[Liblas-commits] hg: whitespace normalization
liblas-commits at liblas.org liblas-commits at liblas.org
Tue Apr 26 13:00:35 EDT 2011
details:   http://hg.liblas.orghg/rev/76a43764654c
changeset: 2930:76a43764654c
user:      Howard Butler <hobu.inc at gmail.com>
date:      Tue Apr 26 12:00:13 2011 -0500
description:
Subject: hg: make sure last char is null
details:   http://hg.liblas.orghg/rev/89021b2ceb00
changeset: 2931:89021b2ceb00
date:      Tue Apr 26 12:00:26 2011 -0500
description:
diffstat:
 apps/las2oci.cpp          |  3 ++-
 include/liblas/bounds.hpp |  2 +-
 2 files changed, 3 insertions(+), 2 deletions(-)
diffs (26 lines):
diff -r 8bdd8c592d18 -r 89021b2ceb00 apps/las2oci.cpp
--- a/apps/las2oci.cpp	Fri Apr 22 12:40:10 2011 -0500
+++ b/apps/las2oci.cpp	Tue Apr 26 12:00:26 2011 -0500
@@ -550,8 +550,9 @@
     OCILobLocator* boundary_locator ;
     if (bHaveSchemaOverride)
-        char* schema = (char*) malloc(point_schema_override.size() * sizeof(char));
+        char* schema = (char*) malloc(point_schema_override.size() * sizeof(char) + 1);
         strncpy(schema, point_schema_override.c_str(), point_schema_override.size());
+        schema[point_schema_override.size()] = '\0';
         statement->WriteCLob( &schema_locator, schema );
         statement->Bind(&schema_locator);
diff -r 8bdd8c592d18 -r 89021b2ceb00 include/liblas/bounds.hpp
--- a/include/liblas/bounds.hpp	Fri Apr 22 12:40:10 2011 -0500
+++ b/include/liblas/bounds.hpp	Tue Apr 26 12:00:26 2011 -0500
@@ -68,7 +68,7 @@
     T minimum;
     T maximum;
-	typedef T value_type;
+    typedef T value_type;
     Range(T mmin=(std::numeric_limits<T>::max)(), T mmax=(std::numeric_limits<T>::min)())
         : minimum(mmin), maximum(mmax) {}
More information about the Liblas-commits mailing list
