[Liblas-commits] hg: 3 new changesets
liblas-commits at liblas.org liblas-commits at liblas.org
Thu Nov 18 12:16:10 EST 2010
changeset 65a798a87d8b in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=65a798a87d8b
summary: make a GetStreamPrecision utility function isntead of copying same functionality all over the place
changeset 55b13d84e958 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=55b13d84e958
summary: merge
changeset 40ce9d65ecce in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=40ce9d65ecce
summary: whoops
diffstat:
 include/liblas/lasindex.hpp |   6 +++---
 include/liblas/utility.hpp  |   2 ++
 src/lasheader.cpp           |  12 ++++--------
 src/lasindex.cpp            |  31 ++++++++++++++++++-------------
 src/lastransform.cpp        |   2 +-
 src/utility.cpp             |  22 +++++++++++++++-------
 6 files changed, 43 insertions(+), 32 deletions(-)
diffs (161 lines):
diff -r 50d7bae327ba -r 40ce9d65ecce include/liblas/lasindex.hpp
--- a/include/liblas/lasindex.hpp	Tue Nov 16 11:54:41 2010 -0600
+++ b/include/liblas/lasindex.hpp	Thu Nov 18 11:16:00 2010 -0600
@@ -492,9 +492,9 @@
 	boost::uint8_t MinMinorVersion(void)	{return(2);};
 public:
-	/// n=0 or n=1 gives next sequence with no gap, n>1 skips n-1 filter-compliant points, n<0 skips backwards
+	/// n=0 or n=1 gives next sequence with no gap, n>1 skips n-1 filter-compliant points, n<0 jumps backwards n compliant points
     const std::vector<boost::uint32_t>& advance(boost::int32_t n);
-    /// returns filter-compliant points beginning with the nth compliant point, 0 and 1 return first set of compliant points
+    /// returns filter-compliant points as though the first point returned is element n in a zero-based array
     const std::vector<boost::uint32_t>& operator()(boost::int32_t n);
 	/// returns next set of filter-compliant points with no skipped points
 	inline const std::vector<boost::uint32_t>& operator++()	{return (advance(1));}
@@ -512,7 +512,7 @@
 	inline const std::vector<boost::uint32_t>& operator-=(boost::int32_t n)	{return (advance(-n));}
 	/// returns set of filter-compliant points beginning n points backwards from the end of the last set, for n<0 acts like +()
 	inline const std::vector<boost::uint32_t>& operator-(boost::int32_t n)	{return (advance(-n));}
 	inline const std::vector<boost::uint32_t>& operator[](boost::int32_t n)	{return ((*this)(n));}
 	/// tests viability of index for filtering with iterator
 	bool ValidateIndexVersion(boost::uint8_t VersionMajor, boost::uint8_t VersionMinor)	{return (VersionMajor > MinMajorVersion() || (VersionMajor == MinMajorVersion() && VersionMinor >= MinMinorVersion()));};
diff -r 50d7bae327ba -r 40ce9d65ecce include/liblas/utility.hpp
--- a/include/liblas/utility.hpp	Tue Nov 16 11:54:41 2010 -0600
+++ b/include/liblas/utility.hpp	Thu Nov 18 11:16:00 2010 -0600
@@ -91,6 +91,8 @@
 LAS_DLL std::ostream& operator<<(std::ostream& os, liblas::Summary const& s);
+boost::uint32_t GetStreamPrecision(double scale);
 } // namespace liblas
 #endif // ndef LIBLAS_LASSUMMARY_HPP_INCLUDED
diff -r 50d7bae327ba -r 40ce9d65ecce src/lasheader.cpp
--- a/src/lasheader.cpp	Tue Nov 16 11:54:41 2010 -0600
+++ b/src/lasheader.cpp	Thu Nov 18 11:16:00 2010 -0600
@@ -45,6 +45,7 @@
