[Liblas-commits] hg: qualify int64_t
liblas-commits at liblas.org liblas-commits at liblas.org
Fri Nov 19 11:14:36 EST 2010
changeset d499301160a3 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=d499301160a3
summary: qualify int64_t
diffstat:
 src/chipper.cpp |  4 ++--
 1 files changed, 2 insertions(+), 2 deletions(-)
diffs (21 lines):
diff -r e542d506da05 -r d499301160a3 src/chipper.cpp
--- a/src/chipper.cpp	Fri Nov 19 09:58:48 2010 -0600
+++ b/src/chipper.cpp	Fri Nov 19 10:14:30 2010 -0600
@@ -247,7 +247,7 @@
     boost::int64_t center = static_cast<boost::int64_t>(m_partitions[pright - 1]);
     // Find left values for the partitions.
-    for (int64_t i = left; i <= right; ++i)
+    for (boost::int64_t i = left; i <= right; ++i)
         boost::int64_t idx = static_cast<boost::int64_t>(narrow[static_cast<boost::uint32_t>(i)].m_oindex);
         if (left1 < 0 && (idx < center))
@@ -264,7 +264,7 @@
     // Find right values for the partitions.
-    for (int64_t i = right; i >= left; --i)
+    for (boost::int64_t i = right; i >= left; --i)
         if (right1 < 0 && (idx < center))
More information about the Liblas-commits mailing list
