[Liblas-commits] hg: more getting started doc
liblas-commits at liblas.org liblas-commits at liblas.org
Thu Nov 4 12:56:55 EDT 2010
changeset 9bc112c8701c in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=9bc112c8701c
summary: more getting started doc
diffstat:
 doc/start.txt |  124 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++-
 1 files changed, 121 insertions(+), 3 deletions(-)
diffs (148 lines):
diff -r 04d40d3a1304 -r 9bc112c8701c doc/start.txt
--- a/doc/start.txt	Thu Nov 04 11:56:14 2010 -0500
+++ b/doc/start.txt	Thu Nov 04 11:56:51 2010 -0500
@@ -60,7 +60,7 @@
 you might want to do on LAS data, and the utilities and approaches to
 take to complete those tasks.
-Reproject a LAS file
+Reprojecting an LAS file
 All LAS data are in some sort of coordinate system, even if that coordinate
@@ -75,8 +75,122 @@
 LAS file, or you may override the coordinate system description (or supply
 one if none was specified).
+We're going to use an example file at http://liblas.org/samples/srs.las which
+contains only 10 points and has a coordinate system defined.  Please
+download this file if you want to follow along.
 :ref:`las2las <las2las>` is very similar in behavior to another data
-translation utility for raster data -- `gdal_translate`_.
+translation utility for raster data -- `gdal_translate`_.  To reproject data,
+we must have a description of both the coordinate system we are starting with
+and a description of the coordinate system we are going to.  To find out what
+you are starting with, issue a :ref:`lasinfo <lasinfo>` command:
+    lasinfo --no-check srs.las
+.. note::
+    The --no-check option tells lasinfo to only print the header information
+    for the file and to not scan through all of the points.  For a 10 point file,
+    this of course isn't much of a concern, but with a 50 or 500 million point
+    file, it isn't worth waiting for a full scan of the data if all you
+    want is header information.
+Our :ref:`lasinfo <lasinfo>` invocation tells us that the ``srs.las`` file
+is in a UTM North Zone 17 coordinate system:
+    PROJCS["WGS 84 / UTM zone 17N",
+        GEOGCS["WGS 84",
+            DATUM["WGS_1984",
+                SPHEROID["WGS 84",6378137,298.257223563,
+                    AUTHORITY["EPSG","7030"]],
+                AUTHORITY["EPSG","6326"]],
+            PRIMEM["Greenwich",0],
+            UNIT["degree",0.0174532925199433],
+            AUTHORITY["EPSG","4326"]],
+        PROJECTION["Transverse_Mercator"],
+        PARAMETER["latitude_of_origin",0],
+        PARAMETER["central_meridian",-81],
+        PARAMETER["scale_factor",0.9996],
+        PARAMETER["false_easting",500000],
+        PARAMETER["false_northing",0],
+        UNIT["metre",1,
+            AUTHORITY["EPSG","9001"]],
+        AUTHORITY["EPSG","32617"]]
+Now that we know our input coordinate system, we can make a decision about
+what to reproject the data to.  In our first example, we're going to use
+the venerable plate carrée non-coordinate system, `EPSG:4326`_.
+    las2las srs.las --t_srs EPSG:4326
+Our process succeeds, but after a quick inspection of the data with
+``lasinfo output.las`` we see a problem:
+    Scale Factor X Y Z:          0.01 0.01 0.01
+    Offset X Y Z:                -0.00 -0.00 -0.00
+    Min X, Y, Z: 		-83.43, 39.01, 170.58,
+    Max X, Y, Z: 		-83.43, 39.01, 170.76,
+The ``srs.las`` file had a scale of 0.01, or two decimal places of precision
+for its X, Y, and Z coordinates.  For UTM data, this is ok, because it implies
+an implicit precision of 1 cm.  For decimal degree data of the unprojected plate carrée
+coordinate system, it causes us to lose a bunch of precision.  We need to
+set our scale values to something that can hold more precision in our case:
+    las2las --t_srs EPSG:4326 srs.las --scale 0.000001 0.000001 0.01
+Another quick inspection with :ref:`lasinfo <lasinfo>` gives us something
+we're more comfortable with:
+    Scale Factor X Y Z:          0.000001 0.000001 0.01
+    Offset X Y Z:                -0.000000 -0.000000 -0.00
+    Min X, Y, Z: 		-83.427598, 39.012599, 170.58
+    Max X, Y, Z: 		-83.427548, 39.012618, 170.76
+Vertical datum transformation of an LAS file
+We're going to continue what we were doing in `Reprojecting an LAS file`_ but
+add a twist -- we want to change the vertical datum on the data from WGS84
+to NAVD88.
+.. warning::
+    A number of requirements are needed before you can do vertical datum transformations
+    with libLAS.  The most important is GDAL, of course, but you also need a
+    very current (possibly even unreleased) version of `Proj.4`_ and the vertical
+    datum .gtx transformation files. If you're using :ref:`osgeo4w_install`, you
+    already have all of this installed when you installed libLAS.  For Linux
+    or other Unix platforms, you should be aware of these requirements.
+Assuming you have all of the prerequisites in place, we can do the vertical
+datum transformation quite simply (again, worrying about precision as well):
+    las2las srs.las --t_srs EPSG:4326+5703 --scale 0.000001 0.000001 0.01
+The key point there is adding `+5703` to the coordinate system description
+tells the GDAL/Proj.4 machinery to do a vertical transformation.  There are
+other ways to have these operations happen using `WKT`_ and even GeoTIFF
+keys, but this is the most simple way to do things via command line.
 .. _`CMake`: http://www.cmake.org/
 .. _`CTest`: http://cmake.org/cmake/help/ctest-2-8-docs.html
@@ -90,4 +204,8 @@
 .. _`OSGeo4W`: http://trac.osgeo.org/osgeo4w/
 .. _`Boost`: http://www.boost.org/
 .. _`DebianGIS`: http://wiki.debian.org/DebianGis
-.. _`gdal_translate`: http://www.gdal.org/gdal_translate.html
\ No newline at end of file
+.. _`gdal_translate`: http://www.gdal.org/gdal_translate.html
+.. _`EPSG`: http://www.epsg-registry.org/
+.. _`EPSG:4326`: http://spatialreference.org/ref/epsg/4326/
+.. _`Proj.4`: http://trac.osgeo.org/proj/
+.. _`WKT`: http://en.wikipedia.org/wiki/Well-known_text#Spatial_reference_systems
More information about the Liblas-commits mailing list
