[Liblas-commits] hg: update docs to reflect beta release
liblas-commits at liblas.org liblas-commits at liblas.org
Tue Oct 12 21:37:14 EDT 2010
changeset 6e16ffeea5f4 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=6e16ffeea5f4
summary: update docs to reflect beta release
diffstat:
 doc/conf.py                      |   8 ++++----
 doc/development/release_plan.txt |  38 +++++++++++++++++++++++++++++---------
 doc/download.txt                 |   6 +++---
 3 files changed, 36 insertions(+), 16 deletions(-)
diffs (117 lines):
diff -r 754479364728 -r 6e16ffeea5f4 doc/conf.py
--- a/doc/conf.py	Tue Oct 12 20:18:31 2010 -0500
+++ b/doc/conf.py	Tue Oct 12 20:37:08 2010 -0500
@@ -64,18 +64,18 @@
             line = line.replace('SET('+major+' ', '')
             line = line.replace(')','')
             line = line.replace('"','')
-            major = int(line)
+            maj = line.strip()
         if str(minor) in line:
             line = line.replace('SET('+minor+' ', '')
-            minor = int(line)
+            min = line.strip()
         if str(patch) in line:
             line = line.replace('SET('+patch+' ', '')
-            patch = int(line)
-    return '%d.%d.%d'%(major, minor, patch)
+            pat = line.strip()
+    return '%s.%s.%s'%(maj, min, pat)
 version = read_version('../CMakeLists.txt')
diff -r 754479364728 -r 6e16ffeea5f4 doc/development/release_plan.txt
--- a/doc/development/release_plan.txt	Tue Oct 12 20:18:31 2010 -0500
+++ b/doc/development/release_plan.txt	Tue Oct 12 20:37:08 2010 -0500
@@ -7,7 +7,7 @@
 :Author: Howard Butler
 :Contact: hobu.inc at gmail dot com
-:Date: 7/27/2010
+:Date: 10/12/2010
 .. contents::
     :depth: 3
@@ -76,11 +76,24 @@
 Generic spatial indexing
-A octree-based spatial index is being developed for libLAS to speed up random,
-bounding-box-based queries to LAS files. It is expected that this will be
-released as part of libLAS 1.6, but it is not yet complete. The index will be
-able to be stored within VLRs (requires a file rewrite) in addition to in a
-file alongside the .las file.
+A octree-based spatial index was developed for libLAS to speed up random,
+bounding-box-based queries to LAS files. It is released as part of libLAS 1.6,
+but its full implementation within the library is not yet complete. The index
+can store its data within VLRs (requires a file rewrite) in addition to
+in a file alongside the .las file.
+Rewritten :ref:`lasinfo <lasinfo>` and :ref:`las2las <las2las>`
+:ref:`lasinfo <lasinfo>` and :ref:`las2las <las2las>` have been completely
+rewritten to take advantage of faster access and summary methods within the
+libLAS C++ API.  In addition to nearly double the speed of the previous
+libLAS-provided lasinfo and las2las implementations, both applications
+gained a number of features including much more expressive filtering and
+more detailed header and file transformation.  The old versions of :ref:`lasinfo <lasinfo_old>`
+and :ref:`las2las <las2las_old>` are still available to people who have
+embedded them in processes and applications.  They are now called ``lasinfo-old`` and
+``las2las-old``.
 Migration to CMake
@@ -129,6 +142,13 @@
 that are as full as possible, square as possible, and made in a reasonable
 amount of time (chips at a rate of ~1 million points per second).
+Faster binary i/o
+libLAS gained a more savvy implementation for its binary i/o which should
+provide some significant performance improvements.
 Release Schedule
@@ -136,9 +156,9 @@
 The following dates are approximate:
-* Beta 1: 8/20/2010
-* Beta 2: 9/10/2010
-* 1.6.0: 9/30/2010
+* Beta 1: 10/12/2010
+* Beta 2: 11/1/2010
+* 1.6.0: 11/15/2010
 libPC
diff -r 754479364728 -r 6e16ffeea5f4 doc/download.txt
--- a/doc/download.txt	Tue Oct 12 20:18:31 2010 -0500
+++ b/doc/download.txt	Tue Oct 12 20:37:08 2010 -0500
@@ -10,15 +10,15 @@
 * **2010-10-12**
-  - `libLAS-1.6.0b1.tar.gz`_
+  - `libLAS-1.6.0b1-src.tar.gz`_
     `(md5) <http://trac.liblas.org/raw-attachment/wiki/1.6.0b1/libLAS-1.6.0b1.tar.gz.md5>`__
-  - `libLAS-1.6.0b1.zip <http://trac.liblas.org/raw-attachment/wiki/1.6.0b1/libLAS-1.6.0b1.zip>`_
+  - `libLAS-1.6.0b1-src.zip <http://trac.liblas.org/raw-attachment/wiki/1.6.0b1/libLAS-1.6.0b1.zip>`_
     `(md5) <http://trac.liblas.org/raw-attachment/wiki/1.6.0b1/libLAS-1.6.0b1.zip.md5>`__
   - `Release Notes <http://trac.liblas.org/wiki/1.2.1>`__
-.. _`libLAS-1.6.0b1.tar.gz`: http://trac.liblas.org/raw-attachment/wiki/1.6.0b1/libLAS-1.6.0b1.tar.gz
+.. _`libLAS-1.6.0b1-src.tar.gz`: http://trac.liblas.org/raw-attachment/wiki/1.6.0b1/libLAS-1.6.0b1.tar.gz
 .. seealso::
     :ref:`source`
More information about the Liblas-commits mailing list
