[Liblas-commits] hg: 4 new changesets
liblas-commits at liblas.org liblas-commits at liblas.org
Wed Sep 29 22:27:37 EDT 2010
changeset 68bd0acb1061 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=68bd0acb1061
summary: update
changeset da126f61bf05 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=da126f61bf05
summary: update version
changeset 2e16f8ba96c8 in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=2e16f8ba96c8
summary: add link to pdf
changeset 3c918bbc326f in /Volumes/Data/www/liblas.org/hg
details: http://hg.liblas.orghg?cmd=changeset;node=3c918bbc326f
summary: update to sphinx 1.0+ makefile
diffstat:
 doc/Makefile              |  174 ++++++++++++++++++++++++++++-----------------
 doc/conf.py               |    4 +-
 doc/docs.txt              |   12 +++
 doc/utilities/las2oci.txt |   46 ++++-------
 4 files changed, 140 insertions(+), 96 deletions(-)
diffs (truncated from 335 to 300 lines):
diff -r f2c9b18e8e37 -r 3c918bbc326f doc/Makefile
--- a/doc/Makefile	Tue Sep 28 15:31:22 2010 -0500
+++ b/doc/Makefile	Wed Sep 29 21:27:10 2010 -0500
@@ -5,95 +5,137 @@
 SPHINXOPTS    =
 SPHINXBUILD   = sphinx-build
 PAPER         =
+BUILDDIR      = build
 # Internal variables.
 PAPEROPT_a4     = -D latex_paper_size=a4
 PAPEROPT_letter = -D latex_paper_size=letter
-ALLSPHINXOPTS   = -d build/doctrees $(PAPEROPT_$(PAPER)) $(SPHINXOPTS) .
+ALLSPHINXOPTS   = -d $(BUILDDIR)/doctrees $(PAPEROPT_$(PAPER)) $(SPHINXOPTS) .
-.PHONY: html help clean html dirhtml pickle json htmlhelp qthelp latex changes linkcheck doctest
-html:
-	$(SPHINXBUILD) -b html $(ALLSPHINXOPTS) build/html
-	@echo
-	@echo "Build finished. The HTML pages are in build/html."
+.PHONY: help clean html dirhtml singlehtml pickle json htmlhelp qthelp devhelp epub latex latexpdf text man changes linkcheck doctest gettext pdf
 help:
 	@echo "Please use \`make <target>' where <target> is one of"
-	@echo "  html      to make standalone HTML files"
-	@echo "  dirhtml   to make HTML files named index.html in directories"
-	@echo "  pickle    to make pickle files"
-	@echo "  json      to make JSON files"
-	@echo "  htmlhelp  to make HTML files and a HTML help project"
-	@echo "  qthelp    to make HTML files and a qthelp project"
-	@echo "  latex     to make LaTeX files, you can set PAPER=a4 or PAPER=letter"
-	@echo "  changes   to make an overview of all changed/added/deprecated items"
-	@echo "  linkcheck to check all external links for integrity"
-	@echo "  doctest   to run all doctests embedded in the documentation (if enabled)"
+	@echo "  html       to make standalone HTML files"
+	@echo "  dirhtml    to make HTML files named index.html in directories"
+	@echo "  singlehtml to make a single large HTML file"
+	@echo "  pickle     to make pickle files"
+	@echo "  json       to make JSON files"
+	@echo "  htmlhelp   to make HTML files and a HTML help project"
+	@echo "  qthelp     to make HTML files and a qthelp project"
+	@echo "  devhelp    to make HTML files and a Devhelp project"
+	@echo "  epub       to make an epub"
+	@echo "  latex      to make LaTeX files, you can set PAPER=a4 or PAPER=letter"
+	@echo "  latexpdf   to make LaTeX files and run them through pdflatex"
+	@echo "  text       to make text files"
+	@echo "  man        to make manual pages"
+	@echo "  gettext    to make PO message catalogs"
+	@echo "  changes    to make an overview of all changed/added/deprecated items"
+	@echo "  linkcheck  to check all external links for integrity"
+	@echo "  doctest    to run all doctests embedded in the documentation (if enabled)"
 clean:
-	-rm -rf build/*
+	-rm -rf $(BUILDDIR)/*
+html:
+	$(SPHINXBUILD) -b html $(ALLSPHINXOPTS) $(BUILDDIR)/html
+	@echo
+	@echo "Build finished. The HTML pages are in $(BUILDDIR)/html."
 dirhtml:
-	$(SPHINXBUILD) -b dirhtml $(ALLSPHINXOPTS) build/dirhtml
+	$(SPHINXBUILD) -b dirhtml $(ALLSPHINXOPTS) $(BUILDDIR)/dirhtml
 	@echo
-	@echo "Build finished. The HTML pages are in build/dirhtml."
+	@echo "Build finished. The HTML pages are in $(BUILDDIR)/dirhtml."
-doxygen:
-	cd api; doxygen doxygen.conf; cd ..
