[Liblas-commits] hg: 4 new changesets
liblas-commits at liblas.org liblas-commits at liblas.org
Fri Dec 17 10:18:40 EST 2010
changeset 31d5978be725 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=31d5978be725
summary: reflect WKT VLR addition
changeset 85e234ea7623 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=85e234ea7623
summary: set the header, as written, back on to the liblas::WriterImpl so the user can fetch what was actually written
changeset 8eb28c112f40 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=8eb28c112f40
summary: test padding scenario for LAS 1.0 files
changeset dc3cb1f372a2 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=dc3cb1f372a2
summary: start on ReaderFactory
diffstat:
 apps/las2oci.cpp              |   7 +++-
 include/liblas/detail/fwd.hpp |   2 +
 include/liblas/factory.hpp    |  85 +++++++++++++++++++++++++++++++++++++++++++
 include/liblas/lasreader.hpp  |  11 +----
 include/liblas/liblas.hpp     |   1 +
 python/tests/SRS-GDAL.txt     |   2 +-
 src/CMakeLists.txt            |   2 +
 src/detail/writer/writer.cpp  |   2 +
 src/factory.cpp               |  82 +++++++++++++++++++++++++++++++++++++++++
 src/las_c_api.cpp             |   4 +-
 src/lasreader.cpp             |  29 +++-----------
 test/unit/laswriter_test.cpp  |  34 ++++++++++++++++-
 12 files changed, 227 insertions(+), 34 deletions(-)
diffs (truncated from 419 to 300 lines):
diff -r 018aae9571f4 -r dc3cb1f372a2 apps/las2oci.cpp
--- a/apps/las2oci.cpp	Thu Dec 16 12:13:27 2010 -0600
+++ b/apps/las2oci.cpp	Fri Dec 17 09:18:22 2010 -0600
@@ -1112,7 +1112,12 @@
         liblas::Reader* reader2 = 0;
         if (bCachedReader)
-            reader2 = new liblas::Reader(*istrm2,0);
+            liblas::ReaderFactory rf;
+            liblas::Reader r = rf.CreateCached(*istrm2, 0);
+            reader2 = new liblas::Reader(r);
+            // reader2 = new liblas::Reader(*istrm2,0);
         else
             reader2 = new liblas::Reader(*istrm2);
diff -r 018aae9571f4 -r dc3cb1f372a2 include/liblas/detail/fwd.hpp
--- a/include/liblas/detail/fwd.hpp	Thu Dec 16 12:13:27 2010 -0600
+++ b/include/liblas/detail/fwd.hpp	Fri Dec 17 09:18:22 2010 -0600
@@ -67,6 +67,8 @@
 typedef boost::shared_ptr<Point> PointPtr;
 typedef boost::shared_ptr<TransformI> TransformPtr;
 typedef boost::shared_ptr<FilterI> FilterPtr;
+typedef boost::shared_ptr<ReaderI> ReaderIPtr;
+typedef boost::shared_ptr<WriterI> WriterIPtr;
 namespace detail {
diff -r 018aae9571f4 -r dc3cb1f372a2 include/liblas/factory.hpp
--- /dev/null	Thu Jan 01 00:00:00 1970 +0000
+++ b/include/liblas/factory.hpp	Fri Dec 17 09:18:22 2010 -0600
@@ -0,0 +1,85 @@
+* $Id$
+* Project:  libLAS - http://liblas.org - A BSD library for LAS format data.
+* Purpose:  LAS factories
+* Author:   Howard Butler, hobu.inc at gmail.com
+* Copyright (c) 2008, Mateusz Loskot
+* Copyright (c) 2010, Howard Butler
+* All rights reserved.
+* Redistribution and use in source and binary forms, with or without
+* modification, are permitted provided that the following
+* conditions are met:
+*     * Redistributions of source code must retain the above copyright
+*       notice, this list of conditions and the following disclaimer.
+*     * Redistributions in binary form must reproduce the above copyright
+*       notice, this list of conditions and the following disclaimer in
+*       the documentation and/or other materials provided
+*       with the distribution.
