[Liblas-commits] hg: 2 new changesets
liblas-commits at liblas.org liblas-commits at liblas.org
Wed Dec 22 16:05:02 EST 2010
changeset 3c0b0cf20bca in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=3c0b0cf20bca
summary: rename include files
changeset 41a8066d9663 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=41a8066d9663
summary: merge
diffstat:
 apps/las2las.cpp                            |   26 +-
 apps/lasindex_test.cpp                      |    2 +-
 apps/laskernel.cpp                          |    3 +-
 include/liblas/bounds.hpp                   |  599 ++++++++++++++++++++++++++++
 include/liblas/classification.hpp           |  244 +++++++++++
 include/liblas/color.hpp                    |  170 +++++++
 include/liblas/detail/index/indexoutput.hpp |    2 +-
 include/liblas/detail/reader/header.hpp     |    6 +-
 include/liblas/detail/reader/reader.hpp     |    1 -
 include/liblas/detail/reader/zipreader.hpp  |    3 -
 include/liblas/detail/writer/base.hpp       |    2 +-
 include/liblas/detail/writer/header.hpp     |    2 +-
 include/liblas/detail/writer/point.hpp      |    6 +-
 include/liblas/dimension.hpp                |  243 +++++++++++
 include/liblas/error.hpp                    |   90 ++++
 include/liblas/factory.hpp                  |   18 +-
 include/liblas/filter.hpp                   |  396 ++++++++++++++++++
 include/liblas/header.hpp                   |  445 ++++++++++++++++++++
 include/liblas/index.hpp                    |  571 ++++++++++++++++++++++++++
 include/liblas/iterator.hpp                 |    6 +-
 include/liblas/lasbounds.hpp                |  599 ----------------------------
 include/liblas/lasclassification.hpp        |  244 -----------
 include/liblas/lascolor.hpp                 |  170 -------
 include/liblas/lasdimension.hpp             |  243 -----------
 include/liblas/laserror.hpp                 |   90 ----
 include/liblas/lasfilter.hpp                |  396 ------------------
 include/liblas/lasheader.hpp                |  445 --------------------
 include/liblas/lasindex.hpp                 |  571 --------------------------
 include/liblas/laspoint.hpp                 |  253 -----------
 include/liblas/lasreader.hpp                |  152 -------
 include/liblas/lasschema.hpp                |  180 --------
 include/liblas/lasspatialreference.hpp      |  212 ---------
 include/liblas/lastransform.hpp             |  215 ----------
 include/liblas/lasvariablerecord.hpp        |  160 -------
 include/liblas/lasversion.hpp               |  101 ----
 include/liblas/laswriter.hpp                |  116 -----
 include/liblas/liblas.hpp                   |   28 +-
 include/liblas/point.hpp                    |  253 +++++++++++
 include/liblas/reader.hpp                   |  152 +++++++
 include/liblas/schema.hpp                   |  179 ++++++++
 include/liblas/spatialreference.hpp         |  212 +++++++++
 include/liblas/transform.hpp                |  215 ++++++++++
 include/liblas/utility.hpp                  |    4 +-
 include/liblas/variablerecord.hpp           |  160 +++++++
 include/liblas/version.hpp                  |   56 ++
 include/liblas/writer.hpp                   |  116 +++++
 src/CMakeLists.txt                          |   31 +-
 src/detail/reader/cachedreader.cpp          |    2 -
 src/detail/reader/header.cpp                |    7 +-
 src/detail/reader/reader.cpp                |    2 -
 src/detail/reader/zipreader.cpp             |   16 +-
 src/detail/writer/header.cpp                |    6 +-
 src/detail/writer/point.cpp                 |    6 +-
 src/detail/writer/writer.cpp                |    2 -
 src/detail/writer/zipwriter.cpp             |   16 +-
 src/factory.cpp                             |   51 +-
 src/las_c_api.cpp                           |   12 +-
 src/lasclassification.cpp                   |    2 +-
 src/lascolor.cpp                            |    2 +-
