[Liblas-commits] laszip: fix of pointreader and small optimization of POINT10 com...
liblas-commits at liblas.org liblas-commits at liblas.org
Thu Dec 23 13:11:29 EST 2010
changeset 113c76a6708b in /Volumes/Data/www/liblas.org/laszip
details: http://hg.liblas.orglaszip?cmd=changeset;node=113c76a6708b
summary: fix of pointreader and small optimization of POINT10 compressor
diffstat:
 src/lasreaditemcompressed_v1.cpp  |  72 +++++++++++++++++---------------------
 src/lasreaditemcompressed_v1.hpp  |   7 +--
 src/lasreadpoint.cpp              |   4 +-
 src/laswriteitemcompressed_v1.cpp |  72 +++++++++++++++++---------------------
 src/laswriteitemcompressed_v1.hpp |   7 +--
 5 files changed, 72 insertions(+), 90 deletions(-)
diffs (296 lines):
diff -r 294dfaf3b0d3 -r 113c76a6708b src/lasreaditemcompressed_v1.cpp
--- a/src/lasreaditemcompressed_v1.cpp	Thu Dec 23 06:11:29 2010 -0800
+++ b/src/lasreaditemcompressed_v1.cpp	Thu Dec 23 10:11:19 2010 -0800
@@ -78,7 +78,7 @@
   this->dec = dec;
   /* create models and integer compressors */
-  ic_dx = new IntegerCompressor(dec, 32, 2);  // 32 bits, 2 contexts
+  ic_dx = new IntegerCompressor(dec, 32);  // 32 bits, 1 context
 	ic_dy = new IntegerCompressor(dec, 32, 33); // 32 bits, 33 contexts
 	ic_z = new IntegerCompressor(dec, 32, 33);  // 32 bits, 33 contexts
 	m_changed_values = dec->createSymbolModel(64);
@@ -112,10 +112,9 @@
 BOOL LASreadItemCompressed_POINT10_v1::init(const U8* item)
   /* init state */
-  last_dir = 0;
-	last_x_diff[0][0] = last_x_diff[0][1] = last_x_diff[0][2] = last_x_diff[1][0] = last_x_diff[1][1] = last_x_diff[1][2] = 0;
-	last_y_diff[0][0] = last_y_diff[0][1] = last_y_diff[0][2] = last_y_diff[1][0] = last_y_diff[1][1] = last_y_diff[1][2] = 0;
-  last_incr[0] = last_incr[1] = 0;
+	last_x_diff[0] = last_x_diff[1] = last_x_diff[2] = 0;
+	last_y_diff[0] = last_y_diff[1] = last_y_diff[2] = 0;
+  last_incr = 0;
   /* init models and integer compressors */
   ic_dx->initDecompressor();
@@ -139,50 +138,50 @@
   // find median difference for x and y from 3 preceding differences
   I32 median_x;
-  if (last_x_diff[last_dir][0] < last_x_diff[last_dir][1])
+  if (last_x_diff[0] < last_x_diff[1])
-    if (last_x_diff[last_dir][1] < last_x_diff[last_dir][2])
-      median_x = last_x_diff[last_dir][1];
-    else if (last_x_diff[last_dir][0] < last_x_diff[last_dir][2])
-     median_x = last_x_diff[last_dir][2];
+    if (last_x_diff[1] < last_x_diff[2])
+      median_x = last_x_diff[1];
+    else if (last_x_diff[0] < last_x_diff[2])
+      median_x = last_x_diff[2];
     else
-      median_x = last_x_diff[last_dir][0];
+      median_x = last_x_diff[0];
   else
-    if (last_x_diff[last_dir][0] < last_x_diff[last_dir][2])
-    else if (last_x_diff[last_dir][1] < last_x_diff[last_dir][2])
+    if (last_x_diff[0] < last_x_diff[2])
+    else if (last_x_diff[1] < last_x_diff[2])
     else
   I32 median_y;
-  if (last_y_diff[last_dir][0] < last_y_diff[last_dir][1])
+  if (last_y_diff[0] < last_y_diff[1])
-    if (last_y_diff[last_dir][1] < last_y_diff[last_dir][2])
-      median_y = last_y_diff[last_dir][1];
-    else if (last_y_diff[last_dir][0] < last_y_diff[last_dir][2])
-      median_y = last_y_diff[last_dir][2];
+    if (last_y_diff[1] < last_y_diff[2])
+      median_y = last_y_diff[1];
+    else if (last_y_diff[0] < last_y_diff[2])
+      median_y = last_y_diff[2];
     else
-      median_y = last_y_diff[last_dir][0];
+      median_y = last_y_diff[0];
   else
-    if (last_y_diff[last_dir][0] < last_y_diff[last_dir][2])
-    else if (last_y_diff[last_dir][1] < last_y_diff[last_dir][2])
+    if (last_y_diff[0] < last_y_diff[2])
+    else if (last_y_diff[1] < last_y_diff[2])
     else
   // copy point from last point
