[Liblas-commits] hg: add Autzen stadium example for ColorFetchingTransform test
liblas-commits at liblas.org liblas-commits at liblas.org
Wed Dec 22 14:16:47 EST 2010
changeset de68335e5839 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=de68335e5839
summary: add Autzen stadium example for ColorFetchingTransform test
diffstat:
 test/data/autzen.jpg         |    0
 test/data/autzen.jpg.aux.xml |   78 +++++++++++++++++++++++++++++++++++++++++++
 test/data/autzen.las         |    0
 test/data/autzen.wld         |    6 +++
 4 files changed, 84 insertions(+), 0 deletions(-)
diffs (96 lines):
diff -r f419244e89e0 -r de68335e5839 test/data/autzen.jpg
Binary file test/data/autzen.jpg has changed
diff -r f419244e89e0 -r de68335e5839 test/data/autzen.jpg.aux.xml
--- /dev/null	Thu Jan 01 00:00:00 1970 +0000
+++ b/test/data/autzen.jpg.aux.xml	Wed Dec 22 13:16:01 2010 -0600
@@ -0,0 +1,78 @@
+<PAMDataset>
+  <SRS>PROJCS[&quot;NAD_1983_HARN_Lambert_Conformal_Conic&quot;,GEOGCS[&quot;GCS_North_American_1983_HARN&quot;,DATUM[&quot;NAD83_High_Accuracy_Regional_Network&quot;,SPHEROID[&quot;GRS_1980&quot;,6378137,298.257222101,AUTHORITY[&quot;EPSG&quot;,&quot;7019&quot;]],AUTHORITY[&quot;EPSG&quot;,&quot;6152&quot;]],PRIMEM[&quot;Greenwich&quot;,0],UNIT[&quot;degree&quot;,0.0174532925199433]],PROJECTION[&quot;Lambert_Conformal_Conic_2SP&quot;],PARAMETER[&quot;standard_parallel_1&quot;,43],PARAMETER[&quot;standard_parallel_2&quot;,45.5],PARAMETER[&quot;latitude_of_origin&quot;,41.75],PARAMETER[&quot;central_meridian&quot;,-120.5],PARAMETER[&quot;false_easting&quot;,1312335.958005249],PARAMETER[&quot;false_northing&quot;,0],UNIT[&quot;foot&quot;,0.3048,AUTHORITY[&quot;EPSG&quot;,&quot;9002&quot;]]]</SRS>
+  <GeoTransform>  6.3561542786591221e+05,  1.0000000000000000e+00,  0.0000000000000000e+00,  8.5336264308515214e+05,  0.0000000000000000e+00, -1.0000000000000000e+00</GeoTransform>
+  <Metadata domain="IMAGE_STRUCTURE">
+    <MDI key="SOURCE_COLOR_SPACE">YCbCr</MDI>
+    <MDI key="INTERLEAVE">PIXEL</MDI>
+    <MDI key="COMPRESSION">JPEG</MDI>
+  </Metadata>
+  <Metadata>
+    <MDI key="AREA_OR_POINT">Area</MDI>
+  </Metadata>
+  <PAMRasterBand band="1">
+    <NoDataValue>0.00000000000000E+00</NoDataValue>
+    </Metadata>
+    <Metadata>
+      <MDI key="STATISTICS_MINIMUM">35</MDI>
+      <MDI key="STATISTICS_MAXIMUM">255</MDI>
+      <MDI key="STATISTICS_MEAN">123.1901795373</MDI>
+      <MDI key="STATISTICS_MEDIAN">119</MDI>
+      <MDI key="STATISTICS_MODE">76</MDI>
+      <MDI key="STATISTICS_STDDEV">44.35868517657</MDI>
+      <MDI key="STATISTICS_SKIPFACTORX">1</MDI>
+      <MDI key="STATISTICS_SKIPFACTORY">1</MDI>
+      <MDI key="STATISTICS_EXCLUDEDVALUES">0</MDI>
+      <MDI key="LAYER_TYPE">athematic</MDI>
+      <MDI key="STATISTICS_HISTOMIN">0</MDI>
+      <MDI key="STATISTICS_HISTOMAX">255</MDI>
+      <MDI key="STATISTICS_HISTONUMBINS">256</MDI>
+      <MDI key="STATISTICS_HISTOBINVALUES">0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|10|21|9|48|224|385|714|2161|2696|8309|7588|24900|17765|46882|27814|61448|34450|77782|42827|98100|53888|120702|65717|148077|78027|166077|84982|174335|89293|177578|90284|180801|93282|190772|101305|210012|115008|243452|135342|284901|148646|302429|148077|298916|144663|280671|134631|256550|120687|215877|108429|202384|104044|203128|102544|206102|105665|201844|103450|193536|102048|192415|101363|190038|101032|187723|100567|193052|99056|191287|100172|189280|100253|186837|99461|187243|100909|185404|96993|183586|96104|176573|91790|168839|88982|166059|86900|166371|87517|167845|88868|166145|85664|166215|87199|164880|84095|164916|86545|165768|87217|167923|87838|168648|87993|172725|90702|173439|92908|174261|91964|175322|90662|175603|91250|175172|89252|168701|86713|171786|89970|175836|91456|173171|90740|174845|92033|175217|91075|180195|93067|183314|95883|184932|94949|185701|96018
 |190825|98995|201777|102195|206910|105152|204126|98577|182425|83535|154042|71125|131076|61583|108842|52470|93858|46701|82533|40238|71499|35254|60535|31174|54041|27046|46217|23192|40760|21504|35811|19297|32132|16929|29471|15875|26553|14795|25450|15184|26335|15298|27888|15328|28723|16319|30614|16239|32032|17502|32144|17640|31247|16786|27753|13451|22024|10148|16089|7716|12861|6317|13674|7537|14457|6305|12395|5855|11472|4038|6186|2813|5086|2912|7510|4317|8871|3493|4621|1494|1728|610|386|468|</MDI>
