[Liblas-commits] hg-main-tree: start on some OCI schema stuff
liblas-commits at liblas.org liblas-commits at liblas.org
Wed Apr 20 12:07:33 EDT 2011
details:   http://hg.libpc.orghg-main-tree/rev/806dbd76fd4d
changeset: 598:806dbd76fd4d
user:      Howard Butler <hobu.inc at gmail.com>
date:      Wed Apr 20 08:27:59 2011 -0500
description:
Subject: hg-main-tree: add operator < and > for sorting
details:   http://hg.libpc.orghg-main-tree/rev/31501e5ca8db
changeset: 599:31501e5ca8db
date:      Wed Apr 20 09:42:15 2011 -0500
description:
Subject: hg-main-tree: xml parsing for generating libpc::Dimension entries
details:   http://hg.libpc.orghg-main-tree/rev/2c3eb32cb4ff
changeset: 600:2c3eb32cb4ff
date:      Wed Apr 20 11:07:00 2011 -0500
description:
Subject: hg-main-tree: make sure to seek to end of file before reading data
details:   http://hg.libpc.orghg-main-tree/rev/1f15fd317a8a
changeset: 601:1f15fd317a8a
date:      Wed Apr 20 11:07:20 2011 -0500
description:
diffstat:
 include/libpc/DimensionLayout.hpp    |    9 +
 include/libpc/drivers/oci/Common.hpp |   26 ++
 include/libpc/drivers/oci/Schema.hpp |   42 +++-
 src/drivers/las/Writer.cpp           |    1 -
 src/drivers/oci/Schema.cpp           |  387 ++++++++++++++++++++++++++++++++++-
 test/unit/OCITest.cpp                |    4 +-
 6 files changed, 456 insertions(+), 13 deletions(-)
diffs (truncated from 603 to 300 lines):
diff -r 8a9807af8582 -r 1f15fd317a8a include/libpc/DimensionLayout.hpp
--- a/include/libpc/DimensionLayout.hpp	Mon Apr 18 21:27:51 2011 -0700
+++ b/include/libpc/DimensionLayout.hpp	Wed Apr 20 11:07:20 2011 -0500
@@ -93,6 +93,15 @@
         m_position = v;
+    inline bool operator < (DimensionLayout const& dim) const
+        return m_position < dim.m_position;
+    inline bool operator > (DimensionLayout const& dim) const
+        return m_position > dim.m_position;
 private:
     Dimension m_dimension;
     std::size_t m_byteOffset;
diff -r 8a9807af8582 -r 1f15fd317a8a include/libpc/drivers/oci/Common.hpp
--- a/include/libpc/drivers/oci/Common.hpp	Mon Apr 18 21:27:51 2011 -0700
+++ b/include/libpc/drivers/oci/Common.hpp	Wed Apr 20 11:07:20 2011 -0500
@@ -85,6 +85,32 @@
+class schema_validation_error : public libpc_error
+public:
+    schema_validation_error(std::string const& msg)
+        : libpc_error(msg)
+class schema_parsing_error : public libpc_error
+public:
+    schema_parsing_error(std::string const& msg)
+class schema_generic_error : public libpc_error
+public:
+    schema_generic_error(std::string const& msg)
 #ifdef LIBPC_COMPILER_MSVC
 #define compare_no_case(a,b,n)  _strnicmp( (a), (b), (n) )
diff -r 8a9807af8582 -r 1f15fd317a8a include/libpc/drivers/oci/Schema.hpp
--- a/include/libpc/drivers/oci/Schema.hpp	Mon Apr 18 21:27:51 2011 -0700
+++ b/include/libpc/drivers/oci/Schema.hpp	Wed Apr 20 11:07:20 2011 -0500
@@ -36,12 +36,17 @@
 #define INCLUDED_DRIVERS_OCI_SCHEMA_HPP
 #include <libpc/libpc.hpp>
+#include <libpc/Schema.hpp>
+#include <libpc/SchemaLayout.hpp>
+#include <libpc/Dimension.hpp>
+#include <libpc/DimensionLayout.hpp>
 #include <libpc/drivers/oci/Common.hpp>
 #include <libpc/drivers/oci/Reader.hpp>
 #include <string>
 #include <stdarg.h>
+#include <functional>
 #include <libxml/parser.h>
 #include <libxml/xmlschemas.h>
@@ -51,6 +56,10 @@
 #include <libxml/xinclude.h>
 #include <libxml/xmlIO.h>
+#include <boost/shared_ptr.hpp>
+#include <boost/concept_check.hpp>
+#include <boost/function.hpp>
 namespace libpc { namespace drivers { namespace oci {
@@ -60,17 +69,44 @@
 class LIBPC_DLL Schema
 public:
-    Schema(std::string xml, std::string xmlschema);
+    Schema(std::string const& xml, std::string const& xmlschema);
     ~Schema();
+protected:
+    void LoadSchema();
+    Dimension::DataType GetDimensionType(std::string const& interpretation);
+    Dimension::Field GetDimensionField(std::string const& name, position);
 private:
     Schema& operator=(const Schema&); // not implemented
