[Liblas-commits] laszip: 3 new changesets
liblas-commits at liblas.org liblas-commits at liblas.org
Fri Dec 17 22:45:16 EST 2010
changeset 473da02e72e3 in /Volumes/Data/www/liblas.org/laszip
details: http://hg.liblas.orglaszip?cmd=changeset;node=473da02e72e3
summary: updated the endian handling and allow seeking
changeset c66256ecc759 in /Volumes/Data/www/liblas.org/laszip
details: http://hg.liblas.orglaszip?cmd=changeset;node=c66256ecc759
changeset df98c890f766 in /Volumes/Data/www/liblas.org/laszip
details: http://hg.liblas.orglaszip?cmd=changeset;node=df98c890f766
summary: changed LASitem from struct to class
diffstat:
 include/laszip/lasunzipper.hpp |   80 ++++++++--------
 include/laszip/laszip.hpp      |  112 +++++++++++++++++++++++-
 include/laszip/laszipper.hpp   |   80 ++++++++--------
 src/bytestreamin.hpp           |    8 +
 src/bytestreamin_file.hpp      |  123 +++++++++++++++++++++++++-
 src/bytestreamin_istream.hpp   |  177 +++++++++++++++++++++++++++-----------
 src/bytestreamout.hpp          |   14 +++
 src/bytestreamout_file.hpp     |  114 +++++++++++++++++++++++-
 src/bytestreamout_ostream.hpp  |  185 ++++++++++++++++++++++++++++++++--------
 src/lasreaditemraw.hpp         |   26 ++++-
 src/lasreadpoint.cpp           |  100 ++++++---------------
 src/laswriteitemraw.hpp        |   26 ++++-
 src/laswritepoint.cpp          |   41 ++------
 src/mydefs.hpp                 |    2 +-
 14 files changed, 778 insertions(+), 310 deletions(-)
diffs (truncated from 1542 to 300 lines):
diff -r 41573d80a706 -r df98c890f766 include/laszip/lasunzipper.hpp
--- a/include/laszip/lasunzipper.hpp	Fri Dec 17 07:49:21 2010 -0800
+++ b/include/laszip/lasunzipper.hpp	Fri Dec 17 19:44:46 2010 -0800
@@ -1,21 +1,21 @@
- * Project:  integrating laszip into liblas - http://liblas.org -
- * Purpose:
- * Author:   Martin Isenburg
- *           isenburg at cs.unc.edu
- * Copyright (c) 2010, Martin Isenburg
- * This is free software; you can redistribute and/or modify it under
- * the terms of the GNU Lesser General Licence as published
- * by the Free Software Foundation.
- * See the COPYING file for more information.
+ * Project:  integrating laszip into liblas - http://liblas.org -
+ * Purpose:
+ * Author:   Martin Isenburg
+ *           isenburg at cs.unc.edu
+ * Copyright (c) 2010, Martin Isenburg
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU Lesser General Licence as published
+ * by the Free Software Foundation.
+ * See the COPYING file for more information.
