[Liblas-commits] hg: lasinfo and las2las coming on line for .laz
support
liblas-commits at liblas.org
Sat Dec 18 15:37:27 EST 2010
changeset ecaf4ec83cd2 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=ecaf4ec83cd2
summary: lasinfo and las2las coming on line for .laz support
diffstat:
apps/las2las.cpp | 15 ++-
include/liblas/detail/reader/zipreader.hpp | 19 ++-
include/liblas/detail/writer/zipwriter.hpp | 14 ++-
src/detail/reader/zipreader.cpp | 158 +++++++++++++++++++++++++---
src/detail/writer/zipwriter.cpp | 102 +++++++++++++++++-
src/laswriter.cpp | 5 +
6 files changed, 278 insertions(+), 35 deletions(-)
diffs (truncated from 519 to 300 lines):
diff -r 82459e1b0262 -r ecaf4ec83cd2 apps/las2las.cpp
--- a/apps/las2las.cpp Fri Dec 17 21:22:40 2010 -0800
+++ b/apps/las2las.cpp Sat Dec 18 12:31:40 2010 -0800
@@ -60,7 +60,8 @@
return false;
- liblas::Reader reader(ifs);
+ liblas::ReaderFactory f;
+ liblas::Reader reader = f.CreateWithStream(ifs);
SummaryPtr summary(new::liblas::Summary);
reader.SetFilters(filters);
@@ -300,7 +301,8 @@
// set_ifstream_buffer(ifs, default_buffer_size);
header = reader.GetHeader();
} else {
std::cerr << "Input LAS file not specified!\n";
@@ -322,6 +324,15 @@
// Transforms alter our header as well. Setting scales, offsets, etc.
transforms = GetTransforms(vm, verbose, header);
+ if (output.compare(output.length()-4,4,".laz")==0)
+#ifdef HAVE_LASZIP
+ header.SetIsCompressed(true);
+#else
+ throw std::runtime_error("Compression support not enabled in liblas configuration");
+#endif
bool op = process( input,
output,
header,
diff -r 82459e1b0262 -r ecaf4ec83cd2 include/liblas/detail/reader/zipreader.hpp
--- a/include/liblas/detail/reader/zipreader.hpp Fri Dec 17 21:22:40 2010 -0800
+++ b/include/liblas/detail/reader/zipreader.hpp Sat Dec 18 12:31:40 2010 -0800
@@ -54,6 +54,10 @@
#include <iosfwd>
#include <boost/shared_ptr.hpp>
+// liblaszip
+class LASitem;
+class LASunzipper;
namespace liblas { namespace detail {
typedef boost::shared_ptr< reader::Point > PointReaderPtr;
@@ -62,7 +66,6 @@
class ZipReaderImpl : public ReaderI
public:
ZipReaderImpl(std::istream& ifs);
~ZipReaderImpl();
@@ -79,9 +82,7 @@
void SetFilters(std::vector<liblas::FilterPtr> const& filters);
void SetTransforms(std::vector<liblas::TransformPtr> const& transforms);
protected:
bool FilterPoint(liblas::Point const& p);
void TransformPoint(liblas::Point& p);
@@ -92,7 +93,7 @@
boost::uint32_t m_size;
boost::uint32_t m_current;
- PointReaderPtr m_point_reader;
+ //PointReaderPtr m_point_reader;
HeaderReaderPtr m_header_reader;
HeaderPtr m_header;
@@ -101,7 +102,17 @@
std::vector<liblas::FilterPtr> m_filters;
std::vector<liblas::TransformPtr> m_transforms;
private:
+ void ConstructItems();
+ void ReadIdiom();
+ LASunzipper* m_unzipper;
+ unsigned int m_num_items;
+ LASitem* m_items;
+ unsigned char** m_lz_point;
+ unsigned char* m_lz_point_data;
+ unsigned int m_lz_point_size;
// Blocked copying operations, declared but not defined.
