[Liblas-commits] laszip: 2 new changesets
liblas-commits at liblas.org liblas-commits at liblas.org
Sat Dec 18 14:50:13 EST 2010
changeset e9118cc24a18 in /Volumes/Data/www/liblas.org/laszip
details: http://hg.liblas.orglaszip?cmd=changeset;node=e9118cc24a18
summary: consolidated all IO paths
changeset 5aaa3c648f10 in /Volumes/Data/www/liblas.org/laszip
details: http://hg.liblas.orglaszip?cmd=changeset;node=5aaa3c648f10
diffstat:
 include/laszip/laszip.hpp     |   4 ++
 src/bytestreamin_file.hpp     |  12 ++++----
 src/bytestreamin_istream.hpp  |  58 +++++++++++++++++++++++-------------------
 src/bytestreamout.hpp         |   8 ++--
 src/bytestreamout_file.hpp    |  40 ++++++++++++++--------------
 src/bytestreamout_ostream.hpp |  48 +++++++++++++++--------------------
 6 files changed, 87 insertions(+), 83 deletions(-)
diffs (truncated from 397 to 300 lines):
diff -r df98c890f766 -r 5aaa3c648f10 include/laszip/laszip.hpp
--- a/include/laszip/laszip.hpp	Fri Dec 17 19:44:46 2010 -0800
+++ b/include/laszip/laszip.hpp	Sat Dec 18 11:49:15 2010 -0800
@@ -51,6 +51,10 @@
 #define LZ_WIN32_VC6
 #endif
+#define LASZIP_VERSION_MAJOR    1
+#define LASZIP_VERSION_MINOR    0
+#define LASZIP_VERSION_REVISION 0
 #define LASZIP_COMPRESSION_NONE 0
 #define LASZIP_COMPRESSION_RANGE 1
 #define LASZIP_COMPRESSION_ARITHMETIC 2
diff -r df98c890f766 -r 5aaa3c648f10 src/bytestreamin_file.hpp
--- a/src/bytestreamin_file.hpp	Fri Dec 17 19:44:46 2010 -0800
+++ b/src/bytestreamin_file.hpp	Sat Dec 18 11:49:15 2010 -0800
@@ -122,17 +122,17 @@
 inline bool ByteStreamInFile::get16bits(unsigned char* bytes)
-  return (fread(bytes, 1, 2, file) == 2);
+  return getBytes(bytes, 2);
 inline bool ByteStreamInFile::get32bits(unsigned char* bytes)
-  return (fread(bytes, 1, 4, file) == 4);
+  return getBytes(bytes, 4);
 inline bool ByteStreamInFile::get64bits(unsigned char* bytes)
-  return (fread(bytes, 1, 8, file) == 8);
+  return getBytes(bytes, 8);
 inline bool ByteStreamInFile::isSeekable() const
@@ -167,7 +167,7 @@
 inline bool ByteStreamInFileEndianSwapped::get16bits(unsigned char* bytes)
-  if (fread(swapped, 1, 2, file) == 2)
+  if (getBytes(swapped, 2))
     bytes[0] = swapped[1];
     bytes[1] = swapped[0];
@@ -178,7 +178,7 @@
 inline bool ByteStreamInFileEndianSwapped::get32bits(unsigned char* bytes)
-  if (fread(swapped, 1, 4, file) == 4)
+  if (getBytes(swapped, 4))
     bytes[0] = swapped[3];
     bytes[1] = swapped[2];
@@ -191,7 +191,7 @@
 inline bool ByteStreamInFileEndianSwapped::get64bits(unsigned char* bytes)
-  if (fread(swapped, 1, 8, file) == 8)
+  if (getBytes(swapped, 8))
     bytes[0] = swapped[7];
     bytes[1] = swapped[6];
diff -r df98c890f766 -r 5aaa3c648f10 src/bytestreamin_istream.hpp
--- a/src/bytestreamin_istream.hpp	Fri Dec 17 19:44:46 2010 -0800
+++ b/src/bytestreamin_istream.hpp	Sat Dec 18 11:49:15 2010 -0800
@@ -125,20 +125,17 @@
 inline bool ByteStreamInIstream::get16bits(unsigned char* bytes)
-  stream->read((char*)bytes, 2);
-  return !!(stream->good());
 inline bool ByteStreamInIstream::get32bits(unsigned char* bytes)