+singlehtml:
+	$(SPHINXBUILD) -b singlehtml $(ALLSPHINXOPTS) $(BUILDDIR)/singlehtml
 	@echo
-	@echo "Doxygen built"
+	@echo "Build finished. The HTML page is in $(BUILDDIR)/singlehtml."
 pickle:
-	$(SPHINXBUILD) -b pickle $(ALLSPHINXOPTS) build/pickle
+	$(SPHINXBUILD) -b pickle $(ALLSPHINXOPTS) $(BUILDDIR)/pickle
 	@echo
 	@echo "Build finished; now you can process the pickle files."
 json:
-	$(SPHINXBUILD) -b json $(ALLSPHINXOPTS) build/json
+	$(SPHINXBUILD) -b json $(ALLSPHINXOPTS) $(BUILDDIR)/json
 	@echo
 	@echo "Build finished; now you can process the JSON files."
+htmlhelp:
+	$(SPHINXBUILD) -b htmlhelp $(ALLSPHINXOPTS) $(BUILDDIR)/htmlhelp
+	@echo
+	@echo "Build finished; now you can run HTML Help Workshop with the" \
+	      ".hhp project file in $(BUILDDIR)/htmlhelp."
+qthelp:
+	$(SPHINXBUILD) -b qthelp $(ALLSPHINXOPTS) $(BUILDDIR)/qthelp
+	@echo
+	@echo "Build finished; now you can run "qcollectiongenerator" with the" \
+	      ".qhcp project file in $(BUILDDIR)/qthelp, like this:"
+	@echo "# qcollectiongenerator $(BUILDDIR)/qthelp/df.qhcp"
+	@echo "To view the help file:"
+	@echo "# assistant -collectionFile $(BUILDDIR)/qthelp/df.qhc"
+devhelp:
+	$(SPHINXBUILD) -b devhelp $(ALLSPHINXOPTS) $(BUILDDIR)/devhelp
+	@echo
+	@echo "Build finished."
+	@echo "# mkdir -p $$HOME/.local/share/devhelp/df"
+	@echo "# ln -s $(BUILDDIR)/devhelp $$HOME/.local/share/devhelp/df"
+	@echo "# devhelp"
+epub:
+	$(SPHINXBUILD) -b epub $(ALLSPHINXOPTS) $(BUILDDIR)/epub
+	@echo
+	@echo "Build finished. The epub file is in $(BUILDDIR)/epub."
+latex:
+	$(SPHINXBUILD) -b latex $(ALLSPHINXOPTS) $(BUILDDIR)/latex
+	@echo
+	@echo "Build finished; the LaTeX files are in $(BUILDDIR)/latex."
+	@echo "Run \`make' in that directory to run these through (pdf)latex" \
+	      "(use \`make latexpdf' here to do that automatically)."
+latexpdf:
+	@echo "Running LaTeX files through pdflatex..."
+	make -C $(BUILDDIR)/latex all-pdf
+	@echo "pdflatex finished; the PDF files are in $(BUILDDIR)/latex."
+text:
+	$(SPHINXBUILD) -b text $(ALLSPHINXOPTS) $(BUILDDIR)/text
+	@echo
+	@echo "Build finished. The text files are in $(BUILDDIR)/text."
+man:
+	$(SPHINXBUILD) -b man $(ALLSPHINXOPTS) $(BUILDDIR)/man
+	@echo
+	@echo "Build finished. The manual pages are in $(BUILDDIR)/man."
+gettext:
+	$(SPHINXBUILD) -b gettext $(ALLSPHINXOPTS) $(BUILDDIR)/locale
+	@echo
+	@echo "Build finished. The message catalogs are in $(BUILDDIR)/locale."
+changes:
+	$(SPHINXBUILD) -b changes $(ALLSPHINXOPTS) $(BUILDDIR)/changes
+	@echo
+	@echo "The overview file is in $(BUILDDIR)/changes."
+linkcheck:
+	$(SPHINXBUILD) -b linkcheck $(ALLSPHINXOPTS) $(BUILDDIR)/linkcheck
+	@echo
+	@echo "Link check complete; look for any errors in the above output " \
+	      "or in $(BUILDDIR)/linkcheck/output.txt."
+doctest:
+	$(SPHINXBUILD) -b doctest $(ALLSPHINXOPTS) $(BUILDDIR)/doctest
+	@echo "Testing of doctests in the sources finished, look at the " \
+	      "results in $(BUILDDIR)/doctest/output.txt."
 pdf:
 	$(SPHINXBUILD) -b pdf $(ALLSPHINXOPTS) build/pdf
 	@echo
-	@echo "Build finished; now you can process the PDF files."
-htmlhelp:
-	$(SPHINXBUILD) -b htmlhelp $(ALLSPHINXOPTS) build/htmlhelp
-	@echo
-	@echo "Build finished; now you can run HTML Help Workshop with the" \
-	      ".hhp project file in build/htmlhelp."
