[Liblas-commits] hg-main-tree: move schema modification into initialize() method ...
liblas-commits at liblas.org liblas-commits at liblas.org
Thu Aug 11 11:39:21 EDT 2011
details:   http://hg.libpc.orghg-main-tree/rev/ea00b6f9de63
changeset: 1033:ea00b6f9de63
user:      Howard Butler <hobu.inc at gmail.com>
date:      Thu Aug 11 10:39:17 2011 -0500
description:
move schema modification into initialize() method so that chipper-specific fields such as block_id and point_id are added
diffstat:
 src/filters/Chipper.cpp |  10 ++++------
 1 files changed, 4 insertions(+), 6 deletions(-)
diffs (41 lines):
diff -r e9a4b3aaf365 -r ea00b6f9de63 src/filters/Chipper.cpp
--- a/src/filters/Chipper.cpp	Thu Aug 11 08:52:06 2011 -0500
+++ b/src/filters/Chipper.cpp	Thu Aug 11 10:39:17 2011 -0500
@@ -96,8 +96,6 @@
     pdal::Schema const& schema = buffer.getSchema();
     boost::int32_t size = m_right - m_left + 1;
     if (size < 0)
         throw pdal_error("m_right - m_left + 1 was less than 0 in Block::GetBuffer()!");
@@ -145,9 +143,6 @@
     m_threshold = options.getValueOrThrow<boost::uint32_t>("capacity");
-    checkImpedance();
-    setPointCountType(PointCount_Fixed);
-    setNumPoints(0);
@@ -155,6 +150,10 @@
     Filter::initialize();
+    checkImpedance();
+    setPointCountType(PointCount_Fixed);
+    setNumPoints(0);
     return;
@@ -499,7 +498,6 @@
         schema.addDimension(blockID);
-    // std::cout << schema << std::endl;
     return;
More information about the Liblas-commits mailing list
