[Liblas-commits] hg: 4 new changesets
liblas-commits at liblas.org
Mon Nov 15 17:25:12 EST 2010
changeset a0ecc216a208 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=a0ecc216a208
summary: Add more file definitions for testing and larger loop limit.
changeset eab21008af17 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=eab21008af17
summary: Bump Index revision. Add method to validate index version for use with filter iterator.
changeset 2846035161cf in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=2846035161cf
summary: Check index version to validate use with iterator.
changeset c2b2bfcd28c6 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=c2b2bfcd28c6
summary: Number of points in VLR needs to be reset when a VLR is written and more data waits in queue.
diffstat:
apps/lasindex_test.cpp | 28 ++++++++++++++++++++++++++--
include/liblas/lasindex.hpp | 6 +++++-
src/detail/index/indexoutput.cpp | 1 +
src/lasindex.cpp | 6 ++++++
4 files changed, 38 insertions(+), 3 deletions(-)
diffs (109 lines):
diff -r a3ebc4007bb9 -r c2b2bfcd28c6 apps/lasindex_test.cpp
--- a/apps/lasindex_test.cpp Mon Nov 15 12:15:52 2010 -0600
+++ b/apps/lasindex_test.cpp Mon Nov 15 15:24:19 2010 -0700
@@ -312,7 +312,7 @@
"-n", "K:\\FME\\billion_points_idx.ldx", "-r", "-it", "5000000"};
argc = 8;
- /*---------------------------billion_points-------------------------------*/
+ /*---------------------------400Pts---------------------------------------*/
/*-----------------build index in standalone file---------------------------
const char* arggv[] = {"foo", "-t", "C:\\LibLAS\\Samples\\400Pts.tmp",
"-i", "C:\\LibLAS\\Samples\\400Pts.las", "-a", SAMPLE_AUTHOR, "-c", SAMPLE_COMMENT, "-d", SAMPLE_DATE,
@@ -324,6 +324,30 @@
"-n", "C:\\LibLAS\\Samples\\400Pts_idx.ldx", "-r", "-it", "25"};
argc = 8;
+ /*---------------------------355by355-------------------------------------*/
+ /*-----------------build index in standalone file---------------------------
+ const char* arggv[] = {"foo", "-t", "C:\\LibLAS\\Samples\\355by355.tmp",
+ "-i", "C:\\LibLAS\\Samples\\355by355.las", "-a", SAMPLE_AUTHOR, "-c", SAMPLE_COMMENT, "-d", SAMPLE_DATE,
+ "-o", "C:\\LibLAS\\Samples\\355by355_idx.ldx", "-s", "-it", "100"};
+ argc = 16;
+ /*-------------------filter from standalone file using iterator-------------
+ const char* arggv[] = {"foo", "-i", "C:\\LibLAS\\Samples\\355by355.las",
+ "-n", "C:\\LibLAS\\Samples\\355by355_idx.ldx", "-r", "-it", "25"};
+ argc = 8;
+ /*---------------------------545by545-------------------------------------*/
+ const char* arggv[] = {"foo", "-t", "C:\\LibLAS\\Samples\\545by545.tmp",
+ "-i", "C:\\LibLAS\\Samples\\545by545.las", "-a", SAMPLE_AUTHOR, "-c", SAMPLE_COMMENT, "-d", SAMPLE_DATE,
+ "-o", "C:\\LibLAS\\Samples\\545by545_idx.ldx", "-s", "-it", "100"};
+ argc = 16;
+ const char* arggv[] = {"foo", "-i", "C:\\LibLAS\\Samples\\545by545.las",
+ "-n", "C:\\LibLAS\\Samples\\545by545_idx.ldx", "-r", "-it", "25"};
+ argc = 8;
for (int i = 1; i < argc; i++)
@@ -501,7 +525,7 @@
IndexIterator *indexIt2 = index.Filter(ParamSrc2, chunkSize);
if (indexIt && indexIt2)
- for (boost::uint32_t step = 0; step < 1000; ++step)
+ for (boost::uint32_t step = 0; step < 5000; ++step)
// use any of these to begin the vector with the next point that fits the filter criteria
// that hasn't been scanned yet.
