[Liblas-commits] hg: rename source files to remove las prefix
liblas-commits at liblas.org liblas-commits at liblas.org
Wed Dec 22 16:10:22 EST 2010
changeset 4efff1e8affd in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=4efff1e8affd
summary: rename source files to remove las prefix
diffstat:
 src/CMakeLists.txt          |    32 +-
 src/c_api.cpp               |  2129 ++++++++++++++++++++++++++++++++++++++++++
 src/classification.cpp      |   143 ++
 src/color.cpp               |    99 +
 src/dimension.cpp           |   199 +++
 src/error.cpp               |    77 +
 src/filter.cpp              |   253 +++++
 src/header.cpp              |   925 ++++++++++++++++++
 src/index.cpp               |  2156 +++++++++++++++++++++++++++++++++++++++++++
 src/las_c_api.cpp           |  2129 ------------------------------------------
 src/lasclassification.cpp   |   143 --
 src/lascolor.cpp            |    99 -
 src/lasdimension.cpp        |   199 ---
 src/laserror.cpp            |    77 -
 src/lasfilter.cpp           |   253 -----
 src/lasheader.cpp           |   925 ------------------
 src/lasindex.cpp            |  2156 -------------------------------------------
 src/laspoint.cpp            |   953 -------------------
 src/lasreader.cpp           |   197 ---
 src/lasschema.cpp           |   778 ---------------
 src/lasspatialreference.cpp |   871 -----------------
 src/lastransform.cpp        |   531 ----------
 src/lasvariablerecord.cpp   |   246 ----
 src/lasversion.cpp          |   134 --
 src/laswriter.cpp           |   126 --
 src/point.cpp               |   953 +++++++++++++++++++
 src/reader.cpp              |   197 +++
 src/schema.cpp              |   778 +++++++++++++++
 src/spatialreference.cpp    |   871 +++++++++++++++++
 src/transform.cpp           |   531 ++++++++++
 src/variablerecord.cpp      |   246 ++++
 src/version.cpp             |   134 ++
 src/writer.cpp              |   126 ++
 33 files changed, 9833 insertions(+), 9833 deletions(-)
diffs (truncated from 19812 to 300 lines):
diff -r 41a8066d9663 -r 4efff1e8affd src/CMakeLists.txt
--- a/src/CMakeLists.txt	Wed Dec 22 15:04:51 2010 -0600
+++ b/src/CMakeLists.txt	Wed Dec 22 15:10:15 2010 -0600
@@ -111,22 +111,22 @@
 set(LIBLAS_CPP
   chipper.cpp
   factory.cpp
-  lasclassification.cpp
-  lascolor.cpp
-  lasdimension.cpp
-  laserror.cpp
-  lasfilter.cpp
-  lasheader.cpp
-  lasindex.cpp
-  laspoint.cpp
-  lasreader.cpp
-  lasspatialreference.cpp
-  lasschema.cpp
-  lastransform.cpp
+  classification.cpp
+  color.cpp
+  dimension.cpp
+  error.cpp
+  filter.cpp
+  header.cpp
+  index.cpp
+  point.cpp
+  reader.cpp
+  spatialreference.cpp
+  schema.cpp
+  transform.cpp
   utility.cpp
-  lasvariablerecord.cpp
-  laswriter.cpp
-  lasversion.cpp)
+  variablerecord.cpp
+  writer.cpp
+  version.cpp)
 set(LIBLAS_DETAIL_CPP
   detail/utility.cpp)
@@ -200,7 +200,7 @@
   ${LIBLAS_HEADERS_DIR}/capi/las_config.h
   ${LIBLAS_HEADERS_DIR}/capi/las_version.h
   ${LIBLAS_HEADERS_DIR}/capi/liblas.h
-  las_c_api.cpp)
+  c_api.cpp)
 # NOTE:
 # This hack is required to correctly link static into shared library.
diff -r 41a8066d9663 -r 4efff1e8affd src/c_api.cpp
--- /dev/null	Thu Jan 01 00:00:00 1970 +0000
+++ b/src/c_api.cpp	Wed Dec 22 15:10:15 2010 -0600
@@ -0,0 +1,2129 @@
+ * $Id$
+ * Project:  libLAS - http://liblas.org - A BSD library for LAS format data.
+ * Purpose:  C API for libLAS
+ * Author:   Howard Butler, hobu.inc at gmail.com, but I'm not proud of it.
+ *           I also swiped a lot of it from GDAL.
+ * Copyright (c) 2008, Mateusz Loskot
+ * Copyright (c) 2008, Howard Butler
+ * All rights reserved.
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following
+ * conditions are met:
+ *     * Redistributions of source code must retain the above copyright
+ *       notice, this list of conditions and the following disclaimer.
+ *     * Redistributions in binary form must reproduce the above copyright
+ *       notice, this list of conditions and the following disclaimer in
+ *       the documentation and/or other materials provided
+ *       with the distribution.
+ *     * Neither the name of the Martin Isenburg or Iowa Department
+ *       of Natural Resources nor the names of its contributors may be
+ *       used to endorse or promote products derived from this software
+ *       without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+ * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+ * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
+ * FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
+ * COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
+ * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
+ * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
+ * OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
+ * AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+ * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+ * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
+ * OF SUCH DAMAGE.