-  stream->read((char*)bytes, 4);
 inline bool ByteStreamInIstream::get64bits(unsigned char* bytes)
-  stream->read((char*)bytes, 8);
 inline bool ByteStreamInIstream::isSeekable() const
@@ -168,34 +165,43 @@
 inline bool ByteStreamInIstreamEndianSwapped::get16bits(unsigned char* bytes)
-  stream->read((char*)swapped, 2);
-  bytes[0] = swapped[1];
-  bytes[1] = swapped[0];
+    bytes[0] = swapped[1];
+    bytes[1] = swapped[0];
+    return true;
+  return false;
 inline bool ByteStreamInIstreamEndianSwapped::get32bits(unsigned char* bytes)
-  stream->read((char*)swapped, 4);
-  bytes[0] = swapped[3];
-  bytes[1] = swapped[2];
-  bytes[2] = swapped[1];
-  bytes[3] = swapped[0];
+    bytes[0] = swapped[3];
+    bytes[1] = swapped[2];
+    bytes[2] = swapped[1];
+    bytes[3] = swapped[0];
+    return true;
+  return false;
 inline bool ByteStreamInIstreamEndianSwapped::get64bits(unsigned char* bytes)
-  stream->read((char*)swapped, 8);
-  bytes[0] = swapped[7];
-  bytes[1] = swapped[6];
-  bytes[2] = swapped[5];
-  bytes[3] = swapped[4];
-  bytes[4] = swapped[3];
-  bytes[5] = swapped[2];
-  bytes[6] = swapped[1];
-  bytes[7] = swapped[0];
+    bytes[0] = swapped[7];
+    bytes[1] = swapped[6];
+    bytes[2] = swapped[5];
+    bytes[3] = swapped[4];
+    bytes[4] = swapped[3];
+    bytes[5] = swapped[2];
+    bytes[6] = swapped[1];
+    bytes[7] = swapped[0];
+    return true;
+  return false;
 #endif
diff -r df98c890f766 -r 5aaa3c648f10 src/bytestreamout.hpp
--- a/src/bytestreamout.hpp	Fri Dec 17 19:44:46 2010 -0800
+++ b/src/bytestreamout.hpp	Sat Dec 18 11:49:15 2010 -0800
@@ -52,13 +52,13 @@
 /* write a single byte                                       */
   virtual bool putByte(unsigned char byte) = 0;
 /* write an array of bytes                                   */
-  virtual bool putBytes(unsigned char* bytes, unsigned int num_bytes) = 0;
+  virtual bool putBytes(const unsigned char* bytes, unsigned int num_bytes) = 0;
 /* write 16 bit field (for implementing endian swap)         */
-  virtual bool put16bits(unsigned char* bytes) = 0;
+  virtual bool put16bits(const unsigned char* bytes) = 0;
 /* write 32 bit field (for implementing endian swap)         */
-  virtual bool put32bits(unsigned char* bytes) = 0;
+  virtual bool put32bits(const unsigned char* bytes) = 0;
 /* write 64 bit field (for implementing endian swap)         */
-  virtual bool put64bits(unsigned char* bytes) = 0;
+  virtual bool put64bits(const unsigned char* bytes) = 0;
 /* is the stream seekable (e.g. standard out is not)         */
   virtual bool isSeekable() const = 0;
 /* save position in the stream for (forward) seeking later   */
diff -r df98c890f766 -r 5aaa3c648f10 src/bytestreamout_file.hpp
--- a/src/bytestreamout_file.hpp	Fri Dec 17 19:44:46 2010 -0800
+++ b/src/bytestreamout_file.hpp	Sat Dec 18 11:49:15 2010 -0800
@@ -55,13 +55,13 @@
   bool putByte(unsigned char byte);
-  bool putBytes(unsigned char* bytes, unsigned int num_bytes);
+  bool putBytes(const unsigned char* bytes, unsigned int num_bytes);