 src/lasdimension.cpp                        |    2 +-
 src/laserror.cpp                            |    2 +-
 src/lasfilter.cpp                           |    4 +-
 src/lasheader.cpp                           |    6 +-
 src/lasindex.cpp                            |    4 +-
 src/laspoint.cpp                            |    6 +-
 src/lasreader.cpp                           |    4 +-
 src/lasschema.cpp                           |    2 +-
 src/lasspatialreference.cpp                 |    2 +-
 src/lastransform.cpp                        |    4 +-
 src/lasvariablerecord.cpp                   |    2 +-
 src/lasversion.cpp                          |    4 +-
 src/laswriter.cpp                           |    6 +-
 test/unit/bounds_test.cpp                   |    2 +-
 test/unit/classification_test.cpp           |    2 +-
 test/unit/common.cpp                        |    2 +-
 test/unit/common.hpp                        |    2 -
 test/unit/error_test.cpp                    |    2 +-
 test/unit/header_test.cpp                   |    3 -
 test/unit/point_test.cpp                    |   11 +-
 test/unit/reader_iterator_test.cpp          |    3 -
 test/unit/reader_test.cpp                   |    4 +-
 test/unit/transform_test.cpp                |    2 +-
 test/unit/variablerecord_test.cpp           |    1 -
 test/unit/writer_test.cpp                   |    6 +-
 84 files changed, 4282 insertions(+), 4318 deletions(-)
diffs (truncated from 9394 to 300 lines):
diff -r 3f63ce4340f0 -r 41a8066d9663 apps/las2las.cpp
--- a/apps/las2las.cpp	Wed Dec 22 13:41:27 2010 -0600
+++ b/apps/las2las.cpp	Wed Dec 22 15:04:51 2010 -0600
@@ -324,15 +324,23 @@
         // Transforms alter our header as well.  Setting scales, offsets, etc.
         transforms = GetTransforms(vm, verbose, header);
-        // This is quite busted for me on OS X...
-//         if (output.compare(output.length()-4,4,".laz")==0)
-// #ifdef HAVE_LASZIP
-//             header.SetIsCompressed(true);
-// #else
-//             throw std::runtime_error("Compression support not enabled in liblas configuration");
-// #endif
+        switch (WriterFactory::InferFileTypeFromExtension(output))
+        case WriterFactory::FileType_LAS:
+            header.SetIsCompressed(false);
+            break;
+        case WriterFactory::FileType_LAZ:
+#ifdef HAVE_LASZIP
+            header.SetIsCompressed(true);
+#else
+            throw std::runtime_error("Compression support not enabled in liblas configuration");
+#endif
+            break;
+        case WriterFactory::FileType_Unknown:
+        default:
+            throw std::runtime_error("Unknown output file type");
+            break;
         bool op = process(  input,
                             output,
diff -r 3f63ce4340f0 -r 41a8066d9663 apps/lasindex_test.cpp
--- a/apps/lasindex_test.cpp	Wed Dec 22 13:41:27 2010 -0600
+++ b/apps/lasindex_test.cpp	Wed Dec 22 15:04:51 2010 -0600
@@ -17,7 +17,7 @@
 #include <typeinfo>
 #include <vector>
-#include <liblas/lasindex.hpp>
+#include <liblas/index.hpp>
 using namespace liblas;
 using namespace boost;
diff -r 3f63ce4340f0 -r 41a8066d9663 apps/laskernel.cpp
--- a/apps/laskernel.cpp	Wed Dec 22 13:41:27 2010 -0600
+++ b/apps/laskernel.cpp	Wed Dec 22 15:04:51 2010 -0600
@@ -111,7 +111,8 @@
         oss << "Cannot open " << filename << "for read.  Exiting...";
         throw std::runtime_error(oss.str());
-    liblas::Reader reader(ifs);
+    liblas::ReaderFactory factory;
+    liblas::Reader reader = factory.CreateWithStream(ifs);
     liblas::Header header = reader.GetHeader();
     ifs.close();
     return header;
diff -r 3f63ce4340f0 -r 41a8066d9663 include/liblas/bounds.hpp
--- /dev/null	Thu Jan 01 00:00:00 1970 +0000
+++ b/include/liblas/bounds.hpp	Wed Dec 22 15:04:51 2010 -0600
@@ -0,0 +1,599 @@
+ * $Id$
+ * Project:  libLAS - http://liblas.org - A BSD library for LAS format data.