 #include <liblas/lasspatialreference.hpp>
 #include <liblas/lasschema.hpp>
 #include <liblas/detail/private_utility.hpp>
+#include <liblas/utility.hpp>
 // boost
 #include <boost/cstdint.hpp>
 #include <boost/lambda/lambda.hpp>
@@ -831,15 +832,10 @@
     boost::uint32_t x_precision = 6;
     boost::uint32_t y_precision = 6;
     boost::uint32_t z_precision = 6;
-    double frac = 0;
-    double integer = 0;
-    frac = std::modf(x_scale, &integer);
-    x_precision = static_cast<boost::uint32_t>(std::fabs(std::floor(std::log10(frac))));
-    frac = std::modf(y_scale, &integer);
-    y_precision = static_cast<boost::uint32_t>(std::fabs(std::floor(std::log10(frac))));
-    frac = std::modf(z_scale, &integer);
-    z_precision = static_cast<boost::uint32_t>(std::fabs(std::floor(std::log10(frac))));
+    x_precision = GetStreamPrecision(x_scale);
+    y_precision = GetStreamPrecision(y_scale);
+    z_precision = GetStreamPrecision(z_scale);
     os << "  Scale Factor X Y Z:          ";
     os.precision(x_precision);
diff -r 50d7bae327ba -r 40ce9d65ecce src/lasindex.cpp
--- a/src/lasindex.cpp	Tue Nov 16 11:54:41 2010 -0600
+++ b/src/lasindex.cpp	Thu Nov 18 11:16:00 2010 -0600
@@ -2127,24 +2127,29 @@
 const std::vector<boost::uint32_t>& IndexIterator::operator()(boost::int32_t n)
-	if (n < 0)
-		n = 0;
-	if ((boost::uint32_t)n <= m_conformingPtsFound)
+	if (n <= 0)
 		ResetPosition();
-	n -= m_conformingPtsFound;
-	return (advance(n));
+		m_advance = 1;
+	} // if
+	else if (n < m_conformingPtsFound)
+		ResetPosition();
+		m_advance = n + 1;
+	} // if
+	else
+		m_advance = n - m_conformingPtsFound + 1;
+	} // else
+	m_indexData.SetIterator(this);
+	return (m_index->Filter(m_indexData));
 } // IndexIterator::operator++
 const std::vector<boost::uint32_t>& IndexIterator::advance(boost::int32_t n)
-	if (n < 0)
-		n = m_conformingPtsFound + n;
-		return((*this)(n));
-	} // if
-	m_advance = n;
-	m_indexData.SetIterator(this);
-	return (m_index->Filter(m_indexData));
+	if (n > 0)
+		--n;
+	return ((*this)(m_conformingPtsFound + n));
 } // IndexIterator::advance
diff -r 50d7bae327ba -r 40ce9d65ecce src/lastransform.cpp
--- a/src/lastransform.cpp	Tue Nov 16 11:54:41 2010 -0600
+++ b/src/lastransform.cpp	Thu Nov 18 11:16:00 2010 -0600
@@ -129,7 +129,7 @@
         msg << "Could not project point for ReprojectionTransform::" << CPLGetLastErrorMsg() << ret;
         throw std::runtime_error(msg.str());
     if (m_new_header.get())
         point.SetHeaderPtr(m_new_header);
diff -r 50d7bae327ba -r 40ce9d65ecce src/utility.cpp
--- a/src/utility.cpp	Tue Nov 16 11:54:41 2010 -0600
+++ b/src/utility.cpp	Thu Nov 18 11:16:00 2010 -0600
@@ -312,13 +312,9 @@
         double x_scale = tree.get<double>("summary.header.scale.x");
         double y_scale = tree.get<double>("summary.header.scale.y");
         double z_scale = tree.get<double>("summary.header.scale.z");
     catch (liblas::property_tree::ptree_bad_path const& e) {
@@ -462,4 +458,16 @@
+    double frac = 0;
+    double integer = 0;
+    frac = std::modf(scale, &integer);
+    double precision = std::fabs(std::floor(std::log10(frac)));
+    boost::uint32_t output = static_cast<boost::uint32_t>(precision);
+    return output;
More information about the Liblas-commits mailing list
