[Liblas-commits] hg: add 2010 annual report
liblas-commits at liblas.org liblas-commits at liblas.org
Tue Dec 21 22:37:32 EST 2010
changeset 08f404fcce59 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=08f404fcce59
summary: add 2010 annual report
diffstat:
 doc/development/annual_report_2010.txt |  247 +++++++++++++++++++++++++++++++++
 doc/development/index.txt              |    2 +
 2 files changed, 249 insertions(+), 0 deletions(-)
diffs (265 lines):
diff -r 037f40022cf1 -r 08f404fcce59 doc/development/annual_report_2010.txt
--- /dev/null	Thu Jan 01 00:00:00 1970 +0000
+++ b/doc/development/annual_report_2010.txt	Tue Dec 21 21:37:25 2010 -0600
@@ -0,0 +1,247 @@
+.. _2010_annual_report:
+2010 Annual Report
+:Author: Howard Butler
+:Contact: hobu.inc at gmail.com
+:Date: 12/21/2010
+The following document is a synopsis of major development activities that have
+taken place in the libLAS project (or related projects) in the 2010 calendar
+year.
+Vertical Datum Reprojection and Transformation
+Frank Warmerdam implemented vertical datum reprojection and transformation in the
+entire open source GIS stack in the past year (`proj.4`_, `GDAL`_ and `libgeotiff`_).  This work
+makes it possible to make vertical datum transformations via command-line utilities
+like :ref:`las2las <las2las>` in addition to providing the tools for software
+developers to implement the features in their own software.
+.. _`libgeotiff`: http://www.remotesensing.org/geotiff/geotiff.html
+.. _`proj.4`: http://proj.maptools.org/
+.. _`GDAL`: http://www.gdal.org
+libLAS Processing Kernel
+libLAS gained something I call the "libLAS Processing Kernel" in the past year.
+It's really just a set of common functions that all application-level software
+can reuse to implement filtering and transformation on LAS data.  The collation
+of all of this functionality in a common place has meant the reuse of the
+same operations in many of the libLAS utilities include :ref:`las2las <las2las>`,
+:ref:`lasinfo <lasinfo>`, and :ref:`las2txt <las2txt>`.  New features implemented
+in the kernel include:
+* Color fetching from GDAL raster data sources
+* Data reprojection and vertical datum transformation
+* Numerous filtering operations
+* Header modification
+These utilities are available to all software developers who wish to reuse them
+in their own tools.
+Re-engineering of :ref:`las2las <las2las>` :ref:`las2txt <las2txt>` and :ref:`lasinfo <lasinfo>`
+:ref:`las2las <las2las>` :ref:`las2txt <las2txt>` and :ref:`lasinfo <lasinfo>`
+were re-imagined in light of development of the `libLAS Processing Kernel`_ to
+take advantage of new functionality and regularize command-line argument
+handling and parsing. The previous versions of the utilities have been
+preserved under the :ref:`las2las-old <las2las_old>` :ref:`las2txt-old
+<las2txt_old>` and :ref:`lasinfo-old <lasinfo_old>` monikers in case people
+have significant processing workflows developed with them. It would be
+advantageous to upgrade to the new versions in many cases -- both for
+significantly improved functionality and for a speed improvement that is
+sometimes double that of the -old versions.
+Some new features the utilities gained as part of this effort include:
+* Setting color information from GDAL rasters
+* Splitting files based on a point count or a file size in mb
+* Chaining many filter operations together into a single call
+* Modifying header information, including setting coordinate system info
+* Summarizing data more fully and more flexibly (XML, per-point)
+Chipper
+Andrew Bell developed a specialized point partitioning process called
+:ref:`lasblock <lasblock>` to bucketize point data.The process that aims to
+optimize the fill capacity, shape, and speed of processing. More specifically,
+it attempts to keep the blocks as full as possible and as square as possible
+to augment querying characteristics for `Oracle Point Cloud`_. This
+pre-processing is needed as precursor step in the processing chain that ends
+with actually loading the data into Oracle via :ref:`las2oci`. :ref:`lasblock
+<lasblock>` can also be used as a LAS tiling process, although it is not so
+memory efficient.
+Indexing
+Gary Huber developed an octree-based spatial index for libLAS to speed up random,
+bounding-box-based queries to LAS files. It is released as part of libLAS 1.6,
+but its full implementation within the library is not yet complete. The index
+can store its data within VLRs (requires a file rewrite) in addition to
+in a file alongside the .las file.
+CMake
+libLAS was migrated to using `CMake`_ for its configuration system. CMake
+allows easy generation of MSVC project files, XCode project files, and make
+files under a common configuration. This effort eliminated three parallel
+build system configurations (MSVC projects, GNU autoconf, MSVC makefiles) and
+provided more flexibility for packaging, testing, and build types. In my
+opinion, its use has been a boon to the project.
+OSGeo4W
+For the first time ever, we have released fully-capable Windows libLAS
+packages in the form of an OSGeo4W release. These releases contain the full
+range of libLAS functionality including coordinate system support, Oracle
+support, vertical datum transformation, and chipping. Head to
+http://trac.osgeo.org/osgeo4w to obtain your copy and start testing libLAS
+immediately.
+New Website
+We rewrote the libLAS website and transformed it from a bunch of wiki pages
+in Trac to a Sphinx-backed HTML website.  We have added tons more documentation,
+provided it in formats such as `PDF`_, and organized things significantly.