+*     * Neither the name of the Martin Isenburg or Iowa Department
+*       of Natural Resources nor the names of its contributors may be
+*       used to endorse or promote products derived from this software
+*       without specific prior written permission.
+* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
+* FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
+* COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
+* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
+* BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
+* OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
+* AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+* OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+* OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
+* OF SUCH DAMAGE.
+#ifndef LIBLAS_FACTORY_HPP_INCLUDED
+#define LIBLAS_FACTORY_HPP_INCLUDED
+#include <liblas/lasreader.hpp>
+#include <liblas/laswriter.hpp>
+#include <liblas/export.hpp>
+// boost
+#include <boost/cstdint.hpp>
+// std
+namespace liblas {
+class LAS_DLL ReaderFactory
+public:
+    ReaderFactory() {};
+    ReaderFactory(ReaderFactory const& other);
+    ReaderFactory& operator=(ReaderFactory const& rhs);
+    Reader CreateWithImpl(ReaderIPtr r);
+    Reader CreateCached(std::istream& stream, boost::uint32_t cache_size);
+    Reader Create(std::istream& stream);
+    /// Destructor.
+    /// @exception nothrow
+    ~ReaderFactory() {};
+private:
+} // namespace liblas
+#endif // ndef LIBLAS_LASREADER_HPP_INCLUDED
diff -r 018aae9571f4 -r dc3cb1f372a2 include/liblas/lasreader.hpp
--- a/include/liblas/lasreader.hpp	Thu Dec 16 12:13:27 2010 -0600
+++ b/include/liblas/lasreader.hpp	Fri Dec 17 09:18:22 2010 -0600
@@ -71,17 +71,11 @@
     /// @param ifs - stream used as source of LAS records.
     /// @exception std::runtime_error - on failure state of the input stream.
     Reader(std::istream& ifs);
-    Reader(std::istream& ifs, boost::uint32_t cache_size);
-    Reader(std::istream& ifs, boost::uint32_t cache_size, Header const& header);
-    Reader(ReaderI* reader);
+    Reader(ReaderIPtr reader);
     Reader(Reader const& other);
     Reader& operator=(Reader const& rhs);
-    /// User-defined consructor initializes reader with input stream and
-    /// a header to override the values in the file
-    /// @exception std::runtime_error - on failure state of the input stream.
-    Reader(std::istream& ifs, Header const& header);
     /// Destructor.
@@ -90,6 +84,8 @@
     /// Provides read-only access to header of LAS file being read.
     Header const& GetHeader() const;
+    void SetHeader(Header const& );
     /// Provides read-only access to current point record.
@@ -146,7 +142,6 @@
     void Init(); // throws on error
-    typedef boost::shared_ptr<ReaderI> ReaderIPtr;
     ReaderIPtr m_pimpl;
diff -r 018aae9571f4 -r dc3cb1f372a2 include/liblas/liblas.hpp
--- a/include/liblas/liblas.hpp	Thu Dec 16 12:13:27 2010 -0600
+++ b/include/liblas/liblas.hpp	Fri Dec 17 09:18:22 2010 -0600
@@ -68,6 +68,7 @@
 #include <liblas/detail/private_utility.hpp>
 #include <liblas/capi/las_version.h>
+#include <liblas/factory.hpp>
 // booost
 #include <boost/array.hpp>
diff -r 018aae9571f4 -r dc3cb1f372a2 python/tests/SRS-GDAL.txt
--- a/python/tests/SRS-GDAL.txt	Thu Dec 16 12:13:27 2010 -0600
+++ b/python/tests/SRS-GDAL.txt	Fri Dec 17 09:18:22 2010 -0600
@@ -31,7 +31,7 @@
   True
   >>> p = f.read(0)
   >>> s2.vlr_count()
-  3
+  4
   >>> s2.GetVLR(0).recordlength
   64
   >>> int(round(p.x))
diff -r 018aae9571f4 -r dc3cb1f372a2 src/CMakeLists.txt
--- a/src/CMakeLists.txt	Thu Dec 16 12:13:27 2010 -0600