-  virtual bool put16bits(unsigned char* bytes);
+  virtual bool put16bits(const unsigned char* bytes);
-  virtual bool put32bits(unsigned char* bytes);
+  virtual bool put32bits(const unsigned char* bytes);
-  virtual bool put64bits(unsigned char* bytes);
+  virtual bool put64bits(const unsigned char* bytes);
   bool isSeekable() const;
@@ -88,11 +88,11 @@
 public:
   ByteStreamOutFileEndianSwapped(FILE* file);
-  bool put16bits(unsigned char* bytes);
+  bool put16bits(const unsigned char* bytes);
-  bool put32bits(unsigned char* bytes);
+  bool put32bits(const unsigned char* bytes);
-  bool put64bits(unsigned char* bytes);
+  bool put64bits(const unsigned char* bytes);
 private:
   unsigned char swapped[8];
@@ -109,24 +109,24 @@
   return (fputc(byte, file) == byte);
-inline bool ByteStreamOutFile::putBytes(unsigned char* bytes, unsigned int num_bytes)
+inline bool ByteStreamOutFile::putBytes(const unsigned char* bytes, unsigned int num_bytes)
   return (fwrite(bytes, 1, num_bytes, file) == num_bytes);
-inline bool ByteStreamOutFile::put16bits(unsigned char* bytes)
+inline bool ByteStreamOutFile::put16bits(const unsigned char* bytes)
-  return (fwrite(bytes, 1, 2, file) == 2);
+  return putBytes(bytes, 2);
-inline bool ByteStreamOutFile::put32bits(unsigned char* bytes)
+inline bool ByteStreamOutFile::put32bits(const unsigned char* bytes)
-  return (fwrite(bytes, 1, 4, file) == 4);
+  return putBytes(bytes, 4);
-inline bool ByteStreamOutFile::put64bits(unsigned char* bytes)
+inline bool ByteStreamOutFile::put64bits(const unsigned char* bytes)
-  return (fwrite(bytes, 1, 8, file) == 8);
+  return putBytes(bytes, 8);
 inline bool ByteStreamOutFile::isSeekable() const
@@ -164,23 +164,23 @@
-inline bool ByteStreamOutFileEndianSwapped::put16bits(unsigned char* bytes)
+inline bool ByteStreamOutFileEndianSwapped::put16bits(const unsigned char* bytes)
   swapped[0] = bytes[1];
   swapped[1] = bytes[0];
-  return (fwrite(swapped, 1, 2, file) == 2);
+  return putBytes(swapped, 2);
-inline bool ByteStreamOutFileEndianSwapped::put32bits(unsigned char* bytes)
+inline bool ByteStreamOutFileEndianSwapped::put32bits(const unsigned char* bytes)
   swapped[0] = bytes[3];
   swapped[1] = bytes[2];
   swapped[2] = bytes[1];
   swapped[3] = bytes[0];
-  return (fwrite(swapped, 1, 4, file) == 4);
+  return putBytes(swapped, 4);
-inline bool ByteStreamOutFileEndianSwapped::put64bits(unsigned char* bytes)
+inline bool ByteStreamOutFileEndianSwapped::put64bits(const unsigned char* bytes)
   swapped[0] = bytes[7];
   swapped[1] = bytes[6];
@@ -190,7 +190,7 @@
   swapped[5] = bytes[2];
   swapped[6] = bytes[1];
   swapped[7] = bytes[0];
-  return (fwrite(swapped, 1, 8, file) == 8);
+  return putBytes(swapped, 8);
 #endif
diff -r df98c890f766 -r 5aaa3c648f10 src/bytestreamout_ostream.hpp
--- a/src/bytestreamout_ostream.hpp	Fri Dec 17 19:44:46 2010 -0800
+++ b/src/bytestreamout_ostream.hpp	Sat Dec 18 11:49:15 2010 -0800
@@ -61,13 +61,13 @@
More information about the Liblas-commits mailing list