@@ -39,44 +39,44 @@
   CHANGE HISTORY:
-    12 December 2010 -- created from LASwriter/LASreader after Howard got pushy (-;
+    12 December 2010 -- created from LASwriter/LASreader after Howard got pushy (-;
 #ifndef LAS_UNZIPPER_H
 #define LAS_UNZIPPER_H
-#include <stdio.h>
+#include <stdio.h>
+#include "laszip.hpp"
+#ifdef LZ_WIN32_VC6
+#include <fstream.h>
+#else
+#include <istream>
+#include <fstream>
+using namespace std;
+#endif
-#ifdef LZ_WIN32_VC6
-    #include <fstream.h>
-#else
-    #include <istream>
-    #include <fstream>
-    using namespace std;
-#endif
-#include "laszip.hpp"
-class ByteStreamIn;
-class LASreadPoint;
+class ByteStreamIn;
+class LASreadPoint;
 class LASunzipper
 public:
-  bool open(FILE* file, unsigned int num_items, const LASitem* items, unsigned int compression=0);
-  bool open(istream* stream, unsigned int num_items, const LASitem* items, unsigned int compression=0);
-  bool read(unsigned char** point);
-  unsigned int close();
+  bool open(FILE* file, unsigned int num_items, const LASitem* items, unsigned int compression=0);
+  bool open(istream* stream, unsigned int num_items, const LASitem* items, unsigned int compression=0);
+  bool read(unsigned char** point);
+  unsigned int close();
   LASunzipper();
   ~LASunzipper();
-private:
+private:
   int count;
-  ByteStreamIn* stream;
-  LASreadPoint* reader;
+  ByteStreamIn* stream;
+  LASreadPoint* reader;
 #endif
diff -r 41573d80a706 -r df98c890f766 include/laszip/laszip.hpp
--- a/include/laszip/laszip.hpp	Fri Dec 17 07:49:21 2010 -0800
+++ b/include/laszip/laszip.hpp	Fri Dec 17 19:44:46 2010 -0800
@@ -47,20 +47,116 @@
 #ifndef LASZIP_H
 #define LASZIP_H
-#if defined(_MSC_VER) && (_MSC_VER < 1300)
-// VC6 is very special wrt C++ streams
-#define LZ_WIN32_VC6
-#endif
+#if defined(_MSC_VER) && (_MSC_VER < 1300)
+#define LZ_WIN32_VC6
+#endif
 #define LASZIP_COMPRESSION_NONE 0
 #define LASZIP_COMPRESSION_RANGE 1
 #define LASZIP_COMPRESSION_ARITHMETIC 2
-struct LASitem
+class LASitem
-  enum { BYTE, SHORT, INT, LONG, FLOAT, DOUBLE, POINT10, GPSTIME, RGB } type;
-  short size;
-  short version;
+public:
+  enum { BYTE = 0, SHORT, INT, LONG, FLOAT, DOUBLE, POINT10, GPSTIME, RGB, WAVEPACKET } type;
+  unsigned short size;
+  unsigned short version;
+  bool supported_type() const
+    switch (type)
+    case POINT10:
+    case GPSTIME:
+    case RGB:
+    case WAVEPACKET:
+    case BYTE:
+      return true;
+      break;
+    return false;
+  bool supported_size() const
+    switch (type)
+    case POINT10:
+      if (size != 20) return false;
+      break;
+    case GPSTIME:
+      if (size != 8) return false;
+      break;
+    case RGB:
+      if (size != 6) return false;
+      break;
+    case WAVEPACKET:
+      if (size != 29) return false;
+      break;
+    case BYTE:
+      if (size < 1) return false;
+      break;
+    default:
+      return false;
+    return true;
+  bool supported_version() const
+    switch (type)
+    case POINT10:
+      if (version > 1) return false;
+      break;
+    case GPSTIME:
+      break;
+    case RGB:
+      break;
+    case WAVEPACKET:
+      break;
+    case BYTE:
+      break;
+    default:
+      return false;
+    return true;
+  bool supported() const
+    switch (type)
+    case POINT10:
+      break;
+    case GPSTIME:
+      break;
+    case RGB:
+      break;
+    case WAVEPACKET:
+      break;
+    case BYTE:
+      break;
+    default:
+      return false;
+    return true;
 struct LASchunk
diff -r 41573d80a706 -r df98c890f766 include/laszip/laszipper.hpp
--- a/include/laszip/laszipper.hpp	Fri Dec 17 07:49:21 2010 -0800
+++ b/include/laszip/laszipper.hpp	Fri Dec 17 19:44:46 2010 -0800
@@ -1,21 +1,21 @@
- * Purpose:
+ * Purpose:
@@ -39,45 +39,45 @@
   CHANGE HISTORY:
 #ifndef LAS_ZIPPER_H
 #define LAS_ZIPPER_H
-#include <stdio.h>
+#include <stdio.h>
 #ifdef LZ_WIN32_VC6
More information about the Liblas-commits mailing list