   memcpy(item, last_item, 20);
   // decompress x y z coordinates
-  I32 x_diff = ic_dx->decompress(median_x, last_dir);
+  I32 x_diff = ic_dx->decompress(median_x);
   ((LASpoint10*)item)->x += x_diff;
   // we use the number k of bits corrector bits to switch contexts
   U32 k_bits = ic_dx->getK();
@@ -233,18 +232,11 @@
-  // only record the difference if the scan direction has not changed
-  if (last_dir == ((LASpoint10*)item)->scan_direction_flag)
-    last_x_diff[last_dir][last_incr[last_dir]] = x_diff;
-    last_y_diff[last_dir][last_incr[last_dir]] = y_diff;
-    last_incr[last_dir]++;
-    if (last_incr[last_dir] > 2) last_incr[last_dir] = 0;
-  else
-    last_dir = ((LASpoint10*)item)->scan_direction_flag;
+  // record the difference
+  last_x_diff[last_incr] = x_diff;
+  last_y_diff[last_incr] = y_diff;
+  last_incr++;
+  if (last_incr > 2) last_incr = 0;
   // copy the last point
   memcpy(last_item, item, 20);
diff -r 294dfaf3b0d3 -r 113c76a6708b src/lasreaditemcompressed_v1.hpp
--- a/src/lasreaditemcompressed_v1.hpp	Thu Dec 23 06:11:29 2010 -0800
+++ b/src/lasreaditemcompressed_v1.hpp	Thu Dec 23 10:11:19 2010 -0800
@@ -65,10 +65,9 @@
   EntropyDecoder* dec;
   U8* last_item;
-  I32 last_dir;
-  I32 last_x_diff[2][3];
-  I32 last_y_diff[2][3];
-  I32 last_incr[2];
+  I32 last_x_diff[3];
+  I32 last_y_diff[3];
+  I32 last_incr;
   IntegerCompressor* ic_dx;
   IntegerCompressor* ic_dy;
   IntegerCompressor* ic_z;
diff -r 294dfaf3b0d3 -r 113c76a6708b src/lasreadpoint.cpp
--- a/src/lasreadpoint.cpp	Thu Dec 23 06:11:29 2010 -0800
+++ b/src/lasreadpoint.cpp	Thu Dec 23 10:11:19 2010 -0800
@@ -146,8 +146,8 @@
           return FALSE;
         break;
       case LASitem::WAVEPACKET13:
-        if (items[i].version == 0)
-          readers_compressed[i] = new LASreadItemCompressed_BYTE_v1(dec, items[i].size);
+        if (items[i].version == 1)
+          readers_compressed[i] = new LASreadItemCompressed_WAVEPACKET13_v1(dec);
         else
           return FALSE;
         break;
diff -r 294dfaf3b0d3 -r 113c76a6708b src/laswriteitemcompressed_v1.cpp
--- a/src/laswriteitemcompressed_v1.cpp	Thu Dec 23 06:11:29 2010 -0800
+++ b/src/laswriteitemcompressed_v1.cpp	Thu Dec 23 10:11:19 2010 -0800
@@ -78,7 +78,7 @@
   this->enc = enc;
-  ic_dx = new IntegerCompressor(enc, 32, 2);  // 32 bits, 2 contexts
+  ic_dx = new IntegerCompressor(enc, 32);  // 32 bits, 1 context
 	ic_dy = new IntegerCompressor(enc, 32, 33); // 32 bits, 33 contexts
 	ic_z = new IntegerCompressor(enc, 32, 33);  // 32 bits, 33 contexts
 	m_changed_values = enc->createSymbolModel(64);
@@ -111,10 +111,9 @@
 BOOL LASwriteItemCompressed_POINT10_v1::init(const U8* item)
   /* init state */
-  last_dir = 0;
+  last_incr = 0;
   ic_dx->initCompressor();
@@ -138,50 +137,50 @@
   I32 median_x;
     else
   else
     else
   I32 median_y;
     else
   else
     else
   // compress x y z coordinates
   I32 x_diff = ((LASpoint10*)item)->x - ((LASpoint10*)last_item)->x;
   I32 y_diff = ((LASpoint10*)item)->y - ((LASpoint10*)last_item)->y;
-  ic_dx->compress(median_x, x_diff, last_dir);
+  ic_dx->compress(median_x, x_diff);
   ic_dy->compress(median_y, y_diff, k_bits);
@@ -234,18 +233,11 @@
     ic_point_source_ID->compress(((LASpoint10*)last_item)->point_source_ID, ((LASpoint10*)item)->point_source_ID);
-  else
+  last_incr++;
   // copy the last item
diff -r 294dfaf3b0d3 -r 113c76a6708b src/laswriteitemcompressed_v1.hpp
--- a/src/laswriteitemcompressed_v1.hpp	Thu Dec 23 06:11:29 2010 -0800
+++ b/src/laswriteitemcompressed_v1.hpp	Thu Dec 23 10:11:19 2010 -0800
@@ -65,10 +65,9 @@
   EntropyEncoder* enc;
   U8* last_item;
-  I32 last_dir;
-  I32 last_incr[2];
+  I32 last_incr;
More information about the Liblas-commits mailing list
