[Liblas-commits] hg-main-tree: add more schema stuff
liblas-commits at liblas.org liblas-commits at liblas.org
Fri Apr 15 17:21:39 EDT 2011
details:   http://hg.libpc.orghg-main-tree/rev/307852e07825
changeset: 575:307852e07825
user:      Howard Butler <hobu.inc at gmail.com>
date:      Fri Apr 15 16:20:11 2011 -0500
description:
Subject: hg-main-tree: start adding Cloud object definition
details:   http://hg.libpc.orghg-main-tree/rev/f7f09599e595
changeset: 576:f7f09599e595
date:      Fri Apr 15 16:20:35 2011 -0500
description:
details:   http://hg.libpc.orghg-main-tree/rev/c78348feab7e
changeset: 577:c78348feab7e
date:      Fri Apr 15 16:21:04 2011 -0500
description:
Subject: hg-main-tree: turn off table creation/deletion for now
details:   http://hg.libpc.orghg-main-tree/rev/19627e75c829
changeset: 578:19627e75c829
date:      Fri Apr 15 16:21:21 2011 -0500
description:
Subject: hg-main-tree: merge
details:   http://hg.libpc.orghg-main-tree/rev/1db3464d27dd
changeset: 579:1db3464d27dd
date:      Fri Apr 15 16:21:31 2011 -0500
description:
merge
diffstat:
 include/libpc/drivers/oci/Common.hpp |   11 +-
 include/libpc/drivers/oci/Schema.hpp |   13 ++-
 src/drivers/oci/Reader.cpp           |   30 +++++-
 src/drivers/oci/Schema.cpp           |   29 +++++-
 src/drivers/oci/common.cpp           |   20 +++
 test/unit/CMakeLists.txt             |   45 +++++++-
 test/unit/ChipperTest.cpp            |    4 +-
 test/unit/LiblasReaderTest.cpp       |  143 ++++++---------------------
 test/unit/LiblasWriterTest.cpp       |   12 +-
 test/unit/OCITest.cpp                |   58 ++++++----
 test/unit/Support.cpp                |  181 +++++++++++++++++++++++++++++++++++
 test/unit/Support.hpp                |   80 +++++++++++++++
 test/unit/TestConfig.cpp             |   54 ++++++++++
 test/unit/TestConfig.hpp             |   48 +++++++++
 test/unit/main.cpp                   |    7 +-
 test/unit/support.cpp                |  106 --------------------
 test/unit/support.hpp                |   58 -----------
 17 files changed, 577 insertions(+), 322 deletions(-)
diffs (truncated from 1396 to 300 lines):
diff -r f16753970cbd -r 1db3464d27dd include/libpc/drivers/oci/Common.hpp
--- a/include/libpc/drivers/oci/Common.hpp	Fri Apr 15 15:37:04 2011 -0500
+++ b/include/libpc/drivers/oci/Common.hpp	Fri Apr 15 16:21:31 2011 -0500
@@ -60,7 +60,7 @@
 typedef boost::shared_ptr<OWStatement> Statement ;
-// use this for code still under development
 class connection_failed : public libpc_error
 public:
@@ -69,7 +69,6 @@
 class buffer_too_small : public libpc_error
 public:
@@ -78,6 +77,14 @@
+class schema_error : public libpc_error
+public:
+    schema_error(std::string const& msg)
+        : libpc_error(msg)
 #ifdef LIBPC_COMPILER_MSVC
 #define compare_no_case(a,b,n)  _strnicmp( (a), (b), (n) )
diff -r f16753970cbd -r 1db3464d27dd include/libpc/drivers/oci/Schema.hpp
--- a/include/libpc/drivers/oci/Schema.hpp	Fri Apr 15 15:37:04 2011 -0500
+++ b/include/libpc/drivers/oci/Schema.hpp	Fri Apr 15 16:21:31 2011 -0500
@@ -45,15 +45,21 @@
 #include <libxml/parser.h>
 #include <libxml/xmlschemas.h>
+#include <libxml/parser.h>
+#include <libxml/tree.h>
