[Liblas-commits] hg-main-tree: clean up write-chunk loops, and try to reuse the s...
liblas-commits at liblas.org liblas-commits at liblas.org
Tue Aug 2 19:48:28 EDT 2011
details:   http://hg.libpc.orghg-main-tree/rev/74075102dd6e
changeset: 998:74075102dd6e
user:      Michael P. Gerlek <mpg at flaxen.com>
date:      Tue Aug 02 16:48:13 2011 -0700
description:
clean up write-chunk loops, and try to reuse the same PointBuffer
diffstat:
 src/Writer.cpp |  80 +++++++++++++++++++++++++++++++++++++++------------------
 1 files changed, 54 insertions(+), 26 deletions(-)
diffs (125 lines):
diff -r a7909cd12dca -r 74075102dd6e src/Writer.cpp
--- a/src/Writer.cpp	Tue Aug 02 16:18:44 2011 -0700
+++ b/src/Writer.cpp	Tue Aug 02 16:48:13 2011 -0700
@@ -41,6 +41,10 @@
 #include <pdal/PointBuffer.hpp>
 #include <pdal/exceptions.hpp>
+#ifdef PDAL_COMPILER_MSVC
+#  pragma warning(disable: 4127)  // conditional expression is constant
+#endif
 namespace pdal
@@ -111,60 +115,84 @@
     iter->readBegin();
-    // in case targetNumPointsToWrite is really big, we will process just one chunk at a time
-    if (targetNumPointsToWrite == 0)
+    if (m_targetNumPointsToWrite == 0)
+        // user has requested 0 points, which means "as many as is available":
+        // proceed a chunk at a time until we reach the end
         PointBuffer buffer(m_prevStage.getSchema(), m_chunkSize);
-        iter->readBufferBegin(buffer);
-        boost::uint32_t numPointsReadThisChunk = iter->readBuffer(buffer);
-        iter->readBufferEnd(buffer);
-        boost::uint32_t numPointsWrittenThisChunk = 0;
-        while (numPointsReadThisChunk != 0)
+        while (true)
+            // have we done enough yet?
+            if (iter->atEnd()) break;
+            // read...
+            iter->readBufferBegin(buffer);
+            const boost::uint32_t numPointsReadThisChunk = iter->readBuffer(buffer);
+            iter->readBufferEnd(buffer);
+            // have we reached the end yet?
+            if (numPointsReadThisChunk == 0) break;
+            // write...
             writeBufferBegin(buffer);
-            numPointsWrittenThisChunk = writeBuffer(buffer);
+            const boost::uint32_t numPointsWrittenThisChunk = writeBuffer(buffer);
             writeBufferEnd(buffer);
+            // update count
             m_actualNumPointsWritten += numPointsWrittenThisChunk;
-            buffer.setNumPoints(0); // reset the buffer, so we can use it again
+            // reset the buffer, so we can use it again
+            buffer.setNumPoints(0);
+    else
+        // user has requested a specific number of points:
+        // proceed a chunk at a time until we reach that number
+        PointBuffer buffer(m_prevStage.getSchema(), m_chunkSize);
+        while (true)
-            numPointsReadThisChunk = iter->readBuffer(buffer);
-    } else
-        while (m_actualNumPointsWritten < m_targetNumPointsToWrite)
             const boost::uint64_t numRemainingPointsToRead = m_targetNumPointsToWrite - m_actualNumPointsWritten;
             const boost::uint64_t numPointsToReadThisChunk64 = std::min<boost::uint64_t>(numRemainingPointsToRead, m_chunkSize);
             // this case is safe because m_chunkSize is a uint32
             const boost::uint32_t numPointsToReadThisChunk = static_cast<boost::uint32_t>(numPointsToReadThisChunk64);
-            PointBuffer buffer(m_prevStage.getSchema(), numPointsToReadThisChunk);
+            // we are reusing the buffer, so we may need to adjust the capacity for the last (and likely undersized) chunk
+            if (buffer.getCapacity() != numPointsToReadThisChunk)
+                buffer = PointBuffer(m_prevStage.getSchema(), numPointsToReadThisChunk);
+            // read...
             assert(numPointsReadThisChunk <= numPointsToReadThisChunk);
+            // write...
             assert(numPointsWrittenThisChunk == numPointsReadThisChunk);
+            // update count
-            if (iter->atEnd())
-                break;
+            if (m_actualNumPointsWritten >= m_targetNumPointsToWrite) break;
More information about the Liblas-commits mailing list