+ * Purpose:  LAS bounds class
+ * Author:   Howard Butler, hobu.inc at gmail.com
+ * Copyright (c) 2010, Howard Butler
+ * All rights reserved.
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following
+ * conditions are met:
+ *     * Redistributions of source code must retain the above copyright
+ *       notice, this list of conditions and the following disclaimer.
+ *     * Redistributions in binary form must reproduce the above copyright
+ *       notice, this list of conditions and the following disclaimer in
+ *       the documentation and/or other materials provided
+ *       with the distribution.
+ *     * Neither the name of the Martin Isenburg or Iowa Department
+ *       of Natural Resources nor the names of its contributors may be
+ *       used to endorse or promote products derived from this software
+ *       without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+ * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+ * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
+ * FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
+ * COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
+ * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
+ * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
+ * OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
+ * AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+ * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+ * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
+ * OF SUCH DAMAGE.
+#ifndef LIBLAS_LASBOUNDS_HPP_INCLUDED
+#define LIBLAS_LASBOUNDS_HPP_INCLUDED
+#include <liblas/detail/fwd.hpp>
+#include <liblas/point.hpp>
+#include <liblas/transform.hpp>
+#include <liblas/detail/private_utility.hpp>
+#include <liblas/export.hpp>
+// boost
+#include <boost/cstdint.hpp>
+#include <boost/concept_check.hpp>
+// std
+#include <cmath>
+#include <limits>
+#include <string>
+#include <sstream>
+#include <vector>
+namespace liblas {
+template <typename T>
+class LAS_DLL Range
+public:
+    T min;
+    T max;
+	typedef T value_type;
+    Range(T mmin=std::numeric_limits<T>::max(), T mmax=std::numeric_limits<T>::min())
+        : min(mmin), max(mmax) {}
+    Range(Range const& other)
+        : min(other.min)
+        , max(other.max)
+    Range& operator=(Range<T> const& rhs)
+        if (&rhs != this)
+            min = rhs.min;
+            max = rhs.max;
+        return *this;
+    bool operator==(Range<T> const& rhs) const
+        return equal(rhs);
+    bool operator!=(Range const& rhs) const
+        return !(equal(rhs));
+    bool equal(Range const& other) const
+        if    (!(detail::compare_distance(min, other.min))
+            || !(detail::compare_distance(max, other.max)))
+            return false;
+        return true;
+    bool overlaps(Range const& r) const
+        return min <= r.max && max >= r.min;
+    bool contains(Range const& r) const
+        return min <= r.min && r.max <= max;
+    bool contains(T v) const
+        return min <= v && v <= max;
+    bool empty(void) const
+        return detail::compare_distance(min, std::numeric_limits<T>::max()) && detail::compare_distance(max, std::numeric_limits<T>::min());
+    void shift(T v)
+        min += v;
+        max += v;
+    void scale(T v)
+        min *= v;
+        max *= v;
+    void clip(Range const& r)
+        if (r.min > min)
+            min = r.min;
+        if (r.max < max)
+            max = r.max;
+    void grow(T v)
+        if (v < min)
+            min = v;
+        if (v > max)
+            max = v;
+    void grow(Range const& r)
+        grow(r.min);
+        grow(r.max);
+    T length() const
+        return max - min;
+class Bounds
+public:
+    typedef typename std::vector< Range<T> >::size_type size_type;
+    typedef typename std::vector< Range<T> > RangeVec;
+private:
+    RangeVec ranges;
+public:
+Bounds<T>()
+    ranges.resize(0);
+Bounds(Bounds const& other)
+    ranges(other.ranges)
+Bounds(RangeVec const& rngs)
+    ranges(rngs)
+Bounds( T minx,
+        T miny,
+        T minz,
+        T maxx,
+        T maxy,
+        T maxz)
+    ranges.resize(3);
+    ranges[0].min = minx;
+    ranges[1].min = miny;
+    ranges[2].min = minz;
+    ranges[0].max = maxx;
+    ranges[1].max = maxy;
+    ranges[2].max = maxz;
+#ifdef DEBUG
+    verify();
+#endif
+Bounds( T minx,
+        T miny,
+        T maxx,
+        T maxy)
More information about the Liblas-commits mailing list