+++ b/src/CMakeLists.txt	Fri Dec 17 09:18:22 2010 -0600
@@ -23,6 +23,7 @@
   ${LIBLAS_HEADERS_DIR}/chipper.hpp
   ${LIBLAS_HEADERS_DIR}/exception.hpp
   ${LIBLAS_HEADERS_DIR}/export.hpp
+  ${LIBLAS_HEADERS_DIR}/factory.hpp
   ${LIBLAS_HEADERS_DIR}/guid.hpp
   ${LIBLAS_HEADERS_DIR}/iterator.hpp
   ${LIBLAS_HEADERS_DIR}/lasbounds.hpp
@@ -108,6 +109,7 @@
 set(LIBLAS_CPP
   chipper.cpp
+  factory.cpp
   lasclassification.cpp
   lascolor.cpp
   lasdimension.cpp
diff -r 018aae9571f4 -r dc3cb1f372a2 src/detail/writer/writer.cpp
--- a/src/detail/writer/writer.cpp	Thu Dec 16 12:13:27 2010 -0600
+++ b/src/detail/writer/writer.cpp	Fri Dec 17 09:18:22 2010 -0600
@@ -69,6 +69,8 @@
     m_header_writer = HeaderWriterPtr(new writer::Header(m_ofs,m_pointCount, *m_header) );
     m_header_writer->write();
+    m_header = HeaderPtr(new liblas::Header(m_header_writer->GetHeader()));
 void WriterImpl::UpdatePointCount(boost::uint32_t count)
diff -r 018aae9571f4 -r dc3cb1f372a2 src/factory.cpp
+++ b/src/factory.cpp	Fri Dec 17 09:18:22 2010 -0600
@@ -0,0 +1,82 @@
+ * $Id$
+ * Project:  libLAS - http://liblas.org - A BSD library for LAS format data.
+ * Purpose:  LAS factories
+ * Author:   Howard Butler, hobu.inc at gmail.com
+ * Copyright (c) 2008, Mateusz Loskot
+ * Copyright (c) 2010, Howard Butler
+ * All rights reserved.
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following
+ * conditions are met:
+ *     * Redistributions of source code must retain the above copyright
+ *       notice, this list of conditions and the following disclaimer.
+ *     * Redistributions in binary form must reproduce the above copyright
+ *       notice, this list of conditions and the following disclaimer in
+ *       the documentation and/or other materials provided
+ *       with the distribution.
+ *     * Neither the name of the Martin Isenburg or Iowa Department
+ *       of Natural Resources nor the names of its contributors may be
+ *       used to endorse or promote products derived from this software
+ *       without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+ * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+ * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
+ * FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
+ * COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
+ * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
+ * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
+ * OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
+ * AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+ * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+ * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
+ * OF SUCH DAMAGE.
+#include <liblas/detail/reader/reader.hpp>
+#include <liblas/detail/reader/cachedreader.hpp>
+#include <liblas/utility.hpp>
+// boost
+// std
+#include <stdexcept>
+#include <fstream>
+#include <string>
+#include <cstring> // std::memset
+#include <cassert>
+#include <iostream>
+using namespace boost;
+namespace liblas
+Reader ReaderFactory::CreateWithImpl(ReaderIPtr r)
+    liblas::Reader reader(r);
+    return reader;
+Reader ReaderFactory::CreateCached(std::istream& stream, boost::uint32_t cache_size)
+    ReaderIPtr r = ReaderIPtr(new detail::CachedReaderImpl(stream, cache_size) );
+    return liblas::Reader(r);
+Reader ReaderFactory::Create(std::istream& stream)
+    ReaderIPtr r = ReaderIPtr(new detail::ReaderImpl(stream) );
diff -r 018aae9571f4 -r dc3cb1f372a2 src/las_c_api.cpp
--- a/src/las_c_api.cpp	Thu Dec 16 12:13:27 2010 -0600
+++ b/src/las_c_api.cpp	Fri Dec 17 09:18:22 2010 -0600
More information about the Liblas-commits mailing list
