[Liblas-commits] hg: clean up color fetcher and implementation in
las2las
liblas-commits at liblas.org
Thu Nov 11 16:10:27 EST 2010
changeset 656065985885 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=656065985885
summary: clean up color fetcher and implementation in las2las
diffstat:
apps/laskernel.cpp | 111 ++++++++++++++++++++++++++++++++++++++-
include/liblas/lastransform.hpp | 6 ++
src/lastransform.cpp | 50 ++++++++++++++---
3 files changed, 153 insertions(+), 14 deletions(-)
diffs (286 lines):
diff -r c84f93be7b8a -r 656065985885 apps/laskernel.cpp
--- a/apps/laskernel.cpp Wed Nov 10 11:47:20 2010 -0600
+++ b/apps/laskernel.cpp Thu Nov 11 15:10:13 2010 -0600
@@ -202,7 +202,6 @@
return liblas::FilterPtr(return_filter);
liblas::FilterPtr MakeClassFilter(std::vector<liblas::Classification> const& classes, liblas::FilterI::FilterType ftype)
@@ -288,6 +287,11 @@
transform_options.add_options()
("t_srs", po::value< string >(), "Coordinate system to reproject output LAS file to. Use --a_srs or verify that your input LAS file has a coordinate system according to lasinfo")
+ ("point-translate", po::value<std::string>(), "An expression to translate the X, Y, Z values of the point. For example, converting Z units that are in meters to feet: --point-translate \"x*1.0 y*1.0 z*3.2808399\"")
+ ("color-source", po::value<std::string>(), "A string to a GDAL-openable raster data source. Use GDAL VRTs if you want to adjust the data source or set its coordinate system, etc. \n--color-source \"afile.tif\" ")
+ ("color-source-bands", po::value< std::vector<boost::uint32_t> >()->multitoken(), "A list of three bands from the --color-source to assign to the R, G, B values for the point \n--color-source-bands 1 2 3")
+ ("color-source-scale", po::value< boost::uint32_t >(), "A number used by --color-source to scale the input R, G, B values for the point. For example, to scale the 8 bit color data from an input raster to 16 bit, the 8 bit data should be multiplied by 256. \n--color-source-scale 256")
return transform_options;
@@ -303,6 +307,7 @@
("offset", po::value< string >(), "A comma-separated or quoted, space-separated list of offsets to set on the output file: \n--offset 0,0,0\n--offset \"1234 5678 91011\"")
("scale", po::value< std::vector<double> >()->multitoken(), "A list of scales to set on the output file. Scales *cannot* be negative, and should always be a negative power of 10 \n--scale 0.1 0.1 0.00001")
("format,f", po::value< string >(), "Set the LAS format of the new file (only 1.0-1.2 supported at this time): \n--format 1.2\n-f 1.1")
+ ("point-format", po::value< boost::uint32_t >(), "Set the LAS point format of the new file (0, 1, 2, 3): \n--point-format 3\n")
("pad-header", po::value< string >(), "Add extra bytes to the existing header")
("min-offset", po::value<bool>()->zero_tokens(), "Set the offset of the header to the minimums of all values in the file. Note that this requires multiple read passes through the file to achieve.")
("file-creation", po::value< std::vector<string> >()->multitoken(), "Set the header's day/year. Specify either as \"1 2010\" for the first day of 2010, or as \"now\" to specify the current day/year")
@@ -311,8 +316,6 @@
("add-vlr", po::value<std::vector<std::string> >()->multitoken(), "Add VLRs with the given name and id combination. --add-vlr hobu 1234 \"Description of the VLR\" \"filename.ext\"")
("system-identifier", po::value<std::string>(), "Set the SystemID for the file. --system_identifier \"MODIFICATION\"")
("generating-software", po::value<std::string>(), "Set the SoftwareID for the file. --generating_software \"liblas.org\"")
- ("point-translate", po::value<std::string>(), "An expression to translate the X, Y, Z values of the point. For example, converting Z units that are in meters to feet: --point-translate \"x*1.0 y*1.0 z*3.2808399\"")
@@ -871,6 +874,20 @@
header.SetVersionMinor(static_cast<boost::uint8_t>(minor));
+ if (vm.count("point-format"))
+ boost::uint32_t format = vm["point-format"].as< boost::uint32_t >();
+ if (verbose)
+ std::cout << "Setting point format to: " << format << std::endl;
+ if (format > 3){
+ ostringstream oss;
+ oss << "Point format valid range is 0-3, not " << format;
+ throw std::runtime_error(oss.str());
+ header.SetDataFormatId(static_cast<liblas::PointFormatName>(format));
if (vm.count("pad-header"))
std::string header_pad = vm["pad-header"].as< string >();
@@ -1212,6 +1229,94 @@
transforms.push_back(srs_transform);
+ if (vm.count("color-source"))
+ std::string datasource = vm["color-source"].as< string >();
+ std::vector<boost::uint32_t> bands;
+ boost::uint32_t scale = 0;
+ bool bSetScale = false;
+ if (vm.count("color-source-bands"))
+ bands = vm["color-source-bands"].as< std::vector<boost::uint32_t> >();
+ if (bands.size() != 3)
+ std::ostringstream oss;
+ oss << "The bands list must have three elements, not " << bands.size();
+ else
+ bands.resize(3);
