[Liblas-commits] hg: switch to reader factory, to support zippified files
liblas-commits at liblas.org liblas-commits at liblas.org
Fri Dec 24 16:05:30 EST 2010
details:   http://hg.liblas.orghg/rev/525e591365b6
changeset: 2641:525e591365b6
user:      Michael P. Gerlek <mpg at flaxen.com>
date:      Fri Dec 24 12:17:33 2010 -0800
description:
Subject: hg: fix scoping issue, so dtor can write the stream
details:   http://hg.liblas.orghg/rev/d1651ff80146
changeset: 2642:d1651ff80146
date:      Fri Dec 24 12:20:46 2010 -0800
description:
Subject: hg: another missing facvtory usage
details:   http://hg.liblas.orghg/rev/7ac404a1357c
changeset: 2643:7ac404a1357c
date:      Fri Dec 24 12:23:55 2010 -0800
description:
Subject: hg: guard against not using the factory
details:   http://hg.liblas.orghg/rev/d8abc651ff00
changeset: 2644:d8abc651ff00
date:      Fri Dec 24 12:24:42 2010 -0800
description:
Subject: hg: guard against bad factories
details:   http://hg.liblas.orghg/rev/77cf1db88f17
changeset: 2645:77cf1db88f17
date:      Fri Dec 24 12:26:09 2010 -0800
description:
Subject: hg: flush out and close the output stream before we reopen it again to update the header
details:   http://hg.liblas.orghg/rev/de0fbaccb564
changeset: 2646:de0fbaccb564
date:      Fri Dec 24 12:32:35 2010 -0800
description:
Subject: hg: don't do this -- it only causes unnecessary pain and suffering everytime a writer gets built, for any reason at all
details:   http://hg.liblas.orghg/rev/803041b4603d
changeset: 2647:803041b4603d
date:      Fri Dec 24 12:33:53 2010 -0800
description:
Subject: hg: renaming Header::IsCompressed
details:   http://hg.liblas.orghg/rev/c5f71ed9f6fc
changeset: 2648:c5f71ed9f6fc
date:      Fri Dec 24 12:51:59 2010 -0800
description:
diffstat:
 apps/las2las.cpp                |  15 ++++++++-------
 apps/las2txt.cpp                |   6 ++++--
 apps/laskernel.cpp              |  15 ++++++++-------
 include/liblas/header.hpp       |   4 ++--
 src/detail/reader/header.cpp    |   4 ++--
 src/detail/reader/reader.cpp    |   8 +++++---
 src/detail/reader/zipreader.cpp |   6 ++++++
 src/detail/writer/header.cpp    |   2 +-
 src/detail/writer/zipwriter.cpp |  19 +++++++++++--------
 src/factory.cpp                 |   4 ++--
 src/header.cpp                  |   4 ++--
 11 files changed, 51 insertions(+), 36 deletions(-)
diffs (268 lines):
diff -r 8f170797c7c5 -r c5f71ed9f6fc apps/las2las.cpp
--- a/apps/las2las.cpp	Thu Dec 23 21:29:05 2010 -0600
+++ b/apps/las2las.cpp	Fri Dec 24 12:51:59 2010 -0800
@@ -199,6 +199,12 @@
     if (verbose)
         std::cout << std::endl;
+    // cheap hackery.  We need the Writer to disappear before the stream.
+    // Fix this up to not suck so bad.
+    writer = WriterPtr();
+    ofs->close();
+    ofs = OStreamPtr();
     if (!split_mb && !split_pts) {
         reader.Reset();
@@ -207,11 +213,6 @@
         RewriteHeader(hnew, output);
-    // cheap hackery.  We need the Writer to disappear before the stream.
-    // Fix this up to not suck so bad.