+#include <libxml/xinclude.h>
+#include <libxml/xmlIO.h>
 namespace libpc { namespace drivers { namespace oci {
+void OCISchemaGenericErrorHandler (void * userData, xmlErrorPtr error);
+void OCISchemaStructuredErrorHandler (void * userData, xmlErrorPtr error);
 class Schema
 public:
-    Schema();
+    Schema(std::string xml, std::string xmlschema);
     ~Schema();
@@ -62,6 +68,9 @@
     Schema& operator=(const Schema&); // not implemented
     Schema(const Schema&); // not implemented;
+    xmlDocPtr m_doc;
+    xmlDocPtr m_schema;
diff -r f16753970cbd -r 1db3464d27dd src/drivers/oci/Reader.cpp
--- a/src/drivers/oci/Reader.cpp	Fri Apr 15 15:37:04 2011 -0500
+++ b/src/drivers/oci/Reader.cpp	Fri Apr 15 16:21:31 2011 -0500
@@ -63,7 +63,19 @@
     m_querytype = describeQueryType();
-    m_block = defineBlock();
+    if (m_querytype == QUERY_SDO_PC_BLK)
+        m_block = defineBlock();
+    else if (m_querytype == QUERY_SDO_PC)
+        m_cloud = defineCloud();
+        throw libpc_error("not yet implemented");
+    else
+        throw libpc_error("SQL statement does not define a SDO_PC or CLIP_CP block");
     registerFields();
@@ -345,6 +357,22 @@
     return block;
+CloudPtr Reader::defineCloud()
+    CloudPtr cloud = CloudPtr(new Cloud(m_connection));
+    m_connection->CreateType(&m_pc);
+    m_statement->Define(&(m_pc));
+    bool bDidRead = m_statement->Fetch();
+    std::cout << "block_table_name: " << m_statement->GetString(m_pc->blk_table);
+    return cloud;
 libpc::SequentialIterator* Reader::createSequentialIterator() const
diff -r f16753970cbd -r 1db3464d27dd src/drivers/oci/Schema.cpp
--- a/src/drivers/oci/Schema.cpp	Fri Apr 15 15:37:04 2011 -0500
+++ b/src/drivers/oci/Schema.cpp	Fri Apr 15 16:21:31 2011 -0500
@@ -37,17 +37,40 @@
 #include <libpc/Utils.hpp>
 #include <sstream>
-#include <map>
-#include <algorithm>
-Schema::Schema()
+    (void * userData, xmlErrorPtr error)
+    std::ostringstream oss;
+    oss << "Generic XML error: '" << error->message <<"' ";
+    oss << "on line " << error->line;
+    throw schema_error(oss.str());
+Schema::Schema(std::string xml, std::string xmlschema)
     LIBXML_TEST_VERSION
+    // No network access
+    // http://xmlsoft.org/html/libxml-parser.html#xmlParserOption
+    m_doc = xmlReadMemory(&(xml[0]), xml.size(), "noname.xml", NULL, XML_PARSE_NONET);
+    if (m_doc == NULL) {
+        throw schema_error("Failed to parse document");
     return;
diff -r f16753970cbd -r 1db3464d27dd src/drivers/oci/common.cpp
--- a/src/drivers/oci/common.cpp	Fri Apr 15 15:37:04 2011 -0500
+++ b/src/drivers/oci/common.cpp	Fri Apr 15 16:21:31 2011 -0500
@@ -154,6 +154,26 @@
     // causes a segfault
     // m_connection->DestroyType(&blk_extent);
+Cloud::Cloud(Connection connection)
+    : schema(new std::vector<boost::uint8_t>)
+    , m_connection(connection)
+    m_connection->CreateType(&pc_geometry);
+    m_connection->CreateType(&pc_geometry->sdo_ordinates, m_connection->GetOrdinateType());
+    m_connection->CreateType(&pc_geometry->sdo_elem_info, m_connection->GetElemInfoType());
+    m_connection->CreateType(&pc_domain);
+Cloud::~Cloud()
+    // FIXME: For some reason having the dtor destroy this