+#ifdef HAVE_LIBGEOTIFF
+// Supress inclusion of cpl_serv.h per #194, perhaps remove one day
+// when libgeotiff 1.4.0+ is widely used
+#define CPL_SERV_H_INCLUDED
+#include <geotiff.h>
+#include <geo_simpletags.h>
+#include <geo_normalize.h>
+#endif
+#include <liblas/liblas.hpp>
+typedef struct LASWriterHS *LASWriterH;
+typedef struct LASReaderHS *LASReaderH;
+typedef struct LASPointHS *LASPointH;
+typedef struct LASHeaderHS *LASHeaderH;
+typedef struct LASGuidHS *LASGuidH;
+typedef struct LASVLRHS *LASVLRH;
+typedef struct LASColorHS *LASColorH;
+typedef struct LASSRSHS *LASSRSH;
+typedef struct LASSchemaHS *LASSchemaH;
+// boost
+#include <boost/cstdint.hpp>
+// std
+#include <cstdio>
+#include <bitset>
+#include <exception>
+#include <fstream>
+#include <iostream>
+#include <map>
+#include <sstream> // std::stringstream
+#include <string>
+#include <stack>
+#include <typeinfo>
+#include <vector>
+using namespace liblas;
+#ifdef _WIN32
+#define compare_no_case(a,b,n)  _strnicmp( (a), (b), (n) )
+#else
+#define compare_no_case(a,b,n)  strncasecmp( (a), (b), (n) )
+#endif
+std::istream* OpenInput(std::string filename)
+    std::ios::openmode const mode = std::ios::in | std::ios::binary;
+    std::istream* istrm = 0;
+    if (compare_no_case(filename.c_str(),"STDIN",5) == 0)
+        istrm = &std::cin;
+    else
+        istrm = new std::ifstream(filename.c_str(), mode);
+    if (!istrm->good())
+        delete istrm;
+        throw std::runtime_error("Reading stream was not able to be created");
+    return istrm;
+LAS_C_START
+#ifndef _WIN32
+#include <stdint.h>
+#endif
+// Error stuff
+typedef enum
+    LE_None = 0,
+    LE_Debug = 1,
+    LE_Warning = 2,
+    LE_Failure = 3,
+    LE_Fatal = 4
+} LASErrorEnum;
+static std::stack<liblas::Error > errors;
+static std::map<liblas::Reader*, std::istream*> readers;
+static std::map<liblas::Writer*, std::ostream*> writers;
+#ifdef _MSC_VER
+# pragma warning(disable: 4127) // warning C4127: conditional expression is constant
+#endif
+#define VALIDATE_LAS_POINTER0(ptr, func) \
+   do { if( NULL == ptr ) { \
+        LASErrorEnum const ret = LE_Failure; \
+        std::ostringstream msg; \
+        msg << "Pointer \'" << #ptr << "\' is NULL in \'" << (func) <<"\'."; \
+        std::string message(msg.str()); \
+        LASError_PushError( ret, message.c_str(), (func)); \
+        return; \
+   }} while(0)
+#define VALIDATE_LAS_POINTER1(ptr, func, rc) \
+        return (rc); \
+   }} while(0)
+LAS_DLL int LAS_IsGDALEnabled(void) {
+    return IsGDALEnabled();
+LAS_DLL int LAS_IsLibGeoTIFFEnabled(void) {
+    return IsLibGeoTIFFEnabled();
+LAS_DLL void LASError_Reset(void) {
+    if (errors.empty()) return;
+    for (std::size_t i=0;i<errors.size();i++) errors.pop();
+LAS_DLL void LASError_Pop(void) {
+    errors.pop();
+LAS_DLL int LASError_GetLastErrorNum(void){
+        return 0;
+    else {
+        liblas::Error err = errors.top();
+        return err.GetCode();
+LAS_DLL char* LASError_GetLastErrorMsg(void){
+        return NULL;
+    else {
+        return LASCopyString(err.GetMessage().c_str());
+LAS_DLL char* LASError_GetLastErrorMethod(void){
+        return NULL;
+    else {
+        return LASCopyString(err.GetMethod().c_str());
+LAS_DLL void LASError_PushError(int code, const char *message, const char *method) {
+    liblas::Error err = liblas::Error(code, std::string(message), std::string(method));
+    errors.push(err);
+LAS_DLL int LASError_GetErrorCount(void) {
+    return static_cast<int>(errors.size());
+LAS_DLL LASReaderH LASReader_Create(const char* filename)
+    VALIDATE_LAS_POINTER1(filename, "LASReader_Create", NULL);
+    try {
+        std::istream* istrm = OpenInput(std::string(filename));
+        liblas::Reader* reader = new liblas::Reader(*istrm);
+        readers.insert(std::pair<liblas::Reader*, std::istream*>(reader, istrm));
+        return (LASReaderH) reader;
+    } catch (std::exception const& e)
+         LASError_PushError(LE_Failure, e.what(), "LASReader_Create");
+         return NULL;
+LAS_DLL LASReaderH LASReader_CreateWithHeader(  const char* filename,
+                                                LASHeaderH hHeader)
+    VALIDATE_LAS_POINTER1(filename, "LASReader_CreateWithHeader", NULL);
+    VALIDATE_LAS_POINTER1(hHeader, "LASReader_CreateWithHeader", NULL);
+    try {
More information about the Liblas-commits mailing list
