2010 -0600
@@ -167,28 +167,29 @@
 bool SpatialReference::IsGeoVLR(VariableRecord const& vlr) const
-    std::string const uid("LASF_Projection");
+    std::string const las_projid("LASF_Projection");
+    std::string const liblas_id("liblas");
     // GTIFF_GEOKEYDIRECTORY == 34735
-    if (uid == vlr.GetUserId(true).c_str() && 34735 == vlr.GetRecordId())
+    if (las_projid == vlr.GetUserId(true).c_str() && 34735 == vlr.GetRecordId())
         return true;
     // GTIFF_DOUBLEPARAMS == 34736
-    if (uid == vlr.GetUserId(true).c_str() && 34736 == vlr.GetRecordId())
+    if (las_projid == vlr.GetUserId(true).c_str() && 34736 == vlr.GetRecordId())
         return true;
     // GTIFF_ASCIIPARAMS == 34737
-    if (uid == vlr.GetUserId(true).c_str() && 34737 == vlr.GetRecordId())
+    if (las_projid == vlr.GetUserId(true).c_str() && 34737 == vlr.GetRecordId())
         return true;
     // OGR_WKT?
-    if (uid == vlr.GetUserId(true).c_str() && 2112 == vlr.GetRecordId())
+    if (liblas_id == vlr.GetUserId(true).c_str() && 2112 == vlr.GetRecordId())
         return true;
@@ -281,6 +282,7 @@
         int i = 0;
         record.SetRecordId(34735);
         record.SetUserId("LASF_Projection");
+        record.SetDescription("GeoTIFF GeoKeyDirectoryTag");
         std::vector<uint8_t> data;
         // Shorts are 2 bytes in length
@@ -310,6 +312,8 @@
         int i = 0;
         record.SetRecordId(34736);
+        record.SetDescription("GeoTIFF GeoDoubleParamsTag");
         // Doubles are 8 bytes in length
@@ -344,6 +348,7 @@
          int i = 0;
          record.SetRecordId(34737);
+         record.SetDescription("GeoTIFF GeoAsciiParamsTag");
          // whoa.  If the returned count was 0, it is because there
@@ -385,7 +390,7 @@
         const uint8_t* wkt_bytes = reinterpret_cast<const uint8_t*>(m_wkt.c_str());
         wkt_record.SetRecordId( 2112 );
-        wkt_record.SetUserId("LASF_Projection");
+        wkt_record.SetUserId("liblas");
         wkt_record.SetDescription( "OGR variant of OpenGIS WKT SRS" );
         // Would you be surprised if this remarshalling of bytes
More information about the Liblas-commits mailing list