-    writer = WriterPtr();
-    ofs = OStreamPtr();
     return true;
@@ -327,11 +328,11 @@
         switch (WriterFactory::InferFileTypeFromExtension(output))
         case WriterFactory::FileType_LAS:
-            header.SetIsCompressed(false);
+            header.SetCompressed(false);
             break;
         case WriterFactory::FileType_LAZ:
 #ifdef HAVE_LASZIP
-            header.SetIsCompressed(true);
+            header.SetCompressed(true);
 #else
             throw std::runtime_error("Compression support not enabled in liblas configuration");
 #endif
diff -r 8f170797c7c5 -r c5f71ed9f6fc apps/las2txt.cpp
--- a/apps/las2txt.cpp	Thu Dec 23 21:29:05 2010 -0600
+++ b/apps/las2txt.cpp	Fri Dec 24 12:51:59 2010 -0800
@@ -460,7 +460,8 @@
                 std::cerr << "Cannot open " << input << " for read.  Exiting..." << std::endl;
                 return 1;
-            liblas::Reader reader(ifs);
+            liblas::ReaderFactory f;
+            liblas::Reader reader = f.CreateWithStream(ifs);
             header = reader.GetHeader();
         } else {
             std::cerr << "Input LAS file not specified!\n";
@@ -592,7 +593,8 @@
         write_points(  reader,
                     *os,
diff -r 8f170797c7c5 -r c5f71ed9f6fc apps/laskernel.cpp
--- a/apps/laskernel.cpp	Thu Dec 23 21:29:05 2010 -0600
+++ b/apps/laskernel.cpp	Fri Dec 24 12:51:59 2010 -0800
@@ -119,22 +119,23 @@
 void RewriteHeader(liblas::Header const& header, std::string const& filename)
     std::ios::openmode m = std::ios::out | std::ios::in | std::ios::binary | std::ios::ate;
+    // Write a blank PointRecordsByReturnCount first
+    std::ofstream ofs(filename.c_str(), m);
-        // Write a blank PointRecordsByReturnCount first
-        std::ofstream ofs(filename.c_str(), m);
+        // scope this, so the dtor can write to the stream before we close it
         liblas::Writer writer(ofs, header);
-        ofs.close();
+    ofs.close();
+    // Write our updated header with summary info
+    std::ofstream ofs2(filename.c_str(), m);
-        // Write our updated header with summary info
-        std::ofstream ofs2(filename.c_str(), m);
         liblas::Writer writer2(ofs2, header);
-        ofs2.close();
+    ofs2.close();
 void RepairHeader(liblas::CoordinateSummary const& summary, liblas::Header& header)
diff -r 8f170797c7c5 -r c5f71ed9f6fc include/liblas/header.hpp
--- a/include/liblas/header.hpp	Thu Dec 23 21:29:05 2010 -0600
+++ b/include/liblas/header.hpp	Fri Dec 24 12:51:59 2010 -0800
@@ -351,10 +351,10 @@
     /// Returns true iff the file is compressed (laszip),
     /// as determined by the high bit in the point type
-    bool IsCompressed() const;
+    bool Compressed() const;
     /// Sets whether or not the points are compressed.
-    void SetIsCompressed(bool b);
+    void SetCompressed(bool b);
     void to_rst(std::ostream& os) const;
     void to_xml(std::ostream& os) const;
diff -r 8f170797c7c5 -r c5f71ed9f6fc src/detail/reader/header.cpp
--- a/src/detail/reader/header.cpp	Thu Dec 23 21:29:05 2010 -0600
+++ b/src/detail/reader/header.cpp	Fri Dec 24 12:51:59 2010 -0800
@@ -162,7 +162,7 @@
     if (n1 >> 7)
-        m_header->SetIsCompressed(true);
+        m_header->SetCompressed(true);
         n1 &= 0x7f;
@@ -311,7 +311,7 @@
         std::ios::off_type remainder = point_bytes % length;
-        if ( !m_header->IsCompressed() && m_header->GetPointRecordsCount() != static_cast<uint32_t>(count)) {
+        if ( !m_header->Compressed() && m_header->GetPointRecordsCount() != static_cast<uint32_t>(count)) {