+ bands[0] = 1;
+ bands[1] = 2;
+ bands[2] = 3;
+ if (vm.count("color-source-scale"))
+ bSetScale = true;
+ scale = vm["color-source-scale"].as< boost::uint32_t >();
+ if (verbose)
+ // make a displayable string for the bands list
+ std::ostringstream bnds;
+ for (std::vector<uint32_t>::const_iterator i = bands.begin();
+ i != bands.end();
+ i++)
+ bnds << *i;
+ std::vector<uint32_t>::const_iterator i2 = i+1;
+ if (i2 != bands.end())
+ bnds << ", ";
+ std::cout << "Fetching color from ' " << datasource
+ << "' using bands '" << bnds.str()
+ << "' for R, G, B";
+ if (bSetScale)
+ std::cout << " with a scale factor of " << scale;
+ std::cout<< std::endl;
+ // Check the schema to see if we have color
+ liblas::Schema const& schema = header.GetSchema();
+ try
+ schema.GetDimension("Red");
+ } catch (std::runtime_error const&)
+ throw std::runtime_error("The header for this file does not allow storing red color information. Alter the header's data format using the --point-format switch");
+ try
+ schema.GetDimension("Blue");
+ throw std::runtime_error("The header for this file does not allow storing blue color information. Alter the header's data format using the --point-format switch");
+ try
+ schema.GetDimension("Green");
+ throw std::runtime_error("The header for this file does not allow storing green color information. Alter the header's data format using the --point-format switch");
+ liblas::TransformPtr color_fetch = liblas::TransformPtr(new liblas::ColorFetchingTransform(datasource, bands, liblas::HeaderPtr(new liblas::Header(header))));
+ if (bSetScale) {
+ liblas::ColorFetchingTransform* c = dynamic_cast<liblas::ColorFetchingTransform*>(color_fetch.get());
+ c->SetScaleFactor(scale);
+ transforms.push_back(color_fetch);
if (vm.count("point-translate"))
std::string translate = vm["point-translate"].as< std::string >();
diff -r c84f93be7b8a -r 656065985885 include/liblas/lastransform.hpp
--- a/include/liblas/lastransform.hpp Wed Nov 10 11:47:20 2010 -0600
+++ b/include/liblas/lastransform.hpp Thu Nov 11 15:10:13 2010 -0600
@@ -169,6 +169,11 @@
ColorFetchingTransform( std::string const& datasource,
+ ColorFetchingTransform( std::string const& datasource,
+ std::vector<boost::uint32_t> bands,
+ HeaderPtr header);
+ void SetScaleFactor(boost::uint32_t v) {m_scale = v; }
~ColorFetchingTransform();
bool transform(Point& point);
@@ -197,6 +202,7 @@
std::vector<boost::uint32_t> m_bands;
boost::array<double, 6> m_forward_transform;
boost::array<double, 6> m_inverse_transform;
+ boost::uint32_t m_scale;
ColorFetchingTransform(ColorFetchingTransform const& other);
ColorFetchingTransform& operator=(ColorFetchingTransform const& rhs);
diff -r c84f93be7b8a -r 656065985885 src/lastransform.cpp
--- a/src/lastransform.cpp Wed Nov 10 11:47:20 2010 -0600
+++ b/src/lastransform.cpp Thu Nov 11 15:10:13 2010 -0600
@@ -40,6 +40,7 @@
#include <liblas/lastransform.hpp>
+#include <liblas/lasheader.hpp>
// boost
#include <boost/concept_check.hpp>
#include <boost/tokenizer.hpp>
@@ -398,9 +399,25 @@
- : m_ds(DataSourcePtr())
+ : m_new_header(HeaderPtr())
+ , m_ds(DataSourcePtr())
, m_datasource(datasource)
, m_bands(bands)
+ , m_scale(0)
+ Initialize();
+ColorFetchingTransform::ColorFetchingTransform(
+ std::string const& datasource,
+ HeaderPtr header
+ : m_new_header(header)
+ , m_datasource(datasource)
+ , m_bands(bands)
+ , m_scale(0)
Initialize();
@@ -426,16 +443,16 @@
m_bands.push_back( i+1 );
+ m_forward_transform.assign(0.0);
+ m_inverse_transform.assign(0.0);
- if (GDALGetGeoTransform( m_ds.get(), &m_forward_transform[0] ) != CE_None )
+ if (GDALGetGeoTransform( m_ds.get(), &(m_forward_transform.front()) ) != CE_None )
throw std::runtime_error("unable to fetch forward geotransform for raster!");
- m_forward_transform.assign(0.0);
- m_inverse_transform.assign(0.0);
- GDALInvGeoTransform( &m_forward_transform[0], &m_inverse_transform[0] );
+ GDALInvGeoTransform( &(m_forward_transform.front()), &(m_inverse_transform.front()) );
#endif
@@ -449,8 +466,12 @@
double x = point.GetX();
double y = point.GetY();
+ if (m_new_header.get())
+ point.SetHeaderPtr(m_new_header);
pixel = (boost::int32_t) std::floor(
+ m_inverse_transform[1] * x
@@ -472,21 +493,28 @@
boost::array<double, 2> pix;
boost::array<liblas::Color::value_type, 3> color;
+ color.assign(0);
for( std::vector<boost::int32_t>::size_type i = 0;
i < m_bands.size(); i++ )
GDALRasterBandH hBand = GDALGetRasterBand( m_ds.get(), m_bands[i] );
- if (hBand == NULL)
- continue;
+ if (hBand == NULL)
+ continue;
if( GDALRasterIO( hBand, GF_Read, pixel, line, 1, 1,
&pix[0], 1, 1, GDT_CFloat64, 0, 0) == CE_None )
- color[i] = static_cast<liblas::Color::value_type>(pix[0]);
+ color[i] = static_cast<liblas::Color::value_type>(pix[0]);
+ if (m_scale) {
+ color[i] = color[i] * m_scale;
point.SetColor(Color(color));
return true;
#else
boost::ignore_unused_variable_warning(point);
More information about the Liblas-commits