+    // causes a segfault
+    // m_connection->DestroyType(&blk_extent);
 std::string to_upper(const std::string& input)
     std::string inp = std::string(input);
diff -r f16753970cbd -r 1db3464d27dd test/unit/CMakeLists.txt
--- a/test/unit/CMakeLists.txt	Fri Apr 15 15:37:04 2011 -0500
+++ b/test/unit/CMakeLists.txt	Fri Apr 15 16:21:31 2011 -0500
@@ -7,7 +7,7 @@
 SET(LIBPC_UNIT_TEST libpc_test)
-SET(LIBPC_UNIT_TEST_SRC
+SET(LIBPC_UNITTEST_TEST_SRC
     BoundsTest.cpp
     CacheFilterTest.cpp
     ChipperTest.cpp
@@ -31,27 +31,60 @@
     SignallerTest.cpp
     UtilsTest.cpp
     VectorTest.cpp
-    support.cpp
-    support.hpp
-    main.cpp)
+SET(LIBPC_UNITTEST_TEST_INC
+SET(LIBPC_UNITTEST_CONFIG_SRC
+    Support.cpp
+    TestConfig.cpp
+    main.cpp
+SET(LIBPC_UNITTEST_CONFIG_INC
+    Support.hpp
+    TestConfig.hpp
 if (WITH_ORACLE)
     set(LIBPC_OCI_TEST_CPP OCITest.cpp)
     FOREACH(file ${LIBPC_OCI_TEST_CPP})
-            SET(LIBPC_UNIT_TEST_SRC "${LIBPC_UNIT_TEST_SRC};${file}" CACHE INTERNAL "source files for test")
+            SET(LIBPC_UNITTEST_TEST_SRC "${LIBPC_UNITTEST_TEST_SRC};${file}" CACHE INTERNAL "source files for test")
     ENDFOREACH(file)
 endif (WITH_ORACLE)
+set(LIBPC_UNITTEST_SOURCES "")
+FOREACH(file ${LIBPC_UNITTEST_TEST_SRC})
+        SET(LIBPC_UNITTEST_SOURCES "${LIBPC_UNITTEST_SOURCES};${file}" CACHE INTERNAL "source files for test")
+ENDFOREACH(file)
+FOREACH(file ${LIBPC_UNITTEST_TEST_INC})
+ENDFOREACH(file)
+FOREACH(file ${LIBPC_UNITTEST_CONFIG_SRC})
+ENDFOREACH(file)
+FOREACH(file ${LIBPC_UNITTEST_CONFIG_INC})
+ENDFOREACH(file)
+source_group("Header Files" FILES ${LIBPC_UNITTEST_TEST_INC})
+source_group("Header Files\\config" FILES ${LIBPC_UNITTEST_CONFIG_INC})
+source_group("Source Files" FILES ${LIBPC_UNITTEST_TEST_SRC})
+source_group("Source Files\\config" FILES ${LIBPC_UNITTEST_CONFIG_SRC})
 INCLUDE_DIRECTORIES(
     ../../include
     ${GDAL_INCLUDE_DIR}
     ${GEOTIFF_INCLUDE_DIR})
-ADD_EXECUTABLE(${LIBPC_UNIT_TEST} ${LIBPC_UNIT_TEST_SRC} )
+ADD_EXECUTABLE(${LIBPC_UNIT_TEST} ${LIBPC_UNITTEST_SOURCES})
 set_target_properties(${LIBPC_UNIT_TEST} PROPERTIES COMPILE_DEFINITIONS LIBPC_DLL_IMPORT)
diff -r f16753970cbd -r 1db3464d27dd test/unit/ChipperTest.cpp
--- a/test/unit/ChipperTest.cpp	Fri Apr 15 15:37:04 2011 -0500
+++ b/test/unit/ChipperTest.cpp	Fri Apr 15 16:21:31 2011 -0500
@@ -39,7 +39,7 @@
 #include <libpc/drivers/liblas/Writer.hpp>
 #include <libpc/drivers/liblas/Reader.hpp>
-#include "support.hpp"
+#include "Support.hpp"
 using namespace libpc;
 using namespace libpc::drivers::liblas;
@@ -49,7 +49,7 @@
 BOOST_AUTO_TEST_CASE(test_construction)
-    LiblasReader reader(TestConfig::g_data_path + "1.2-with-color.las");
+    LiblasReader reader(Support::datapath("1.2-with-color.las"));
         const boost::uint64_t num_points = reader.getNumPoints();
diff -r f16753970cbd -r 1db3464d27dd test/unit/LiblasReaderTest.cpp
--- a/test/unit/LiblasReaderTest.cpp	Fri Apr 15 15:37:04 2011 -0500
+++ b/test/unit/LiblasReaderTest.cpp	Fri Apr 15 16:21:31 2011 -0500
@@ -40,7 +40,7 @@
 #include <libpc/SchemaLayout.hpp>
More information about the Liblas-commits mailing list
