[Liblas-commits] laszip: added test for new WAVEPACKET13 compressor
liblas-commits at liblas.org
Thu Dec 23 09:02:41 EST 2010
changeset 30313ba06a38 in /Volumes/Data/www/liblas.org/laszip
details: http://hg.liblas.orglaszip?cmd=changeset;node=30313ba06a38
summary: added test for new WAVEPACKET13 compressor
diffstat:
tools/laszippertest.cpp | 120 +++++++++++++++++++++--------------------------
1 files changed, 54 insertions(+), 66 deletions(-)
diffs (294 lines):
diff -r 7770fdf9c7c2 -r 30313ba06a38 tools/laszippertest.cpp
--- a/tools/laszippertest.cpp Thu Dec 23 05:45:46 2010 -0800
+++ b/tools/laszippertest.cpp Thu Dec 23 06:02:14 2010 -0800
@@ -49,11 +49,11 @@
#include "lasunzipper.hpp"
#ifdef LZ_WIN32_VC6
- #include <fstream.h>
+#include <fstream.h>
#else
- #include <istream>
- #include <fstream>
- using namespace std;
+#include <istream>
+#include <fstream>
+using namespace std;
#endif
#include <time.h>
@@ -68,49 +68,43 @@
unsigned char c;
unsigned int i, j;
- unsigned int num_points = 1000000;
+ unsigned int num_points = 100000;
unsigned int num_errors, num_bytes;
+ double start_time, end_time;
+ FILE* ofile1 = 0;
+ FILE* ofile2 = 0;
+ FILE* ofile3 = 0;
+ FILE* ifile1 = 0;
+ FILE* ifile2 = 0;
+ FILE* ifile3 = 0;
filebuf ofb1;
filebuf ofb2;
filebuf ofb3;
+ filebuf ifb1;
+ filebuf ifb2;
+ filebuf ifb3;
#ifdef LZ_WIN32_VC6
ostream* ostream1 = 0;
ostream* ostream2 = 0;
ostream* ostream3 = 0;
istream* istream1 = 0;
istream* istream2 = 0;
- istream* istream3 = 0;
+ istream* istream3 = 0;
#else
ofstream* ostream1 = 0;
ofstream* ostream2 = 0;
ofstream* ostream3 = 0;
ifstream* istream1 = 0;
ifstream* istream2 = 0;
- ifstream* istream3 = 0;
-#endif
+ ifstream* istream3 = 0;
+#endif
- FILE* ofile1 = 0;
- FILE* ofile2 = 0;
- FILE* ofile3 = 0;
- filebuf ifb1;
- filebuf ifb2;
- filebuf ifb3;
- FILE* ifile1 = 0;
- FILE* ifile2 = 0;
- FILE* ifile3 = 0;
- double start_time, end_time;
- bool use_iostream = true;
+ bool use_iostream = false;
// describe the point structure
- unsigned int num_items = 4;
- LASitem items[4];
+ unsigned int num_items = 5;
+ LASitem items[5];
items[0].type = LASitem::POINT10;
items[0].size = 20;
@@ -124,10 +118,14 @@
items[2].size = 6;
items[2].version = 0;
- items[3].type = LASitem::BYTE;
- items[3].size = 7;
+ items[3].type = LASitem::WAVEPACKET13;
+ items[3].size = 29;
items[3].version = 0;
+ items[4].type = LASitem::BYTE;
+ items[4].size = 7;
+ items[4].version = 0;
// compute the point size
unsigned int point_size = 0;
for (i = 0; i < num_items; i++) point_size += items[i].size;
@@ -148,49 +146,42 @@
if (use_iostream)
-#ifdef LZ_WIN32_VC6
+#ifdef LZ_WIN32_VC6
ofb1.open("test1.lax", ios::out);
ofb1.setmode(filebuf::binary);
ostream1 = new ostream(&ofb1);
#else
ostream1 = new ofstream();
ostream1->open("test1.lax", std::ios::out | std::ios::binary );
-#endif
+#endif
if (laszipper1->open(*ostream1, num_items, items, LASZIP_COMPRESSION_NONE) != 0)
fprintf(stderr, "ERROR: could not open laszipper1\n");
return 0;
ofb2.open("test2.lax", ios::out);
ofb2.setmode(filebuf::binary);
ostream2 = new ostream(&ofb2);
#else
ostream2 = new ofstream();
ostream2->open("test2.lax", std::ios::out | std::ios::binary );
-#endif
+#endif
if (laszipper2->open(*ostream2, num_items, items, LASZIP_COMPRESSION_ARITHMETIC) != 0)
fprintf(stderr, "ERROR: could not open laszipper2\n");
return 0;
ofb3.open("test3.lax", ios::out);
ofb3.setmode(filebuf::binary);