+    </Metadata>
+  </PAMRasterBand>
+  <PAMRasterBand band="2">
+    </Metadata>
+    <Metadata>
+      <MDI key="STATISTICS_MINIMUM">49</MDI>
+      <MDI key="STATISTICS_MEAN">126.93814343797</MDI>
+      <MDI key="STATISTICS_MEDIAN">128</MDI>
+      <MDI key="STATISTICS_MODE">138</MDI>
+      <MDI key="STATISTICS_STDDEV">35.775545093364</MDI>
+      <MDI key="STATISTICS_HISTOBINVALUES">0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|18|9|28|44|153|455|649|1909|2802|9343|8425|25725|18685|48050|28223|67362|37470|82241|45761|101584|55711|126075|68487|152172|84794|185524|96559|202617|102919|207709|107658|221607|112434|225654|114200|226284|117806|236558|121474|249767|133466|279408|147634|311941|156605|304328|144515|265805|128428|242913|119590|220174|109344|197377|98997|179184|93175|170933|90611|173631|93411|175426|97490|192322|107014|211156|117797|230545|123482|237845|125043|239649|124347|240428|123593|237589|127948|242878|129053|249688|134057|262793|141319|273910|145203|293016|155054|304156|160249|314311|161814|312308|160454|308648|155976|298196|153161|285765|143846|280226|140683|269363|135636|260773|133749|256619|130225|251022|126654|236668|122231|234878|118759|243566|123416|244800|121230|235098|109441|195277|88475|154991|68581|120307|55513|97517|45947|81705|40212|690
 70|33767|57270|30034|49877|25261|41621|22384|38164|19332|31686|17072|29268|16329|26848|15437|23774|13766|23130|12871|21305|12017|20269|12036|22952|12587|22703|13543|23212|13555|23875|13710|24546|13690|24291|13374|24922|13991|26470|14345|29125|16765|31059|16335|26956|13871|26177|13426|21748|10943|16192|7825|11009|5179|7879|3754|7214|4319|7511|4141|7849|3626|8161|3991|8099|3718|6940|2939|4239|1951|3804|2771|9166|2689|4483|1619|1505|264|</MDI>
+    </Metadata>
+  </PAMRasterBand>
+  <PAMRasterBand band="3">
+    </Metadata>
+    <Metadata>
+      <MDI key="STATISTICS_MINIMUM">46</MDI>
+      <MDI key="STATISTICS_MEAN">112.16139266402</MDI>
+      <MDI key="STATISTICS_MEDIAN">106</MDI>
+      <MDI key="STATISTICS_MODE">96</MDI>
+      <MDI key="STATISTICS_STDDEV">30.726139906689</MDI>
+      <MDI key="STATISTICS_HISTOBINVALUES">0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|0|9|0|16|69|70|103|397|270|819|995|2190|2835|5936|6759|14962|13403|33486|26770|62511|42952|103342|61300|133575|72938|152680|81852|162560|91043|186667|107722|228069|130398|285507|158372|341260|183090|377369|198397|410282|208868|420529|209239|415785|207731|406405|204345|410580|211696|418652|216557|426333|212853|412247|202892|401270|199707|386659|197533|378993|196369|383642|193058|377743|188743|356527|180138|336117|165578|304889|152009|275527|142388|260312|133446|244782|130177|244735|128582|249357|131526|254492|132798|260627|132172|257483|130976|246435|124768|236203|119417|222765|111785|211513|104362|195253|97881|189364|95559|185934|94344|189684|95302|189376|91534|177018|79731|142584|63351|110873|50137|84781|40970|68491|33129|57178|28200|46810|24555|40193|20759|34577|19461|32213|17444|27783|15196|24679|14209|22635|13543|21053|11986|20092|11628|185
 64|12278|19894|10789|18339|11260|19955|11417|19998|12017|21206|11668|19712|11755|19141|11663|21530|12098|22059|12146|22022|13077|22079|12762|23450|12408|24186|13515|24601|12207|23662|12318|21238|10667|17363|8261|14042|7485|11903|6368|11092|5159|8432|3673|5881|3025|4973|2861|5895|2868|5822|2978|5992|3065|7216|3293|7284|3476|6987|2735|5848|2177|3560|1997|3232|1548|4070|2396|6362|1877|2645|425|295|41|30|9|</MDI>
+    </Metadata>
+  </PAMRasterBand>
+</PAMDataset>
diff -r f419244e89e0 -r de68335e5839 test/data/autzen.las
Binary file test/data/autzen.las has changed
diff -r f419244e89e0 -r de68335e5839 test/data/autzen.wld
+++ b/test/data/autzen.wld	Wed Dec 22 13:16:01 2010 -0600
@@ -0,0 +1,6 @@
+1.0000000000
+0.0000000000
+0.0000000000
+-1.0000000000
+635615.9278659122
+853362.1430851521
More information about the Liblas-commits mailing list
