[Liblas-commits] hg-main-tree: update comment about getName
liblas-commits at liblas.org liblas-commits at liblas.org
Tue Apr 26 11:36:44 EDT 2011
details:   http://hg.libpc.orghg-main-tree/rev/093224cac503
changeset: 652:093224cac503
user:      Howard Butler <hobu.inc at gmail.com>
date:      Tue Apr 26 10:20:08 2011 -0500
description:
Subject: hg-main-tree: a little more work on Options
details:   http://hg.libpc.orghg-main-tree/rev/5e725be08a10
changeset: 653:5e725be08a10
date:      Tue Apr 26 10:20:32 2011 -0500
description:
diffstat:
 include/libpc/Options.hpp |  39 +++++++++++++++++++++++++++++++++++++--
 include/libpc/Stage.hpp   |   6 ++++--
 2 files changed, 41 insertions(+), 4 deletions(-)
diffs (73 lines):
diff -r 22692e3985f2 -r 5e725be08a10 include/libpc/Options.hpp
--- a/include/libpc/Options.hpp	Tue Apr 26 08:16:36 2011 -0500
+++ b/include/libpc/Options.hpp	Tue Apr 26 10:20:32 2011 -0500
@@ -43,6 +43,38 @@
 namespace libpc
+template <typename T>
+class LIBPC_DLL Option
+private:
+    T m_value;
+    std::string m_description;
+    std::string m_name;
+public:
+    Option(std::string const& name, T value, std::string const& description)
+    : m_value(value), m_description(description), m_name(name) {}
+    std::string const& getName() const { return m_name; }
+    std::string const& getDescription() const { return m_description; }
+    T const& getValue() const { return m_value; }
+    boost::property_tree::ptree& getTree() const
+        boost::property_tree::ptree t;
+        t.put("description", getDescription());
+        t.put("value", getValue());
+        boost::property_tree::ptree output;
+        output.put_child(getName(), t);
+        return output;
 class LIBPC_DLL Options
@@ -52,9 +84,12 @@
 public:
     Options();
+    Options(boost::property_tree::ptree const& tree) { m_tree = tree; }
+    template<class T> void add(Option<T> const& option) { m_tree.put_child(option.getTree()); }
+    template<class T> Option<T> const& get(std::string const& name) { return m_tree.get<T>(name); }
-    boost::property_tree::ptree& GetPTree() {return m_tree; }
-    boost::property_tree::ptree const& GetPTree() const {return m_tree; }
+    boost::property_tree::ptree& GetPTree() { return m_tree; }
+    boost::property_tree::ptree const& GetPTree() const { return m_tree; }
diff -r 22692e3985f2 -r 5e725be08a10 include/libpc/Stage.hpp
--- a/include/libpc/Stage.hpp	Tue Apr 26 08:16:36 2011 -0500
+++ b/include/libpc/Stage.hpp	Tue Apr 26 10:20:32 2011 -0500
@@ -61,8 +61,10 @@
     virtual ~Stage();
     // Implement this in your concrete classes to return a constant string
-    // as the name of the stage.  Use upper camel case, with spaces between
-    // words.  The last word should generally be "Reader" or "Filter".
+    // as the name of the stage.  Use a dotted, XPath-style name for your
+    // stage.  For example, 'drivers.las.reader' or 'filters.crop'.  This
+    // XPath-style name will also correspond to an entry in the libpc::Options
+    // tree for the given stage.
     virtual const std::string& getName() const = 0;
     virtual const std::string& getDescription() const = 0;
More information about the Liblas-commits mailing list
