[Liblas-commits] hg: 2 new changesets
liblas-commits at liblas.org liblas-commits at liblas.org
Fri Nov 19 13:38:01 EST 2010
changeset abb3d1671a2b in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=abb3d1671a2b
summary: add twitter logo
changeset 8567233dc03d in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=8567233dc03d
summary: update LAS schema to more closely match what is currently going on
diffstat:
 doc/images/liblas-twitter-logo.png |    0
 schemas/LAS.xsd                    |  195 +++++++++++++++++++++++++-----------
 2 files changed, 132 insertions(+), 63 deletions(-)
diffs (239 lines):
diff -r f0b72c3c9bf7 -r 8567233dc03d doc/images/liblas-twitter-logo.png
Binary file doc/images/liblas-twitter-logo.png has changed
diff -r f0b72c3c9bf7 -r 8567233dc03d schemas/LAS.xsd
--- a/schemas/LAS.xsd	Fri Nov 19 10:15:58 2010 -0600
+++ b/schemas/LAS.xsd	Fri Nov 19 12:37:48 2010 -0600
@@ -1,22 +1,21 @@
-<?xml version="1.0" encoding="UTF-8"?>
-<xs:schema xmlns:xs="http://www.w3.org/2001/XMLSchema"
-    xmlns:las="http://liblas.org/schemas/LAS/example"
-    elementFormDefault="qualified"
-    attributeFormDefault="unqualified"
-    targetNamespace="http://liblas.org/schemas/LAS/example" version="1.0">
+<?xml version="1.0" encoding="UTF-8" standalone="no"?>
+<xs:schema xmlns:las="http://liblas.org/schemas/LAS/1.0" xmlns:xs="http://www.w3.org/2001/XMLSchema" attributeFormDefault="unqualified" elementFormDefault="qualified" targetNamespace="http://liblas.org/schemas/LAS/1.0" version="1.0">
     <xs:simpleType name="sizeType">
-        <xs:annotation><xs:documentation>
+        <xs:annotation>
+      <xs:documentation>
             The storage size type of the dimension.
-        </xs:documentation></xs:annotation>
+        </xs:documentation>
+    </xs:annotation>
         <xs:restriction base="xs:string">
-            <xs:enumeration value="byte"></xs:enumeration>
-            <xs:enumeration value="bit"></xs:enumeration>
+            <xs:enumeration value="byte"/>
+            <xs:enumeration value="bit"/>
         </xs:restriction>
     </xs:simpleType>
-    <xs:simpleType name="interpretationType" >
+    <xs:simpleType name="interpretationType">
+        <xs:annotation>
             Common interpretations of the data that may be used.  This
             type may be extended under the expectation that clients
             know how to consume the data.  In the case of string-like
@@ -24,78 +23,148 @@
             and transform accordingly.  Because nulls (or even
             multi-byte strings) might be allowed, there are
             no common string interpretations provided by defaut.
+    </xs:annotation>
-            <xs:enumeration value="int8_t"></xs:enumeration>
-            <xs:enumeration value="uint8_t"></xs:enumeration>
-            <xs:enumeration value="int16_t"></xs:enumeration>
-            <xs:enumeration value="uint16_t"></xs:enumeration>
-            <xs:enumeration value="int32_t"></xs:enumeration>
-            <xs:enumeration value="uint32_t"></xs:enumeration>
-            <xs:enumeration value="int64_t"></xs:enumeration>
-            <xs:enumeration value="uint64_t"></xs:enumeration>
-            <xs:enumeration value="double"></xs:enumeration>
-            <xs:enumeration value="float"></xs:enumeration>
-            <xs:enumeration value="unknown"></xs:enumeration>
+            <xs:enumeration value="int8_t"/>
+            <xs:enumeration value="uint8_t"/>
+            <xs:enumeration value="int16_t"/>
+            <xs:enumeration value="uint16_t"/>
+            <xs:enumeration value="int32_t"/>
+            <xs:enumeration value="uint32_t"/>
+            <xs:enumeration value="int64_t"/>
+            <xs:enumeration value="uint64_t"/>
+            <xs:enumeration value="double"/>
+            <xs:enumeration value="float"/>
+            <xs:enumeration value="unknown"/>
         </xs:restriction>
     </xs:simpleType>
     <xs:complexType name="rangeType">
-        <xs:attribute name="units" type="las:interpretationType"></xs:attribute>
-        <xs:attribute name="value" type="xs:decimal"></xs:attribute>
+        <xs:attribute name="units" type="las:interpretationType"/>
+        <xs:attribute name="value" type="xs:decimal"/>
     </xs:complexType>
     <xs:complexType name="dimensionType">
-        <xs:sequence>
-            <xs:element name="name" type="xs:string"  />
-            <xs:element name="description" type="xs:string" minOccurs="0"/>
-            <xs:element name="position" type="xs:nonNegativeInteger" >
-                    The dimension's position in the block of point data (counting from 0)
+        <xs:all>
+            <xs:element name="position" type="xs:nonNegativeInteger">
+                <xs:annotation>
+                        The dimension's position in the block of point data
+                        (counting from 0)
+                </xs:annotation>
+            </xs:element>
+            <xs:element name="size" type="xs:nonNegativeInteger">
+                <xs:annotation>
+                        The size of this dimension (assumed to be in bytes if
+                        no units element is available).
