[Liblas-commits] hg: 3 new changesets
liblas-commits at liblas.org liblas-commits at liblas.org
Tue Jun 15 10:50:19 EDT 2010
changeset 2a6f556860e1 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=2a6f556860e1
summary: ignores
changeset 0d4cf80578cd in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=0d4cf80578cd
summary: don't *force* Release mode building, but default to it
changeset 30464a12bc58 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=30464a12bc58
summary: clean up test file
diffstat:
 .hgignore             |  2 ++
 CMakeLists.txt        |  2 +-
 python/tests/File.txt |  3 ++-
 3 files changed, 5 insertions(+), 2 deletions(-)
diffs (34 lines):
diff -r e53ca986b408 -r 30464a12bc58 .hgignore
--- a/.hgignore	Fri Jun 11 14:03:10 2010 -0500
+++ b/.hgignore	Tue Jun 15 09:50:10 2010 -0500
@@ -89,3 +89,5 @@
 doc/api/xml
 doc/api/html
 *.mshark
+Testing/
+README.txt
diff -r e53ca986b408 -r 30464a12bc58 CMakeLists.txt
--- a/CMakeLists.txt	Fri Jun 11 14:03:10 2010 -0500
+++ b/CMakeLists.txt	Tue Jun 15 09:50:10 2010 -0500
@@ -65,7 +65,7 @@
 # Default to release mode
 set(CMAKE_BUILD_TYPE Release CACHE STRING
     "Choose the type of build, options are: None Debug Release RelWithDebInfo MinSizeRel"
-    FORCE)
 set(BUILD_PEDANTIC TRUE CACHE BOOL "Choose compilation in pedantic or relaxed mode")
diff -r e53ca986b408 -r 30464a12bc58 python/tests/File.txt
--- a/python/tests/File.txt	Fri Jun 11 14:03:10 2010 -0500
+++ b/python/tests/File.txt	Tue Jun 15 09:50:10 2010 -0500
@@ -350,7 +350,8 @@
   >>> os.remove('junk2.las')
   >>> os.remove('junk3.las')
   >>> os.remove('junk4.las')
+  >>> os.remove('junk5.las')
   >>> f = file.File('junk.las', mode="w", header=h)
   >>> import liblas.core
   >>> liblas.core.las.LASWriter_Destroy(f.handle)
More information about the Liblas-commits mailing list
