[Liblas-commits] hg: reorganize some of the summary stuff
liblas-commits at liblas.org liblas-commits at liblas.org
Sun Oct 10 23:26:06 EDT 2010
changeset 5e45e6abee41 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=5e45e6abee41
summary: reorganize some of the summary stuff
diffstat:
 apps/las2las2.cpp            |  16 +++++++--
 apps/laskernel.cpp           |  47 ++++++++++++++++++------------
 apps/laskernel.hpp           |   5 ++-
 include/liblas/lasheader.hpp |   4 ++
 include/liblas/utility.hpp   |   6 ++-
 src/lasheader.cpp            |  67 +++++++++++++++++++++++--------------------
 src/utility.cpp              |  20 +++++++++++-
 7 files changed, 106 insertions(+), 59 deletions(-)
diffs (truncated from 364 to 300 lines):
diff -r bae716d26b73 -r 5e45e6abee41 apps/las2las2.cpp
--- a/apps/las2las2.cpp	Sun Oct 10 21:05:20 2010 -0500
+++ b/apps/las2las2.cpp	Sun Oct 10 22:25:57 2010 -0500
@@ -151,7 +151,10 @@
             ostringstream old_filename;
             old_filename << out << "-" << fileno - 1 << ".las";
-            RepairHeader(*summary, old_filename.str());
+            liblas::Header hnew = FetchHeader(old_filename.str());
+            RepairHeader(*summary, hnew);
+            RewriteHeader(hnew, old_filename.str());
             delete summary;
             summary =  new liblas::Summary;
             fileno++;
@@ -175,8 +178,10 @@
             delete summary;
             fileno++;
@@ -199,7 +204,10 @@
     delete writer;
     delete ofs;
-    RepairHeader(*summary, output);
+    liblas::Header hnew = FetchHeader(output);
+    RewriteHeader(hnew, output);
     delete summary;
     return true;
diff -r bae716d26b73 -r 5e45e6abee41 apps/laskernel.cpp
--- a/apps/laskernel.cpp	Sun Oct 10 21:05:20 2010 -0500
+++ b/apps/laskernel.cpp	Sun Oct 10 22:25:57 2010 -0500
@@ -99,8 +99,9 @@
     os.precision(prec);
-void RepairHeader(liblas::Summary const& summary, std::string const& filename)
+liblas::Header FetchHeader(std::string const& filename)
     std::ifstream ifs;
     if (!liblas::Open(ifs, filename.c_str()))
@@ -111,11 +112,10 @@
     liblas::Reader reader(ifs);
     liblas::Header header = reader.GetHeader();
     ifs.close();
-    for (boost::uint32_t i = 0; i < 5; i++)
-        header.SetPointRecordsByReturnCount(i, 0);
+    return header;
+void RewriteHeader(liblas::Header const& header, std::string const& filename)
     std::ios::openmode m = std::ios::out | std::ios::in | std::ios::binary | std::ios::ate;
@@ -123,18 +123,33 @@
     std::ofstream ofs(filename.c_str(), m);
     liblas::Writer writer(ofs, header);
     ofs.close();
+    // Write our updated header with summary info
+    std::ofstream ofs2(filename.c_str(), m);
+    liblas::Writer writer2(ofs2, header);
+    ofs2.close();
+void RepairHeader(liblas::Summary const& summary, liblas::Header& header)
+    for (boost::uint32_t i = 0; i < 5; i++)
+        header.SetPointRecordsByReturnCount(i, 0);
     liblas::property_tree::ptree tree = summary.GetPTree();
     try
-        header.SetMin(tree.get<double>("minimum.x"),
-                      tree.get<double>("minimum.y"),
-                      tree.get<double>("minimum.z"));
+        header.SetMin(tree.get<double>("summary.points.minimum.x"),
+                      tree.get<double>("summary.points.minimum.y"),
+                      tree.get<double>("summary.points.minimum.z"));
-        header.SetMax(tree.get<double>("maximum.x"),
-                      tree.get<double>("maximum.y"),
-                      tree.get<double>("maximum.z"));
+        header.SetMax(tree.get<double>("summary.points.maximum.x"),
+                      tree.get<double>("summary.points.maximum.y"),
+                      tree.get<double>("summary.points.maximum.z"));
     }     catch (liblas::property_tree::ptree_bad_path const& e)
@@ -151,7 +166,7 @@
         BOOST_FOREACH(ptree::value_type &v,
-                tree.get_child("points_by_return"))
+                tree.get_child("summary.points.points_by_return"))
             boost::uint32_t i = v.second.get<boost::uint32_t>("id");
             boost::uint32_t count = v.second.get<boost::uint32_t>("count");
@@ -164,12 +179,6 @@
         return;
-    // Write our updated header with summary info
-    std::ofstream ofs2(filename.c_str(), m);
-    liblas::Writer writer2(ofs2, header);
-    ofs2.close();
 bool IsDualRangeFilter(std::string parse_string)
diff -r bae716d26b73 -r 5e45e6abee41 apps/laskernel.hpp
--- a/apps/laskernel.hpp	Sun Oct 10 21:05:20 2010 -0500
+++ b/apps/laskernel.hpp	Sun Oct 10 22:25:57 2010 -0500
@@ -97,6 +97,9 @@
 std::vector<char> TryReadRawFileData(std::string filename);
 bool term_progress(std::ostream& os, double complete);
 void SetStreamPrecision(std::ostream& os, double scale);
-void RepairHeader(liblas::Summary const& summary, std::string const& filename);
+liblas::Header FetchHeader(std::string const& filename);
+void RewriteHeader(liblas::Header const& header, std::string const& filename);
+void RepairHeader(liblas::Summary const& summary, liblas::Header& header);
 #endif // LIBLAS_ITERATOR_HPP_INCLUDED
diff -r bae716d26b73 -r 5e45e6abee41 include/liblas/lasheader.hpp
--- a/include/liblas/lasheader.hpp	Sun Oct 10 21:05:20 2010 -0500
+++ b/include/liblas/lasheader.hpp	Sun Oct 10 22:25:57 2010 -0500
@@ -348,6 +348,10 @@
     /// all of the header data in a structured format.
