[Liblas-commits] laszip: 2 new changesets
liblas-commits at liblas.org liblas-commits at liblas.org
Wed Dec 15 14:10:55 EST 2010
changeset b21103347c21 in /Volumes/Data/www/liblas.org/laszip
details: http://hg.liblas.orglaszip?cmd=changeset;node=b21103347c21
summary: added rangecoder and fixed read past write issue
changeset 7c3e352c29ee in /Volumes/Data/www/liblas.org/laszip
details: http://hg.liblas.orglaszip?cmd=changeset;node=7c3e352c29ee
summary: added rangecoder and improved test output
diffstat:
 src/arithmeticencoder.cpp |    5 +
 src/lasreadpoint.cpp      |    7 +-
 src/laswritepoint.cpp     |    7 +-
 tools/laszippertest.cpp   |  158 +++++++++++++++++++++++++++++++++++++++++----
 4 files changed, 157 insertions(+), 20 deletions(-)
diffs (truncated from 358 to 300 lines):
diff -r f066092800a9 -r 7c3e352c29ee src/arithmeticencoder.cpp
--- a/src/arithmeticencoder.cpp	Wed Dec 15 08:37:53 2010 -0800
+++ b/src/arithmeticencoder.cpp	Wed Dec 15 11:10:35 2010 -0800
@@ -98,6 +98,11 @@
   U32 buffer_size = outbyte - outbuffer;
   if (buffer_size) outstream->putBytes(outbuffer, buffer_size);
+  // write three zero bytes to be sure the decoder does not read past the array
+  outstream->putByte(0);
   outstream = 0;
diff -r f066092800a9 -r 7c3e352c29ee src/lasreadpoint.cpp
--- a/src/lasreadpoint.cpp	Wed Dec 15 08:37:53 2010 -0800
+++ b/src/lasreadpoint.cpp	Wed Dec 15 11:10:35 2010 -0800
@@ -47,6 +47,7 @@
 #include "lasreadpoint.hpp"
 #include "arithmeticdecoder.hpp"
+#include "rangedecoder.hpp"
 #include "lasreaditemraw.hpp"
 #include "lasreaditemrawendianswapped.hpp"
 #include "lasreaditemcompressed_v1.hpp"
@@ -131,9 +132,9 @@
   case LASZIP_COMPRESSION_NONE:
     dec = 0;
     break;
-//  case LASZIP_COMPRESSION_RANGE:
-//    enc = new RangeDecoder();
-//    break;
+  case LASZIP_COMPRESSION_RANGE:
+    dec = new RangeDecoder();
+    break;
   case LASZIP_COMPRESSION_ARITHMETIC:
     dec = new ArithmeticDecoder();
     break;
diff -r f066092800a9 -r 7c3e352c29ee src/laswritepoint.cpp
--- a/src/laswritepoint.cpp	Wed Dec 15 08:37:53 2010 -0800
+++ b/src/laswritepoint.cpp	Wed Dec 15 11:10:35 2010 -0800
@@ -47,6 +47,7 @@
 #include "laswritepoint.hpp"
 #include "arithmeticencoder.hpp"
+#include "rangeencoder.hpp"
 #include "laswriteitemraw.hpp"
 #include "laswriteitemrawendianswapped.hpp"
 #include "laswriteitemcompressed_v1.hpp"
@@ -95,9 +96,9 @@
     enc = 0;
     break;
-//    enc = new RangeEncoder();
-//    break;
+    enc = new RangeEncoder();
+    break;
     enc = new ArithmeticEncoder();
     break;
diff -r f066092800a9 -r 7c3e352c29ee tools/laszippertest.cpp
--- a/tools/laszippertest.cpp	Wed Dec 15 08:37:53 2010 -0800
+++ b/tools/laszippertest.cpp	Wed Dec 15 11:10:35 2010 -0800
@@ -55,28 +55,40 @@
 using namespace std;
 #endif
+#include <time.h>
 #include <stdio.h>
+static double taketime()
+  return (double)(clock())/CLOCKS_PER_SEC;
 int main(int argc, char *argv[])
   unsigned char c;
   unsigned int i, j;
-  unsigned int num_points = 5;
-  unsigned int num_errors = 0;
+  unsigned int num_points = 1000000;
+  unsigned int num_errors, num_bytes;
   filebuf ofb1;
   filebuf ofb2;
+  filebuf ofb3;
   ostream* ostream1 = 0;
   ostream* ostream2 = 0;
+  ostream* ostream3 = 0;
   FILE* ofile1 = 0;
   FILE* ofile2 = 0;
+  FILE* ofile3 = 0;
   filebuf ifb1;
   filebuf ifb2;
+  filebuf ifb3;
   istream* istream1 = 0;
   istream* istream2 = 0;
+  istream* istream3 = 0;
   FILE* ifile1 = 0;
   FILE* ifile2 = 0;
+  FILE* ifile3 = 0;
+  double start_time, end_time;
-  bool range = false;
   bool use_iostream = true;
   // describe the point structure
@@ -116,6 +128,7 @@
   LASzipper* laszipper1 = new LASzipper(); // without compression
   LASzipper* laszipper2 = new LASzipper(); // with arithmetic compression
+  LASzipper* laszipper3 = new LASzipper(); // with range compression
   if (use_iostream)
