[Liblas-commits] hg: add WriterFactory
liblas-commits at liblas.org liblas-commits at liblas.org
Fri Dec 17 14:04:50 EST 2010
changeset d44837072a6a in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=d44837072a6a
summary: add WriterFactory
diffstat:
 include/liblas/factory.hpp   |  23 +++++++++++++++++++++--
 include/liblas/laswriter.hpp |   5 +++--
 src/detail/writer/writer.cpp |  16 ----------------
 src/factory.cpp              |  20 +++++++++++++++++++-
 src/laswriter.cpp            |   9 ++++++++-
 5 files changed, 51 insertions(+), 22 deletions(-)
diffs (163 lines):
diff -r d4128e8b5ece -r d44837072a6a include/liblas/factory.hpp
--- a/include/liblas/factory.hpp	Fri Dec 17 11:42:54 2010 -0600
+++ b/include/liblas/factory.hpp	Fri Dec 17 13:04:42 2010 -0600
@@ -67,7 +67,7 @@
     Reader CreateWithImpl(ReaderIPtr r);
     Reader CreateCached(std::istream& stream, boost::uint32_t cache_size);
-    Reader Create(std::istream& stream);
+    Reader CreateWithStream(std::istream& stream);
     /// Destructor.
     /// @exception nothrow
@@ -76,10 +76,29 @@
 private:
+class LAS_DLL WriterFactory
+public:
+    WriterFactory() {};
+    WriterFactory(WriterFactory const& other);
+    WriterFactory& operator=(WriterFactory const& rhs);
+    Writer CreateWithImpl(WriterIPtr w);
+    Writer CreateWithStream(std::ostream& stream);
+    /// Destructor.
+    /// @exception nothrow
+    ~WriterFactory() {};
+private:
 } // namespace liblas
 #endif // ndef LIBLAS_LASREADER_HPP_INCLUDED
diff -r d4128e8b5ece -r d44837072a6a include/liblas/laswriter.hpp
--- a/include/liblas/laswriter.hpp	Fri Dec 17 11:42:54 2010 -0600
+++ b/include/liblas/laswriter.hpp	Fri Dec 17 13:04:42 2010 -0600
@@ -71,6 +71,8 @@
     Writer(std::ostream& ofs, Header const& header);
     Writer(Writer const& other);
+    Writer(WriterIPtr ptr);
     Writer& operator=(Writer const& rhs);
     /// Destructor does not close file attached to the output stream
@@ -104,8 +106,7 @@
     void SetTransforms(std::vector<liblas::TransformPtr> const& transforms);
 private:
-    typedef boost::shared_ptr<WriterI> WriterIPtr;
     WriterIPtr m_pimpl;
diff -r d4128e8b5ece -r d44837072a6a src/detail/writer/writer.cpp
--- a/src/detail/writer/writer.cpp	Fri Dec 17 11:42:54 2010 -0600
+++ b/src/detail/writer/writer.cpp	Fri Dec 17 13:04:42 2010 -0600
@@ -129,21 +129,5 @@
     m_header = HeaderPtr(new liblas::Header(header));
-WriterImpl* WriterFactory::Create(std::ostream& ofs)
-    if (!ofs)
-        throw std::runtime_error("output stream state is invalid");
-    return new detail::WriterImpl(ofs);
-void WriterFactory::Destroy(detail::WriterImpl* p)
-    delete p;
-    p = 0;
 }} // namespace liblas::detail
diff -r d4128e8b5ece -r d44837072a6a src/factory.cpp
--- a/src/factory.cpp	Fri Dec 17 11:42:54 2010 -0600
+++ b/src/factory.cpp	Fri Dec 17 13:04:42 2010 -0600
@@ -43,6 +43,7 @@
 #include <liblas/factory.hpp>
 #include <liblas/detail/reader/reader.hpp>
 #include <liblas/detail/reader/cachedreader.hpp>
+#include <liblas/detail/writer/writer.hpp>
 #include <liblas/utility.hpp>
 // boost
@@ -73,10 +74,27 @@
     return liblas::Reader(r);
-Reader ReaderFactory::Create(std::istream& stream)
+Reader ReaderFactory::CreateWithStream(std::istream& stream)
     ReaderIPtr r = ReaderIPtr(new detail::ReaderImpl(stream) );
+Writer WriterFactory::CreateWithImpl(WriterIPtr w)
+    liblas::Writer writer(w);
+    return writer;
+Writer WriterFactory::CreateWithStream(std::ostream& stream)
+    WriterIPtr w  = WriterIPtr(new detail::WriterImpl(stream));
+    return liblas::Writer(w);
diff -r d4128e8b5ece -r d44837072a6a src/laswriter.cpp
--- a/src/laswriter.cpp	Fri Dec 17 11:42:54 2010 -0600
+++ b/src/laswriter.cpp	Fri Dec 17 13:04:42 2010 -0600
@@ -42,6 +42,7 @@
 #include <liblas/lasversion.hpp>
 #include <liblas/laswriter.hpp>
+#include <liblas/factory.hpp>
 // std
 #include <stdexcept>
@@ -54,7 +55,7 @@
 Writer::Writer(std::ostream& ofs, Header const& header) :
-    m_pimpl(detail::WriterFactory::Create(ofs))
+    m_pimpl(WriterIPtr(new detail::WriterImpl(ofs)))
     m_pimpl->SetHeader(header);
@@ -76,6 +77,12 @@
     return *this;
+Writer::Writer(WriterIPtr ptr) :
+    m_pimpl(ptr)
 Writer::~Writer()
More information about the Liblas-commits mailing list