ZipReaderImpl(ZipReaderImpl const& other);
diff -r 82459e1b0262 -r ecaf4ec83cd2 include/liblas/detail/writer/zipwriter.hpp
--- a/include/liblas/detail/writer/zipwriter.hpp Fri Dec 17 21:22:40 2010 -0800
+++ b/include/liblas/detail/writer/zipwriter.hpp Sat Dec 18 12:31:40 2010 -0800
@@ -52,6 +52,10 @@
#include <boost/cstdint.hpp>
+// liblaszip
+class LASzipper;
+class LASitem;
typedef boost::shared_ptr< writer::Point > PointWriterPtr;
@@ -88,8 +92,16 @@
HeaderPtr m_header;
private:
+ boost::uint32_t m_pointCount;
- boost::uint32_t m_pointCount;
+ LASzipper* m_zipper;
+ LASitem* m_items;
// block copying operations
ZipWriterImpl(ZipWriterImpl const& other);
diff -r 82459e1b0262 -r ecaf4ec83cd2 src/detail/reader/zipreader.cpp
--- a/src/detail/reader/zipreader.cpp Fri Dec 17 21:22:40 2010 -0800
+++ b/src/detail/reader/zipreader.cpp Sat Dec 18 12:31:40 2010 -0800
@@ -68,18 +68,39 @@
: m_ifs(ifs)
, m_size(0)
, m_current(0)
- , m_point_reader(PointReaderPtr())
+ //, m_point_reader(PointReaderPtr())
, m_header_reader(new reader::Header(m_ifs))
, m_header(HeaderPtr())
, m_point(PointPtr(new liblas::Point()))
, m_filters(0)
- , m_transforms(0)
+ , m_transforms(0),
+ m_unzipper(NULL),
+ m_num_items(0),
+ m_items(NULL),
+ m_lz_point(NULL),
+ m_lz_point_data(NULL),
+ m_lz_point_size(0)
- new LASunzipper();
+ return;
ZipReaderImpl::~ZipReaderImpl()
+ if (m_unzipper)
+ m_unzipper->close();
+ delete m_unzipper;
+ m_unzipper = NULL;
+ m_num_items = 0;
+ delete[] m_items;
+ m_items = NULL;
+ delete[] m_lz_point;
+ delete[] m_lz_point_data;
+ return;
void ZipReaderImpl::Reset()
@@ -93,10 +114,84 @@
// If we reset the reader, we're ready to start reading points, so
// we'll create a point reader at this point.
- if (!m_point_reader)
+ if (!m_unzipper)
- m_point_reader = PointReaderPtr(new reader::Point(m_ifs, m_header));
+ m_unzipper = new LASunzipper();
+ ConstructItems();
+ bool ok = m_unzipper->open(&m_ifs, m_num_items, m_items, LASZIP_COMPRESSION_NONE);
+ if (!ok) throw 0; // BUG: need status codes?
+ return;
+void ZipReaderImpl::ConstructItems()
+ PointFormatName format = m_header->GetDataFormatId();
+ switch (format)
+ case ePointFormat0:
+ m_num_items = 1;
+ m_items = new LASitem[1];
+ m_items[0].set(LASitem::POINT10);
+ break;
+ case ePointFormat1:
+ m_num_items = 2;
+ m_items = new LASitem[2];
+ m_items[1].set(LASitem::GPSTIME);
+ break;
+ case ePointFormat2:
+ m_num_items = 2;
+ m_items[1].set(LASitem::RGB);
+ break;
+ case ePointFormat3:
+ m_num_items = 3;
+ m_items = new LASitem[3];
+ m_items[2].set(LASitem::RGB);
+ break;
+ case ePointFormat4:
+ m_num_items = 3;
+ m_items[2].set(LASitem::WAVEPACKET);
+ break;
+ default:
+ throw 0;
+ // construct the object that will hold a laszip point
+ // compute the point size
+ m_lz_point_size = 0;
+ for (unsigned int i = 0; i < m_num_items; i++)
+ m_lz_point_size += m_items[i].size;
+ // create the point data
+ unsigned int point_offset = 0;
+ m_lz_point = new unsigned char*[m_num_items];
+ m_lz_point_data = new unsigned char[m_lz_point_size];
+ for (unsigned i = 0; i < m_num_items; i++)
+ m_lz_point[i] = &(m_lz_point_data[point_offset]);
+ point_offset += m_items[i].size;
+ return;
void ZipReaderImpl::TransformPoint(liblas::Point& p)
@@ -144,9 +239,9 @@
m_header_reader->read();
m_header = m_header_reader->GetHeader();
+ m_point->SetHeaderPtr(m_header);
Reset();
void ZipReaderImpl::SetHeader(liblas::Header const& header)
@@ -154,6 +249,23 @@
m_header = HeaderPtr(new liblas::Header(header));
+void ZipReaderImpl::ReadIdiom()
+ //////m_point_reader->read();
+ //////++m_current;
+ //////*m_point = m_point_reader->GetPoint();
+ bool ok = m_unzipper->read(m_lz_point);
+ if (!ok) throw 0;
+ std::vector<boost::uint8_t> v(m_lz_point_size);
+ for (unsigned int i=0; i<m_lz_point_size; i++)
+ v[i] = m_lz_point_data[i];
+ m_point->SetData(v);
+ ++m_current;
void ZipReaderImpl::ReadNextPoint()
if (0 == m_current)
More information about the Liblas-commits