     Schema(const Schema&); // not implemented;
-    xmlDocPtr m_doc;
-    xmlDocPtr m_schema;
+    // We're going to put all of our libxml2 primatives into shared_ptrs
+    // that have custom deleters that clean up after themselves so we
+    // have a good chance at having clean exception-safe code
+    typedef boost::shared_ptr<void> DocPtr;
+    typedef boost::shared_ptr<void> SchemaParserCtxtPtr;
+    typedef boost::shared_ptr<void> SchemaPtr;
+    typedef boost::shared_ptr<void> SchemaValidCtxtPtr;
+    DocPtr m_doc;
+    DocPtr m_schema_doc;
+    SchemaParserCtxtPtr m_schema_parser_ctx;
+    SchemaPtr m_schema_ptr;
+    SchemaValidCtxtPtr m_schema_valid_ctx;
+    xmlParserOption m_doc_options;
+    void* m_global_context;
+    libpc::Schema m_schema;
diff -r 8a9807af8582 -r 1f15fd317a8a src/drivers/las/Writer.cpp
--- a/src/drivers/las/Writer.cpp	Mon Apr 18 21:27:51 2011 -0700
+++ b/src/drivers/las/Writer.cpp	Wed Apr 20 11:07:20 2011 -0500
@@ -143,7 +143,6 @@
     std::cout.setf(std::ios_base::fixed, std::ios_base::floatfield);
     std::cout.precision(8);
-    std::cout << "scale: " << dimX.getNumericScale() <<" " << dimY.getNumericScale() << " " << dimZ.getNumericScale() << std::endl;
     boost::uint32_t cnt = static_cast<boost::uint32_t>(m_targetNumPointsToWrite);
     m_lasHeader.SetPointRecordsCount(cnt);
diff -r 8a9807af8582 -r 1f15fd317a8a src/drivers/oci/Schema.cpp
--- a/src/drivers/oci/Schema.cpp	Mon Apr 18 21:27:51 2011 -0700
+++ b/src/drivers/oci/Schema.cpp	Wed Apr 20 11:07:20 2011 -0500
@@ -37,6 +37,46 @@
 #include <libpc/Utils.hpp>
 #include <sstream>
+#include <iostream>
+#include <list>
+#include <cstdlib>
+struct XMLDocDeleter
+   template <typename T>
+   void operator()(T* ptr)
+       ::xmlFreeDoc(ptr);
+struct SchemaParserCtxDeleter
+       ::xmlSchemaFreeParserCtxt(ptr);
+struct SchemaDeleter
+       ::xmlSchemaFree(ptr);
+struct SchemaValidCtxtDeleter
+       ::xmlSchemaFreeValidCtxt(ptr);
@@ -49,10 +89,86 @@
     std::ostringstream oss;
     oss << "XML error: '" << error->message <<"' ";
+    if (error->str1)
+        oss << " extra info1: '" << error->str1 << "' ";
+    if (error->str2)
+        oss << " extra info2: '" << error->str2 << "' ";
+    if (error->str3)
+        oss << " extra info3: '" << error->str3 << "' ";
     oss << "on line " << error->line;
+    if (error->ctxt)
+        xmlParserCtxtPtr ctxt = (xmlParserCtxtPtr) error->ctxt;
+        xmlParserInputPtr input = ctxt->input;
+        xmlParserPrintFileContext(input);
     throw schema_error(oss.str());
+void OCISchemaParserStructuredErrorHandler
+    (void * userData, xmlErrorPtr error)
+    std::ostringstream oss;
+    oss << "Schema parsing error: '" << error->message <<"' ";
+    oss << "on line " << error->line;
+    throw schema_parsing_error(oss.str());
+void OCISchemaValidationStructuredErrorHandler
+    oss << "Schema validation error: '" << error->message <<"' ";
+    throw schema_validation_error(oss.str());
+void OCISchemaValidityError
+    (void * ctx, const char* message, ... )
+    const int ERROR_MESSAGE_SIZE = 256;
+    char error[ERROR_MESSAGE_SIZE];
+    va_list arg_ptr;
+    va_start(arg_ptr, message);
+    vsnprintf(error, ERROR_MESSAGE_SIZE, message, arg_ptr);
+    va_end(arg_ptr);
+    oss << "Schema valididy error: '" << error <<"' ";
+void OCISchemaValidityDebug
+    va_list arg_ptr;
+    va_end(arg_ptr);
+    oss << "Schema validity debug: '" << error <<"' ";
+    std::cout << oss.str() << std::endl;
 void OCISchemaGenericErrorHandler
@@ -69,28 +185,65 @@
     oss << "Generic error: '" << error <<"' ";
-    throw schema_error(oss.str());
+    throw schema_generic_error(oss.str());
-Schema::Schema(std::string xml, std::string xmlschema)
+// XML_PARSE_NONET No network access
+// http://xmlsoft.org/html/libxml-parser.html#xmlParserOption
+Schema::Schema(std::string const& xml, std::string const &xsd)
+: m_doc_options(XML_PARSE_NONET)
More information about the Liblas-commits mailing list