     liblas::property_tree::ptree GetPTree() const;
+    void to_rst(std::ostream& os) const;
+    void to_xml(std::ostream& os) const;
+    void to_json(std::ostream& os) const;
 private:
     typedef detail::Point<double> PointScales;
diff -r bae716d26b73 -r 5e45e6abee41 include/liblas/utility.hpp
--- a/include/liblas/utility.hpp	Sun Oct 10 21:05:20 2010 -0500
+++ b/include/liblas/utility.hpp	Sun Oct 10 22:25:57 2010 -0500
@@ -70,7 +70,7 @@
     void AddPoint(liblas::Point const& p);
+    void SetHeader(liblas::Header const& h);
 private:
@@ -83,7 +83,9 @@
     boost::array<boost::uint32_t, 8> returns_of_given_pulse;
     bool first;
     liblas::Point min;
-    liblas::Point max;
+    liblas::Point max;
+    liblas::Header m_header;
+    bool bHaveHeader;
 std::ostream& operator<<(std::ostream& os, liblas::Summary const& s);
diff -r bae716d26b73 -r 5e45e6abee41 src/lasheader.cpp
--- a/src/lasheader.cpp	Sun Oct 10 21:05:20 2010 -0500
+++ b/src/lasheader.cpp	Sun Oct 10 22:25:57 2010 -0500
@@ -782,15 +782,14 @@
     return pt;
-std::ostream& operator<<(std::ostream& os, liblas::Header const& h)
+void Header::to_rst(std::ostream& os) const
     using liblas::property_tree::ptree;
-    ptree tree = h.GetPTree();
-    os << "---------------------------------------------------------" << std::endl;
+    ptree tree = GetPTree();
     os << "  Header Summary" << std::endl;
+    os << std::endl;
     os << "  Version:                     " << tree.get<std::string>("version") << std::endl;
     os << "  Source ID:                   " << tree.get<boost::uint32_t>("filesourceid") << std::endl;
@@ -801,60 +800,60 @@
     os << "  File Creation Day/Year:      " << tree.get<std::string>("date") << std::endl;
     os << "  Header Byte Size             " << tree.get<boost::uint32_t>("size") << std::endl;
     os << "  Data Offset:                 " << tree.get<std::string>("dataoffset") << std::endl;
     os << "  Number Var. Length Records:  ";
     try {
-        os << tree.get_child("vlrs").size();
+      os << tree.get_child("vlrs").size();
     catch (liblas::property_tree::ptree_bad_path const& e) {
-        ::boost::ignore_unused_variable_warning(e);
-        os << "None";
+      ::boost::ignore_unused_variable_warning(e);
+      os << "None";
     os << std::endl;
     os << "  Point Data Format:           " << tree.get<boost::uint32_t>("dataformatid") << std::endl;
     os << "  Number of Point Records:     " << tree.get<boost::uint32_t>("count") << std::endl;
     std::ostringstream returns_oss;
-            tree.get_child("returns"))
+          tree.get_child("returns"))
-            returns_oss << v.second.get<std::string>("count")<< " ";
+          returns_oss << v.second.get<std::string>("count")<< " ";
     os << "  Number of Points by Return:  " << returns_oss.str() << std::endl;
     os.setf(std::ios_base::fixed, std::ios_base::floatfield);
     double scale = tree.get<double>("scale.z");
     double frac = 0;
     double integer = 0;
     frac = std::modf(scale, &integer);
     boost::uint32_t prec = static_cast<boost::uint32_t>(std::fabs(std::floor(std::log10(frac))));
     os.precision(prec);
     os << "  Scale Factor X Y Z:          "
-       << tree.get<double>("scale.x") << " "
-       << tree.get<double>("scale.y") << " "
-       << tree.get<double>("scale.x") << std::endl;
+     << tree.get<double>("scale.x") << " "
+     << tree.get<double>("scale.y") << " "
+     << tree.get<double>("scale.z") << std::endl;
     os << "  Offset X Y Z:                "
-       << tree.get<double>("offset.x") << " "
-       << tree.get<double>("offset.y") << " "
-       << tree.get<double>("offset.x") << std::endl;
+     << tree.get<double>("offset.x") << " "
+     << tree.get<double>("offset.y") << " "
+     << tree.get<double>("offset.z") << std::endl;
     os << "  Min X Y Z:                   "
-       << tree.get<double>("minimum.x") << " "
-       << tree.get<double>("minimum.y") << " "
-       << tree.get<double>("minimum.x") << std::endl;
+     << tree.get<double>("minimum.x") << " "
+     << tree.get<double>("minimum.y") << " "
+     << tree.get<double>("minimum.z") << std::endl;
     os << "  Max X Y Z:                   "
+     << tree.get<double>("maximum.x") << " "
+     << tree.get<double>("maximum.y") << " "
+     << tree.get<double>("maximum.z") << std::endl;
     os << "  Spatial Reference:  " << std::endl;
     os << tree.get<std::string>("srs.prettywkt") << std::endl;
     os << tree.get<std::string>("srs.gtiff") << std::endl;
@@ -884,6 +883,12 @@
     // catch (liblas::property_tree::ptree_bad_path const& e) {
     //     ::boost::ignore_unused_variable_warning(e);
+std::ostream& operator<<(std::ostream& os, liblas::Header const& h)
More information about the Liblas-commits mailing list