+Generic LAS Schema Support
+Though it is specifically allowed by the standard but not widely implemented,
+it is possible to store extra data attached to each point after the requisite
+PointFormat data are stored. There is neither a regularized way to describe
+these data nor a way to capture metadata about this. To this end, I have
+proposed an XML schema document that could be stored in a VLR as well as
+schema-aware reader and writer implementations that can utilize that VLR to
+work with the data. See <https://lidarbb.cr.usgs.gov/index.php?showtopic=9075>
+for more details on the initial proposal of schema support.
+libLAS now implements a class called liblas::Schema that is driven
+by the Point Data Format ID of the header in addition to any extra dimensions
+you wish to store with the point.  This work is used for both the `Oracle Point Cloud`_
+effort and upcoming LASzip compression integration.
+Refactoring of liblas::Point class
+We significantly refactored the liblas::Point class the 1.6.0 release.  The
+first thing that was done was to make it "thinner" in the sense that it doesn't
+store a union of all point-format-derived dimensions on it, and instead
+stores a reference to a schema that informs the class about which dimensions
+exist.  Additionally, data are interpreted on-the-fly from the raw bytes
+which compose the point, eliminating the fidelity issues.
+libLAS 1.2.1 and below utilized a liblas::Point that was kind of fat. It
+carried around interpreted data members for all of the dimensions on the point
+-- x, y, z, intensity, etc -- and if you asked for one of these, it just
+returned it to you directly. The interpretation of those data happened as the
+data were read, and again as the data were written (back into raw bytes).
+libLAS 1.6+ has changed liblas::Point in a number of important ways.
+liblas::Point now only carries along the raw bytes for the point, and if you
+ask for one of the dimensions, it interprets it on-the-fly. For example, a
+GetX() call now requires going into the liblas::Point byte array, pulling the
+first four bytes off of it, asking the point's header for scaling information,
+and rescaling the integer data into double data. If you only call GetX() one
+time, things are roughly equivalent to what we were doing before --
+interpreting and caching interpreted data directly on the liblas::Point -- but
+every one of your subsequent calls to GetX() have this interpretation
+performance hit. You need to cache your calls to interpreted data if you are
+reusing things.  Alternatively, you can control when your data have scaling
+applied by using GetRawX(), which was not possible before libLAS 1.6.
+The rationale for moving to this approach was three-fold. First, the LAS
+committee continually adds new dimensions onto the specification, and I wanted
+an extendable way to add them to libLAS without causing a full re-engineering
+of the liblas::Point class every time they do. Second, liblas::Point now has a
+schema attached to it (based on the list of dimensions that a LAS file's point
+format defines plus any custom dimensions you wish to add to the point
+record). The schema allows you to extend the point format and add your own
+dimensions and it provides generic descriptive information about what exists
+in the file. You can see the description of these schemas in the new
+:ref:`lasinfo <lasinfo>` output from libLAS. Lastly, previous versions of
+libLAS did not allow you to work with raw data, and did not allow the user to
+transform the data (coordinate data, especially) with perfect fidelity. The
+new approach explicitly supports this out-of-the-box. Here's something that is
+now possible with the new (C++) API that was not previously:
+    liblas::Point const& p = reader.GetPoint();
+    std::vector<uint8_t> data = p.GetData();
+    ... // do something with the raw data like stuff it into a database.
+Refactoring of internal Reader and Writer code
+The previous (< libLAS 1.2) C++ reader and writer code of libLAS was a bit
+inflexible, and contained significant duplication for each file format
+version. Giant updates would be required to the code as the ASPRS LAS standard
+committee added new specification versions with new required point formats.
+Additionally, the old code's design was a bit rigid for adding things like
+generic schema support.
+Both the liblas::Reader and liblas::Writer have been significantly `refactored`_
+The reduction in duplication means going to only one place to make changes to
+the code.  In addition to not repeating ourselves, it provides us more
+flexibility to add new features and extensibility to allow the reader and
+writers to be overridden by user code.
+Generic interfaces
+A number of generic interfaces have been added to libLAS to support dynamic
+polymorphism. See <liblas/liblas.hpp> for the C++ interfaces. By implementing
+these interfaces, you can add your own reader/writer implementations as well
+as provide custom filtering and transformation capability.
+Faster binary i/o
+Mateusz Loskot developed a more savvy implementation for its binary i/o which
+provides some significant performance improvements.
+Caching reader
+A reader implementation that provides data caching will be provided at
+libLAS 1.6. If your data reading involves reading the data in multiple passes
+through the file, you can utilize the cached reader to cache the points
+(up to the size of the entire file) for faster repeated and random access.
+Seek support
+It is now possible to seek to a specific point in the file and start reading
+points.  This can significantly speed up the "random sampling" access strategy
+where one starts reading a run of points at a specific location in the file
+and then moves to a different location.
+Classification class
+A class is now provided to abstract the LAS classification value and help
+interpret the bit fields that are present for synthetic, key point, and withheld
+types.
+.. _refactored: http://en.wikipedia.org/wiki/Code_refactoring
+.. _`Oracle Point Cloud`: http://download.oracle.com/docs/cd/B28359_01/appdev.111/b28400/sdo_pc_pkg_ref.htm
+.. _`PDF`: http://liblas.org/pdf/libLAS.pdf
\ No newline at end of file
diff -r 037f40022cf1 -r 08f404fcce59 doc/development/index.txt
--- a/doc/development/index.txt	Tue Dec 21 16:09:42 2010 -0600
+++ b/doc/development/index.txt	Tue Dec 21 21:37:25 2010 -0600
@@ -16,7 +16,9 @@
    source
    format_elements
    Motivation <http://www.youtube.com/watch?v=u6XAPnuFjJc>
+   2010 Annual Report <2010_annual_report>
    Release Plan <release_plan>
    RFCs <rfc/index>
More information about the Liblas-commits mailing list
