[Liblas-commits] laszip: 2 new changesets
liblas-commits at liblas.org
Mon Dec 20 13:12:50 EST 2010
changeset 035b52b181dc in /Volumes/Data/www/liblas.org/laszip
details: http://hg.liblas.orglaszip?cmd=changeset;node=035b52b181dc
summary: minor changes to finalize interface
changeset b49409e2e144 in /Volumes/Data/www/liblas.org/laszip
details: http://hg.liblas.orglaszip?cmd=changeset;node=b49409e2e144
summary: more minor changes under the hood
diffstat:
include/laszip/laszip.hpp | 97 ++++++++++++++++++++++++++------------
include/laszip/laszipper.hpp | 3 +-
src/lasreaditemcompressed_v1.cpp | 18 +++++--
src/lasreaditemcompressed_v1.hpp | 1 +
src/lasreadpoint.cpp | 4 +
src/laswriteitemcompressed_v1.cpp | 23 +++++++--
src/laswriteitemcompressed_v1.hpp | 1 +
src/laswritepoint.cpp | 9 +++
src/laszipper.cpp | 7 ++
src/rangedecoder.cpp | 2 +-
src/rangeencoder.cpp | 2 +-
11 files changed, 121 insertions(+), 46 deletions(-)
diffs (truncated from 383 to 300 lines):
diff -r b095ef93a1f2 -r b49409e2e144 include/laszip/laszip.hpp
--- a/include/laszip/laszip.hpp Sat Dec 18 12:29:58 2010 -0800
+++ b/include/laszip/laszip.hpp Mon Dec 20 10:12:32 2010 -0800
@@ -55,8 +55,8 @@
#define LASZIP_VERSION_MINOR 0
#define LASZIP_VERSION_REVISION 0
-#define LASZIP_COMPRESSION_NONE 0
-#define LASZIP_COMPRESSION_RANGE 1
+#define LASZIP_COMPRESSION_NONE 0
+#define LASZIP_COMPRESSION_RANGE 1
#define LASZIP_COMPRESSION_ARITHMETIC 2
class LASitem
@@ -67,36 +67,65 @@
unsigned short size;
unsigned short version;
- // convenience function (not done as a ctor, since these items are usually allocated as an array)
- void set(LASitem::Type type)
+ void set(LASitem::Type t, unsigned int number=1)
- LASitem& x = *this;
- switch (type)
- case LASitem::POINT10:
- x.type = LASitem::POINT10;
- x.size = 20;
- x.version = 0;
- break;
- case LASitem::GPSTIME:
- x.type = LASitem::GPSTIME;
- x.size = 8;
- x.version = 0;
- break;
- case LASitem::RGB:
- x.type = LASitem::RGB;
- x.size = 6;
- x.version = 0;
- break;
- case LASitem::WAVEPACKET:
- x.type = LASitem::WAVEPACKET;
- x.size = 29;
- x.version = 0;
- break;
- default:
- throw 0; // BUG
- return;
+ switch (t)
+ case LASitem::POINT10:
+ type = LASitem::POINT10;
+ size = 20;
+ version = 0;
+ break;
+ case LASitem::GPSTIME:
+ type = LASitem::GPSTIME;
+ size = 8;
+ version = 0;
+ break;
+ case LASitem::RGB:
+ type = LASitem::RGB;
+ size = 6;
+ version = 0;
+ break;
+ case LASitem::WAVEPACKET:
+ type = LASitem::WAVEPACKET;
+ size = 29;
+ version = 0;
+ break;
+ case LASitem::BYTE:
+ type = LASitem::BYTE;
+ size = number;
+ version = 0;
+ break;
+ default:
+ throw 0; // BUG
+ return;
+ bool is_type(LASitem::Type t) const
+ if (t != type) return false;
+ switch (t)
+ case POINT10:
+ if (size != 20) return false;
+ break;
+ case GPSTIME:
+ if (size != 8) return false;
+ break;
+ case RGB:
+ if (size != 6) return false;
+ break;
+ case WAVEPACKET:
+ if (size != 29) return false;
+ break;
+ case BYTE:
+ if (size < 1) return false;
+ break;
+ default:
+ return false;
+ return true;
bool supported_type() const
@@ -110,6 +139,8 @@
case BYTE:
return true;
break;
+ default:
+ return false;
return false;
@@ -195,10 +226,12 @@
struct LASchunk
unsigned int count;
unsigned int bytes;
#endif
diff -r b095ef93a1f2 -r b49409e2e144 include/laszip/laszipper.hpp
--- a/include/laszip/laszipper.hpp Sat Dec 18 12:29:58 2010 -0800
+++ b/include/laszip/laszipper.hpp Mon Dec 20 10:12:32 2010 -0800
@@ -68,8 +68,7 @@
bool open(FILE* outfile, unsigned int num_items, LASitem* items, unsigned int compression=0);
bool open(ostream* outstream, unsigned int num_items, LASitem* items, unsigned int compression=0);
bool write(unsigned char** point);
- bool chunk(LASchunk* chunk);
- unsigned int close(LASchunk* chunk=0);