ostream3 = new ostream(&ofb3);
#else
ostream3 = new ofstream();
ostream3->open("test3.lax", std::ios::out | std::ios::binary );
-#endif
+#endif
if (laszipper3->open(*ostream3, num_items, items, LASZIP_COMPRESSION_RANGE) != 0)
fprintf(stderr, "ERROR: could not open laszipper3\n");
@@ -200,21 +191,21 @@
else
ofile1 = fopen("test1.lax", "wb");
- if (laszipper1->open(ofile1, num_items, items, LASZIP_COMPRESSION_NONE) != 0)
+ if (!laszipper1->open(ofile1, num_items, items, LASZIP_COMPRESSION_NONE))
return 0;
ofile2 = fopen("test2.lax", "wb");
- if (laszipper2->open(ofile2, num_items, items, LASZIP_COMPRESSION_ARITHMETIC) != 0)
+ if (!laszipper2->open(ofile2, num_items, items, LASZIP_COMPRESSION_ARITHMETIC))
return 0;
ofile3 = fopen("test3.lax", "wb");
- if (laszipper3->open(ofile3, num_items, items, LASZIP_COMPRESSION_RANGE) != 0)
+ if (!laszipper3->open(ofile3, num_items, items, LASZIP_COMPRESSION_RANGE))
return 0;
@@ -277,9 +268,11 @@
delete ostream1;
delete ostream2;
delete ostream3;
ofb1.close();
ofb2.close();
ofb3.close();
+#endif
else
@@ -294,48 +287,41 @@
if (use_iostream)
ifb1.open("test1.lax", ios::in);
ifb1.setmode(filebuf::binary);
istream1 = new istream(&ifb1);
#else
istream1 = new ifstream();
- istream1->open("test1.lax", std::ios::in | std::ios::binary );
+ istream1->open("test1.lax", std::ios::in | std::ios::binary );
#endif
if (lasunzipper1->open(*istream1, num_items, items, LASZIP_COMPRESSION_NONE) != 0)
fprintf(stderr, "ERROR: could not open lasunzipper1\n");
return 0;
ifb2.open("test2.lax", ios::in);
ifb2.setmode(filebuf::binary);
istream2 = new istream(&ifb2);
#else
istream2 = new ifstream();
- istream2->open("test2.lax", std::ios::in | std::ios::binary );
+ istream2->open("test2.lax", std::ios::in | std::ios::binary );
#endif
- if (lasunzipper2->open(*istream2, num_items, items, LASZIP_COMPRESSION_ARITHMETIC) != 0)
+ if (lasunzipper2->open(istream2, num_items, items, LASZIP_COMPRESSION_ARITHMETIC) != 0)
fprintf(stderr, "ERROR: could not open lasunzipper2\n");
return 0;
ifb3.open("test3.lax", ios::in);
ifb3.setmode(filebuf::binary);
istream3 = new istream(&ifb3);
#else
istream3 = new ifstream();
- istream3->open("test3.lax", std::ios::in | std::ios::binary );
+ istream3->open("test3.lax", std::ios::in | std::ios::binary );
#endif
- if (lasunzipper3->open(*istream3, num_items, items, LASZIP_COMPRESSION_RANGE) != 0)
+ if (lasunzipper3->open(istream3, num_items, items, LASZIP_COMPRESSION_RANGE) != 0)
fprintf(stderr, "ERROR: could not open lasunzipper3\n");
return 0;
@@ -344,19 +330,19 @@
else
ifile1 = fopen("test1.lax", "rb");
- if (lasunzipper1->open(ifile1, num_items, items, LASZIP_COMPRESSION_NONE) != 0)
+ if (!lasunzipper1->open(ifile1, num_items, items, LASZIP_COMPRESSION_NONE))
return 0;
ifile2 = fopen("test2.lax", "rb");
- if (lasunzipper2->open(ifile2, num_items, items, LASZIP_COMPRESSION_ARITHMETIC) != 0)
+ if (!lasunzipper2->open(ifile2, num_items, items, LASZIP_COMPRESSION_ARITHMETIC))
return 0;
ifile3 = fopen("test3.lax", "rb");
- if (lasunzipper3->open(ifile3, num_items, items, LASZIP_COMPRESSION_RANGE) != 0)
+ if (!lasunzipper3->open(ifile3, num_items, items, LASZIP_COMPRESSION_RANGE))
return 0;
@@ -459,12 +445,14 @@
if (use_iostream)
+ delete istream1;
+ delete istream2;
+ delete istream3;
ifb1.close();
ifb2.close();
ifb3.close();
- delete istream1;
- delete istream2;
- delete istream3;
+#endif
else
More information about the Liblas-commits
