[Liblas-commits] hg: 4 new changesets
liblas-commits at liblas.org
Tue Nov 2 10:50:50 EDT 2010
changeset 2a622d0bc76f in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=2a622d0bc76f
summary: silence unintialized warning
changeset dff322986678 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=dff322986678
summary: verbose makefile option
changeset d72a9c8085d2 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=d72a9c8085d2
summary: add osgeo4w include/lib to CMAKE_INCLUDE_PATH and CMAKE_LIBRARY_PATH for find_path and find_library default on win32
changeset fc67f81addc4 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=fc67f81addc4
summary: put osgeo4w's gdal-dev package ahead of the default osgeo4w gdal search paths
diffstat:
CMakeLists.txt | 14 ++++++++++++--
cmake/modules/FindGDAL.cmake | 2 ++
hobu-config.bat | 2 +-
include/liblas/lasbounds.hpp | 2 +-
4 files changed, 16 insertions(+), 4 deletions(-)
diffs (81 lines):
diff -r 29f90cc49906 -r fc67f81addc4 CMakeLists.txt
--- a/CMakeLists.txt Mon Nov 01 20:44:33 2010 -0500
+++ b/CMakeLists.txt Tue Nov 02 09:50:25 2010 -0500
@@ -100,6 +100,9 @@
mark_as_advanced(VCPROJ_USER_ENVIRONMENT_PATH_DEBUG)
endif()
+ set(CMAKE_INCLUDE_PATH c:/osgeo4w/include;$ENV{CMAKE_INCLUDE_PATH})
+ set(CMAKE_LIBRARY_PATH c:/osgeo4w/lib;$ENV{CMAKE_LIBRARY_PATH})
else()
# Recommended C++ compilation flags
@@ -173,9 +176,12 @@
# Determine libTIFF availability, required
if (GEOTIFF_FOUND)
+ mark_as_advanced(CLEAR TIFF_INCLUDE_DIR)
+ mark_as_advanced(CLEAR TIFF_LIBRARY)
+ if (WIN32)
+ set(TIFF_NAMES libtiff_i)
+ endif(WIN32)
find_package(TIFF)
- mark_as_advanced(CLEAR TIFF_INCLUDE_DIR)
- mark_as_advanced(CLEAR TIFF_LIBRARIES)
if (TIFF_FOUND)
include_directories(${TIFF_INCLUDE_DIR})
endif()
@@ -209,6 +215,10 @@
add_definitions(-DHAVE_GDAL=1)
endif()
endif()
+ mark_as_advanced(CLEAR GDAL_INCLUDE_DIR)
+ mark_as_advanced(CLEAR GDAL_LIBRARY)
endif()
# Oracle support - optional, default=OFF
diff -r 29f90cc49906 -r fc67f81addc4 cmake/modules/FindGDAL.cmake
--- a/cmake/modules/FindGDAL.cmake Mon Nov 01 20:44:33 2010 -0500
+++ b/cmake/modules/FindGDAL.cmake Tue Nov 02 09:50:25 2010 -0500
@@ -55,6 +55,7 @@
NAMES gdal.h
PATH_PREFIXES gdal gdal-1.6
PATHS
+ "${OSGEO4W_ROOT_DIR}/apps/gdal-dev/include"
"$ENV{LIB_DIR}/include/gdal"
${OSGEO4W_ROOT_DIR}/include)
@@ -66,6 +67,7 @@
"$ENV{LIB_DIR}/lib"
/usr/lib
c:/msys/local/lib
+ "${OSGEO4W_ROOT_DIR}/apps/gdal-dev/lib"
${OSGEO4W_ROOT_DIR}/lib)
IF(GDAL_LIBRARY)
diff -r 29f90cc49906 -r fc67f81addc4 hobu-config.bat
--- a/hobu-config.bat Mon Nov 01 20:44:33 2010 -0500
+++ b/hobu-config.bat Tue Nov 02 09:50:25 2010 -0500
@@ -26,5 +26,5 @@
-DORACLE_INCLUDE_DIR=%ORACLE_HOME%\include ^
-DORACLE_OCI_LIBRARY=%ORACLE_HOME%\lib\oci.lib ^
-DCMAKE_BUILD_TYPE=%BUILD_TYPE% ^
- -DCMAKE_VERBOSE_FILE=OFF ^
+ -DCMAKE_VERBOSE_MAKEFILE=OFF ^
%LIBLAS%
\ No newline at end of file
diff -r 29f90cc49906 -r fc67f81addc4 include/liblas/lasbounds.hpp
--- a/include/liblas/lasbounds.hpp Mon Nov 01 20:44:33 2010 -0500
+++ b/include/liblas/lasbounds.hpp Tue Nov 02 09:50:25 2010 -0500
@@ -533,7 +533,7 @@
T volume() const
- T output;
+ T output = static_cast<T>(0);
for (size_type i = 0; i < dimension(); i++) {
output = output * ranges[i].length();
More information about the Liblas-commits