+ unsigned int close();
LASzipper();
~LASzipper();
diff -r b095ef93a1f2 -r b49409e2e144 src/lasreaditemcompressed_v1.cpp
--- a/src/lasreaditemcompressed_v1.cpp Sat Dec 18 12:29:58 2010 -0800
+++ b/src/lasreaditemcompressed_v1.cpp Mon Dec 20 10:12:32 2010 -0800
@@ -376,7 +376,8 @@
this->dec = dec;
/* create models and integer compressors */
- ic_rgb = new IntegerCompressor(dec, 16, 3); // 16 bits, 3 contexts
+ m_byte_used = dec->createSymbolModel(64);
+ ic_rgb = new IntegerCompressor(dec, 8, 6);
/* create last item */
last_item = new U8[6];
@@ -384,6 +385,7 @@
LASreadItemCompressed_RGB_v1::~LASreadItemCompressed_RGB_v1()
+ dec->destroySymbolModel(m_byte_used);
delete ic_rgb;
delete [] last_item;
@@ -393,6 +395,7 @@
/* init state */
/* init models and integer compressors */
+ dec->initSymbolModel(m_byte_used);
ic_rgb->initDecompressor();
/* init last item */
@@ -402,10 +405,15 @@
BOOL LASreadItemCompressed_RGB_v1::read(U8* item)
- ((U16*)item)[0] = (U16)(ic_rgb->decompress(((U16*)last_item)[0], 0));
- ((U16*)item)[1] = (U16)(ic_rgb->decompress(((U16*)last_item)[1], 1));
- ((U16*)item)[2] = (U16)(ic_rgb->decompress(((U16*)last_item)[2], 2));
- memcpy(last_item, item, 6);
+ U32 i, sym = dec->decodeSymbol(m_byte_used);
+ for (i = 0; i < 6; i++)
+ if (sym & (1 << i))
+ item[i] = ic_rgb->decompress(last_item[i], i);
+ last_item[i] = item[i];
return TRUE;
diff -r b095ef93a1f2 -r b49409e2e144 src/lasreaditemcompressed_v1.hpp
--- a/src/lasreaditemcompressed_v1.hpp Sat Dec 18 12:29:58 2010 -0800
+++ b/src/lasreaditemcompressed_v1.hpp Mon Dec 20 10:12:32 2010 -0800
@@ -118,6 +118,7 @@
EntropyDecoder* dec;
U8* last_item;
+ EntropyModel* m_byte_used;
IntegerCompressor* ic_rgb;
diff -r b095ef93a1f2 -r b49409e2e144 src/lasreadpoint.cpp
--- a/src/lasreadpoint.cpp Sat Dec 18 12:29:58 2010 -0800
+++ b/src/lasreadpoint.cpp Mon Dec 20 10:12:32 2010 -0800
@@ -115,6 +115,8 @@
case LASitem::BYTE:
readers_raw[i] = new LASreadItemRaw_BYTE(items[i].size);
break;
+ default:
+ return FALSE;
@@ -155,6 +157,8 @@
else
return FALSE;
break;
+ default:
+ return FALSE;
diff -r b095ef93a1f2 -r b49409e2e144 src/laswriteitemcompressed_v1.cpp
--- a/src/laswriteitemcompressed_v1.cpp Sat Dec 18 12:29:58 2010 -0800
+++ b/src/laswriteitemcompressed_v1.cpp Mon Dec 20 10:12:32 2010 -0800
@@ -419,7 +419,8 @@
this->enc = enc;
- ic_rgb = new IntegerCompressor(enc, 16, 3); // 16 bits, 3 contexts
+ m_byte_used = enc->createSymbolModel(64);
+ ic_rgb = new IntegerCompressor(enc, 8, 6);
@@ -427,6 +428,7 @@
LASwriteItemCompressed_RGB_v1::~LASwriteItemCompressed_RGB_v1()
+ enc->destroySymbolModel(m_byte_used);
delete ic_rgb;
@@ -436,6 +438,7 @@
/* init state */
+ enc->initSymbolModel(m_byte_used);
ic_rgb->initCompressor();
@@ -445,10 +448,20 @@
BOOL LASwriteItemCompressed_RGB_v1::write(U8* item)
- ic_rgb->compress(((U16*)last_item)[0], ((U16*)item)[0], 0);
- ic_rgb->compress(((U16*)last_item)[1], ((U16*)item)[1], 1);
- ic_rgb->compress(((U16*)last_item)[2], ((U16*)item)[2], 2);
+ U32 i, sym = 0;
+ sym |= ((last_item[i] != item[i]) << i);
+ enc->encodeSymbol(m_byte_used, sym);
+ if (last_item[i] != item[i])
+ ic_rgb->compress(last_item[i], item[i], i);
return TRUE;
diff -r b095ef93a1f2 -r b49409e2e144 src/laswriteitemcompressed_v1.hpp
--- a/src/laswriteitemcompressed_v1.hpp Sat Dec 18 12:29:58 2010 -0800
+++ b/src/laswriteitemcompressed_v1.hpp Mon Dec 20 10:12:32 2010 -0800
@@ -118,6 +118,7 @@
EntropyEncoder* enc;
U8* last_item;
diff -r b095ef93a1f2 -r b49409e2e144 src/laswritepoint.cpp
--- a/src/laswritepoint.cpp Sat Dec 18 12:29:58 2010 -0800
+++ b/src/laswritepoint.cpp Mon Dec 20 10:12:32 2010 -0800
@@ -101,19 +101,26 @@
writers_raw[i] = new LASwriteItemRaw_POINT10();
+ items[i].version = 0;
break;
More information about the Liblas-commits