@@ -136,6 +149,15 @@
       fprintf(stderr, "ERROR: could not open laszipper2\n");
       return 0;
+    ofb3.open("test3.lax", ios::out);
+    ofb3.setmode(filebuf::binary);
+    ostream3 = new ostream(&ofb3);
+    if (!laszipper3->open(ostream3, num_items, items, LASZIP_COMPRESSION_RANGE))
+      fprintf(stderr, "ERROR: could not open laszipper3\n");
+      return 0;
   else
@@ -152,10 +174,18 @@
       return 0;
+    ofile3 = fopen("test3.lax", "wb");
+    if (!laszipper3->open(ofile3, num_items, items, LASZIP_COMPRESSION_RANGE))
+      return 0;
   // write / compress num_points with "random" data
+  start_time = taketime();
   c = 0;
   for (i = 0; i < num_points; i++)
@@ -165,32 +195,64 @@
       c++;
     laszipper1->write(point);
+  num_bytes = laszipper1->close();
+  end_time = taketime();
+  fprintf(stderr, "laszipper1 wrote %d bytes in %g seconds\n", num_bytes, end_time-start_time);
+  c = 0;
+  for (i = 0; i < num_points; i++)
+    for (j = 0; j < point_size; j++)
+      point_data[j] = c;
+      c++;
     laszipper2->write(point);
+  num_bytes = laszipper2->close();
+  fprintf(stderr, "laszipper2 wrote %d bytes in %g seconds\n", num_bytes, end_time-start_time);
-  fprintf(stderr, "laszipper1 wrote %d bytes\n", laszipper1->close());
-  fprintf(stderr, "laszipper2 wrote %d bytes\n", laszipper2->close());
+  c = 0;
+      c++;
+    laszipper3->write(point);
+  num_bytes = laszipper3->close();
+  fprintf(stderr, "laszipper3 wrote %d bytes in %g seconds\n", num_bytes, end_time-start_time);
   delete laszipper1;
   delete laszipper2;
+  delete laszipper3;
   if (use_iostream)
-    ostream1->flush();
-    ostream2->flush();
     delete ostream1;
     delete ostream2;
+    delete ostream3;
     ofb1.close();
     ofb2.close();
+    ofb3.close();
   else
     fclose(ofile1);
     fclose(ofile2);
+    fclose(ofile3);
   LASunzipper* lasunzipper1 = new LASunzipper(); // without compression
   LASunzipper* lasunzipper2 = new LASunzipper(); // with arithmetic compression
+  LASunzipper* lasunzipper3 = new LASunzipper(); // with range compression
   if (use_iostream)
@@ -210,6 +272,14 @@
       fprintf(stderr, "ERROR: could not open lasunzipper2\n");
       return 0;
+    ifb3.open("test3.lax", ios::in);
+    ifb3.setmode(filebuf::binary);
+    istream3 = new istream(&ifb3);
+    if (!lasunzipper3->open(istream3, num_items, items, LASZIP_COMPRESSION_RANGE))
+      fprintf(stderr, "ERROR: could not open lasunzipper3\n");
+      return 0;
   else
@@ -225,10 +295,17 @@
       return 0;
+    ifile3 = fopen("test3.lax", "rb");
+    if (!lasunzipper3->open(ifile3, num_items, items, LASZIP_COMPRESSION_RANGE))
+      return 0;
   // read num_points with "random" data
   num_errors = 0;
   c = 0;
@@ -236,15 +313,29 @@
     lasunzipper1->read(point);
-      if (point_data[j] != c) num_errors++;
+      if (point_data[j] != c)
+        fprintf(stderr, "%d %d %d != %d\n", i, j, point_data[j], c);
+        num_errors++;
+        if (num_errors > 20) return -1;
       c++;
-  if (num_errors) fprintf(stderr, "ERROR: with lasunzipper1 %d\n", num_errors);
-  else fprintf(stderr, "SUCCESS: lasunzipper1 read %d points correclty\n", num_points);
+  num_bytes = lasunzipper1->close();
+  if (num_errors)
+    fprintf(stderr, "ERROR: with lasunzipper1 %d\n", num_errors);
+  else
+   fprintf(stderr, "SUCCESS: lasunzipper1 read %d bytes in %g seconds\n", num_bytes, end_time-start_time);
   // decompress num_points with "random" data
   num_errors = 0;
   c = 0;
@@ -261,26 +352,65 @@
       c++;
-  if (num_errors) fprintf(stderr, "ERROR: with lasunzipper2 %d\n", num_errors);
-  else fprintf(stderr, "SUCCESS: lasunzipper2 read %d points correclty\n", num_points);
+  num_bytes = lasunzipper2->close();
+  if (num_errors)
+    fprintf(stderr, "ERROR: with lasunzipper2 %d\n", num_errors);
More information about the Liblas-commits mailing list
