[Liblas-commits] hg-main-tree: fix comment
liblas-commits at liblas.org liblas-commits at liblas.org
Fri Aug 12 12:42:11 EDT 2011
details:   http://hg.libpc.orghg-main-tree/rev/812381915e9d
changeset: 1061:812381915e9d
user:      Michael P. Gerlek <mpg at flaxen.com>
date:      Fri Aug 12 09:41:58 2011 -0700
description:
fix comment
diffstat:
 apps/Application.cpp |  2 +-
 1 files changed, 1 insertions(+), 1 deletions(-)
diffs (12 lines):
diff -r af3c273a58c0 -r 812381915e9d apps/Application.cpp
--- a/apps/Application.cpp	Fri Aug 12 09:40:55 2011 -0700
+++ b/apps/Application.cpp	Fri Aug 12 09:41:58 2011 -0700
@@ -204,7 +204,7 @@
     basic_options->add_options()
         ("help,h", "produce help message")
         ("debug,d", po::value<bool>(&m_isDebug)->zero_tokens(), "Enable debug mode")
-        ("verbose,v", po::value<boost::uint32_t>(&m_verboseLevel)->default_value(0), "Set verbose message level (default is 0)")
+        ("verbose,v", po::value<boost::uint32_t>(&m_verboseLevel)->default_value(0), "Set verbose message level")
         ("version", "Show version info")
         ("timer", "Show execution time")
More information about the Liblas-commits mailing list