-qthelp:
-	$(SPHINXBUILD) -b qthelp $(ALLSPHINXOPTS) build/qthelp
-	@echo
-	@echo "Build finished; now you can run "qcollectiongenerator" with the" \
-	      ".qhcp project file in build/qthelp, like this:"
-	@echo "# qcollectiongenerator build/qthelp/libLAS.qhcp"
-	@echo "To view the help file:"
-	@echo "# assistant -collectionFile build/qthelp/libLAS.qhc"
-latex:
-	$(SPHINXBUILD) -b latex $(ALLSPHINXOPTS) build/latex
-	@echo
-	@echo "Build finished; the LaTeX files are in build/latex."
-	@echo "Run \`make all-pdf' or \`make all-ps' in that directory to" \
-	      "run these through (pdf)latex."
-changes:
-	$(SPHINXBUILD) -b changes $(ALLSPHINXOPTS) build/changes
-	@echo
-	@echo "The overview file is in build/changes."
-linkcheck:
-	$(SPHINXBUILD) -b linkcheck $(ALLSPHINXOPTS) build/linkcheck
-	@echo
-	@echo "Link check complete; look for any errors in the above output " \
-	      "or in build/linkcheck/output.txt."
-doctest:
-	$(SPHINXBUILD) -b doctest $(ALLSPHINXOPTS) build/doctest
-	@echo "Testing of doctests in the sources finished, look at the " \
-	      "results in build/doctest/output.txt."
+	@echo "Build finished; now you can process the PDF files."
\ No newline at end of file
diff -r f2c9b18e8e37 -r 3c918bbc326f doc/conf.py
--- a/doc/conf.py	Tue Sep 28 15:31:22 2010 -0500
+++ b/doc/conf.py	Wed Sep 29 21:27:10 2010 -0500
@@ -51,9 +51,9 @@
 # built documents.
 # The short X.Y version.
-version = '1.3.0'
+version = '1.6.0'
 # The full version, including alpha/beta/rc tags.
-release = '1.3.0'
+release = '1.6.0'
 # The language for content autogenerated by Sphinx. Refer to documentation
 # for a list of supported languages.
diff -r f2c9b18e8e37 -r 3c918bbc326f doc/docs.txt
--- a/doc/docs.txt	Tue Sep 28 15:31:22 2010 -0500
+++ b/doc/docs.txt	Wed Sep 29 21:27:10 2010 -0500
@@ -4,6 +4,18 @@
 libLAS Documentation
+.. note::
+    The entire documentation is also available as a single
+    `PDF document <./libLAS.pdf>`__ |image|  and `ePub document <./libLAS.epub>`__
+.. include:: ./include/docnav.inc
+.. |image| image:: ./../_static/pdf.png
+   :height: 15
+   :width: 15
+   :alt: PDF icon
+   :target: /pdf/libLAS.pdf
 .. toctree::
    :maxdepth: 2
diff -r f2c9b18e8e37 -r 3c918bbc326f doc/utilities/las2oci.txt
--- a/doc/utilities/las2oci.txt	Tue Sep 28 15:31:22 2010 -0500
+++ b/doc/utilities/las2oci.txt	Wed Sep 29 21:27:10 2010 -0500
@@ -28,7 +28,7 @@
 :ref:`las2oci` is a command-line utility that allows you to ingest a
 .las file into Oracle.
+.. code-block:: text
         las2oci (libLAS 1.6.0 with GeoTIFF 1.3.0 GDAL 1.8dev)
@@ -87,37 +87,24 @@
                                        (PC_EXTENT, BLK_EXTENT,
                                        USER_SDO_GEOM_METADATA) entries
       --global-extent arg              Extent window to define for the PC_EXTENT.
-                                       Use a comma-separated list, for example,
-                                         --global-extent minx, miny, maxx, maxy
+                                       Use a list, for example,
+                                         --global-extent minx miny maxx maxy
                                          or
-                                         --global-extent minx, miny, minz, maxx,
-                                       maxy, maxz
+                                         --global-extent minx miny minz maxx maxy
+                                       maxz
       --cached                         Cache the entire file on the first read
     Transformation options:
-      --a_srs arg           Coordinate system to assign to input LAS file
       --t_srs arg           Coordinate system to reproject output LAS file to.  Use
                             --a_srs or verify that your input LAS file has a
                             coordinate system according to lasinfo
-      --offset arg          A comma-separated list of offsets to set on the output
-                            file:
-                            --offset 0,0,0
-                            --offset  min,min,min
-      --scale arg           A comma-separated list of scales to set on the output
-                            file:
-                            --scale 0.1,0.1,0.00001
-      -f [ --format ] arg   Set the LAS format of the new file (only 1.0-1.2
-                            supported at this time):
-                            --format 1.2
-                            -f 1.1
-      --pad-header arg      Add extra bytes to the existing header
     Filtering options:
       -e [ --extent ] arg    Extent window that points must fall within to keep.
-                               -e minx, miny, maxx, maxy
+                             For example,
+                               -e minx miny maxx maxy
                                or
-                               -e minx, miny, minz, maxx, maxy, maxz
+                               -e minx miny minz maxx maxy maxz
       -t [ --thin ] arg (=0) Simple decimation-style thinning.
More information about the Liblas-commits mailing list