diff -r a3ebc4007bb9 -r c2b2bfcd28c6 include/liblas/lasindex.hpp
--- a/include/liblas/lasindex.hpp Mon Nov 15 12:15:52 2010 -0600
+++ b/include/liblas/lasindex.hpp Mon Nov 15 15:24:19 2010 -0700
@@ -61,7 +61,7 @@
#define LIBLAS_INDEX_MAXMEMDEFAULT 10000000 // 10 megs default
#define LIBLAS_INDEX_MINMEMDEFAULT 1000000 // 1 meg at least has to be allowed
#define LIBLAS_INDEX_VERSIONMAJOR 1
-#define LIBLAS_INDEX_VERSIONMINOR 1 // minor version 1 begins 10/12/10
+#define LIBLAS_INDEX_VERSIONMINOR 2 // minor version 2 begins 11/15/10
#define LIBLAS_INDEX_MAXSTRLEN 512
#define LIBLAS_INDEX_MAXCELLS 250000
#define LIBLAS_INDEX_OPTPTSPERCELL 100
@@ -488,6 +488,8 @@
private:
void Copy(IndexIterator const& other);
void ResetPosition(void);
+ boost::uint8_t MinMajorVersion(void) {return(1);};
+ boost::uint8_t MinMinorVersion(void) {return(2);};
public:
/// n=0 or n=1 gives next sequence with no gap, n>1 skips n-1 filter-compliant points, n<0 skips backwards
@@ -512,6 +514,8 @@
inline const std::vector<boost::uint32_t>& operator-(boost::int32_t n) {return (advance(-n));}
/// returns filter-compliant points beginning with the nth compliant point, 0 and 1 return first set of compliant points
inline const std::vector<boost::uint32_t>& operator[](boost::int32_t n) {return ((*this)(n));}
+ /// tests viability of index for filtering with iterator
+ bool ValidateIndexVersion(boost::uint8_t VersionMajor, boost::uint8_t VersionMinor) {return (VersionMajor > MinMajorVersion() || (VersionMajor == MinMajorVersion() && VersionMinor >= MinMinorVersion()));};
template <typename T, typename Q>
diff -r a3ebc4007bb9 -r c2b2bfcd28c6 src/detail/index/indexoutput.cpp
--- a/src/detail/index/indexoutput.cpp Mon Nov 15 12:15:52 2010 -0600
+++ b/src/detail/index/indexoutput.cpp Mon Nov 15 15:24:19 2010 -0700
@@ -265,6 +265,7 @@
// get set up for next VLR
if (! InitializeVLRData(x, y))
return false;
+ m_DataPointsThisVLR = NumPts;
} // if
// if size allows, add to VLR cell record data
if (m_TempWritePos + m_DataRecordSize <= numeric_limits<unsigned short>::max())
diff -r a3ebc4007bb9 -r c2b2bfcd28c6 src/lasindex.cpp
--- a/src/lasindex.cpp Mon Nov 15 12:15:52 2010 -0600
+++ b/src/lasindex.cpp Mon Nov 15 15:24:19 2010 -0700
@@ -291,6 +291,12 @@
fprintf(m_debugger, "Index bounds do not intersect filter bounds.\n");
break;
} // if
+ if (ParamSrc.m_iterator && ! ParamSrc.m_iterator->ValidateIndexVersion(GetVersionMajor(), GetVersionMinor()))
+ if (m_debugOutputLevel > 1)
+ fprintf(m_debugger, "Index version does not support iterator access. Regenerate Index.\n");
+ break;
+ } // if
} // if 42
else if (RecordID == m_DataVLR_ID)
More information about the Liblas-commits