             if (remainder == 0)
                 // The point bytes are exactly long enough, let's use it
diff -r 8f170797c7c5 -r c5f71ed9f6fc src/detail/reader/reader.cpp
--- a/src/detail/reader/reader.cpp	Thu Dec 23 21:29:05 2010 -0600
+++ b/src/detail/reader/reader.cpp	Fri Dec 24 12:51:59 2010 -0800
@@ -132,11 +132,13 @@
     m_header_reader->read();
     m_header = m_header_reader->GetHeader();
+    if (m_header->Compressed())
+        throw std::runtime_error("Internal error: uncompressed reader encountered compressed header");
     m_point->SetHeaderPtr(m_header);
     Reset();
 void ReaderImpl::SetHeader(liblas::Header const& header)
diff -r 8f170797c7c5 -r c5f71ed9f6fc src/detail/reader/zipreader.cpp
--- a/src/detail/reader/zipreader.cpp	Thu Dec 23 21:29:05 2010 -0600
+++ b/src/detail/reader/zipreader.cpp	Fri Dec 24 12:51:59 2010 -0800
@@ -238,6 +238,9 @@
+    if (!m_header->Compressed())
+        throw std::runtime_error("Internal error: compressed reader encountered uncompressed header");
     Reset();
@@ -260,7 +263,10 @@
     std::vector<boost::uint8_t> v(m_lz_point_size);
     for (unsigned int i=0; i<m_lz_point_size; i++)
         v[i] = m_lz_point_data[i];
+        //printf("%d %d\n", v[i], i);
     m_point->SetData(v);
     ++m_current;
diff -r 8f170797c7c5 -r c5f71ed9f6fc src/detail/writer/header.cpp
--- a/src/detail/writer/header.cpp	Thu Dec 23 21:29:05 2010 -0600
+++ b/src/detail/writer/header.cpp	Fri Dec 24 12:51:59 2010 -0800
@@ -223,7 +223,7 @@
     // 16. Point Data Format ID
     n1 = static_cast<uint8_t>(m_header.GetDataFormatId());
     uint8_t n1tmp = n1;
-    if (m_header.IsCompressed())
+    if (m_header.Compressed())
         n1tmp |= 0x80;
     detail::write_n(m_ofs, n1tmp, sizeof(n1tmp));
diff -r 8f170797c7c5 -r c5f71ed9f6fc src/detail/writer/zipwriter.cpp
--- a/src/detail/writer/zipwriter.cpp	Thu Dec 23 21:29:05 2010 -0600
+++ b/src/detail/writer/zipwriter.cpp	Fri Dec 24 12:51:59 2010 -0800
@@ -178,7 +178,10 @@
     const std::vector<boost::uint8_t>& v = point.GetData();
         m_lz_point_data[i] = v[i];
     bool ok = m_zipper->write(m_lz_point);
     if (!ok)
@@ -191,14 +194,14 @@
     // Try to update the point count on our way out, but we don't really
     // care if we weren't able to write it.
-    try
-        UpdatePointCount(0);
-    } catch (std::runtime_error const&)
+    //try
+    //    UpdatePointCount(0);
+    //} catch (std::runtime_error const&)
     delete m_zipper;
diff -r 8f170797c7c5 -r c5f71ed9f6fc src/factory.cpp
--- a/src/factory.cpp	Thu Dec 23 21:29:05 2010 -0600
+++ b/src/factory.cpp	Fri Dec 24 12:51:59 2010 -0800
@@ -83,7 +83,7 @@
     h->read();
     HeaderPtr header = h->GetHeader();
-    if (header->IsCompressed())
+    if (header->Compressed())
 #ifdef HAVE_LASZIP
         ReaderIPtr r = ReaderIPtr(new detail::ZipReaderImpl(stream) );
@@ -107,7 +107,7 @@
 WriterIPtr WriterFactory::CreateWithStream(std::ostream& stream, Header const& header)
-    if (header.IsCompressed())
+    if (header.Compressed())
 #ifdef HAVE_LASZIP
         WriterIPtr w  = WriterIPtr(new detail::ZipWriterImpl(stream));
diff -r 8f170797c7c5 -r c5f71ed9f6fc src/header.cpp
--- a/src/header.cpp	Thu Dec 23 21:29:05 2010 -0600
+++ b/src/header.cpp	Fri Dec 24 12:51:59 2010 -0800
@@ -691,12 +691,12 @@
-void Header::SetIsCompressed(bool b)
+void Header::SetCompressed(bool b)
     m_isCompressed = b;
-bool Header::IsCompressed() const
+bool Header::Compressed() const
     return m_isCompressed;
More information about the Liblas-commits mailing list