+                </xs:annotation>
+            </xs:element>
+            <xs:element name="required" type="xs:boolean">
+                <xs:annotation>
+                        Is this dimension required by the LAS Point Format?
+                </xs:annotation>
             </xs:element>
+            <xs:element minOccurs="0" name="name" type="xs:string"/>
+            <xs:element minOccurs="0" name="description" type="xs:string"/>
-            <xs:element name="active" type="xs:boolean">
-                    A dimension may have be holding its place in bytes but might not have actual
-                    values that mean anything.  This flag can be used to skip the dimension in
-                    that case.
+            <xs:element minOccurs="0" name="active" type="xs:boolean">
+                <xs:annotation>
+                    A dimension may have be holding its place in bytes but
+                    might not have actual values that mean anything. This flag
+                    can be used to skip the dimension in that case.
+                </xs:annotation>
+            </xs:element>
+            <xs:element minOccurs="0" name="units" type="las:sizeType">
+                <xs:annotation>
+                        The units to use for size measurements for this
+                        dimension. If no units element is specified, "bytes"
+                        is the assumed unit.
+                </xs:annotation>
             </xs:element>
-            <!--Specify the size and units of the dimension's storage-->
-            <xs:element name="size" type="xs:nonNegativeInteger"></xs:element>
-            <xs:element name="units" type="las:sizeType"></xs:element>
-            <xs:element name="interpretation" type="las:interpretationType">
-                    This element describes how the data should be interpreted.
-                    In the case of conflicting data, for example when then size is 2, the units "byte",
-                    but the interpretation is "uint32_t", the size determines how much
-                    precision is available.
+            <xs:element minOccurs="0" name="interpretation" type="las:interpretationType">
+                <xs:annotation>
+                        This element describes how the data should be
+                        interpreted. In the case of conflicting data, for
+                        example when then size is 2, the units "byte", but the
+                        interpretation is "uint32_t", the size determines how
+                        much precision is available.
+                </xs:annotation>
             </xs:element>
-            <xs:element name="minimum" type="las:rangeType" minOccurs="0">
-                    The minimum value of this dimension.
+            <xs:element minOccurs="0" name="minimum" type="las:rangeType">
+                <xs:annotation>
+                        The minimum value of this dimension.
+                </xs:annotation>
             </xs:element>
-            <xs:element name="maximum" type="las:rangeType">
-                    The maximum value of this dimension.
+            <xs:element minOccurs="0" name="maximum" type="las:rangeType">
+                <xs:annotation>
+                        The maximum value of this dimension.
+                </xs:annotation>
             </xs:element>
-        </xs:sequence>
+            <xs:element minOccurs="0" name="offset" type="xs:double"/>
+                <xs:annotation>
+                        The double offset to use when applying a scaling
+                        factor to an integer dimension
+                </xs:annotation>
+            </xs:element>
+            <xs:element minOccurs="0" name="scale" type="xs:double">
+                <xs:annotation>
+                        The scale (usually a negative log10 exponent) of this
+                        dimension.  Used to support scaled integer types
+                </xs:annotation>
+            </xs:element>
+            <xs:element minOccurs="0" name="byteOffset" type="xs:nonNegativeInteger">
+                <xs:annotation>
+                        The byte offset to start reading this dimension from
+                        the front of the point record.
+                </xs:annotation>
+            </xs:element>
+            <xs:element minOccurs="0" name="bitOffset" type="xs:nonNegativeInteger">
+                <xs:annotation>
+                        The bit offset to start reading this dimension from the
+                        calculated (or specified, using byteOffset) byte offset
+                        of the dimension.
+                </xs:annotation>
+            </xs:element>
+        </xs:all>
     </xs:complexType>
-    <xs:element name="LASSchema" >
+    <xs:element name="LASSchema">
         <xs:complexType>
-            <xs:sequence >
-                <xs:element name="dimension" type="las:dimesionType" minOccurs="1" maxOccurs="unbounded"></xs:element>
+            <xs:sequence>
+                <xs:element maxOccurs="unbounded" minOccurs="1" name="dimension" type="las:dimensionType"/>
             </xs:sequence>
         </xs:complexType>
     </xs:element>
More information about the Liblas-commits mailing list
