[Liblas-commits] hg-main-tree: gcc 4.5.2 linker issue
liblas-commits at liblas.org liblas-commits at liblas.org
Mon Aug 15 10:15:22 EDT 2011
details:   http://hg.libpc.orghg-main-tree/rev/8522c2999b57
changeset: 1087:8522c2999b57
user:      mpg
date:      Mon Aug 15 06:43:50 2011 -0700
description:
Subject: hg-main-tree: gcc lint
details:   http://hg.libpc.orghg-main-tree/rev/796b179c92df
changeset: 1088:796b179c92df
user:      mpg
date:      Mon Aug 15 07:12:43 2011 -0700
description:
gcc lint
diffstat:
 include/pdal/drivers/las/VariableLengthRecord.hpp |  2 +-
 src/drivers/las/LasHeaderReader.cpp               |  4 ++--
 src/drivers/las/VariableLengthRecord.cpp          |  1 +
 test/unit/ByteSwapFilterTest.cpp                  |  4 ++++
 test/unit/ChipperTest.cpp                         |  4 ++++
 test/unit/FauxReaderTest.cpp                      |  5 +++++
 test/unit/QFITReaderTest.cpp                      |  4 ++++
 test/unit/ReprojectionFilterTest.cpp              |  3 ++-
 test/unit/ScalingFilterTest.cpp                   |  4 ++++
 test/unit/Support.cpp                             |  7 +++++++
 test/unit/TerraSolidTest.cpp                      |  5 +++++
 11 files changed, 39 insertions(+), 4 deletions(-)
diffs (175 lines):
diff -r 91c4509b5ec5 -r 796b179c92df include/pdal/drivers/las/VariableLengthRecord.hpp
--- a/include/pdal/drivers/las/VariableLengthRecord.hpp	Sun Aug 14 22:06:34 2011 -0500
+++ b/include/pdal/drivers/las/VariableLengthRecord.hpp	Mon Aug 15 07:12:43 2011 -0700
@@ -82,7 +82,7 @@
     std::size_t getLength() const;
     std::size_t getTotalSize() const;
-    static const int s_headerLength = 54;
+    static const int s_headerLength;
     static void setSRSFromVLRs(const std::vector<VariableLengthRecord>& vlrs, SpatialReference& srs);
     static void setVLRsFromSRS(const SpatialReference& srs, std::vector<VariableLengthRecord>& vlrs, SpatialReference::WKTModeFlag modeFlag);
diff -r 91c4509b5ec5 -r 796b179c92df src/drivers/las/LasHeaderReader.cpp
--- a/src/drivers/las/LasHeaderReader.cpp	Sun Aug 14 22:06:34 2011 -0500
+++ b/src/drivers/las/LasHeaderReader.cpp	Mon Aug 15 07:12:43 2011 -0700
@@ -342,9 +342,9 @@
     std::string description = "";
-        boost::uint8_t buf1[pdal::drivers::las::VariableLengthRecord::s_headerLength];
+        boost::scoped_ptr<boost::uint8_t> buf1( new boost::uint8_t[pdal::drivers::las::VariableLengthRecord::s_headerLength]);
         Utils::read_n(buf1, m_istream, pdal::drivers::las::VariableLengthRecord::s_headerLength);
-        boost::uint8_t* p1 = buf1;
+        boost::uint8_t* p1 = buf1.get();
         reserved = Utils::read_field<boost::uint16_t>(p1);
         boost::ignore_unused_variable_warning(reserved);
diff -r 91c4509b5ec5 -r 796b179c92df src/drivers/las/VariableLengthRecord.cpp
--- a/src/drivers/las/VariableLengthRecord.cpp	Sun Aug 14 22:06:34 2011 -0500
+++ b/src/drivers/las/VariableLengthRecord.cpp	Mon Aug 15 07:12:43 2011 -0700
@@ -55,6 +55,7 @@
 static const boost::uint16_t s_wktRecordId = 2112;
 static const std::string s_wktDescription = "OGR variant of OpenGIS WKT SRS";
+const int VariableLengthRecord::s_headerLength = 54;
 VariableLengthRecord::VariableLengthRecord(boost::uint16_t reserved,
                                            std::string userId,
diff -r 91c4509b5ec5 -r 796b179c92df test/unit/ByteSwapFilterTest.cpp
--- a/test/unit/ByteSwapFilterTest.cpp	Sun Aug 14 22:06:34 2011 -0500
+++ b/test/unit/ByteSwapFilterTest.cpp	Mon Aug 15 07:12:43 2011 -0700
@@ -45,6 +45,10 @@
 #include <pdal/Endian.hpp>
 #include <iostream>
+#ifdef PDAL_COMPILER_GCC
+#pragma GCC diagnostic ignored "-Wfloat-equal"
+#endif
 using namespace pdal;
 BOOST_AUTO_TEST_SUITE(ByteSwapFilterTest)
diff -r 91c4509b5ec5 -r 796b179c92df test/unit/ChipperTest.cpp
--- a/test/unit/ChipperTest.cpp	Sun Aug 14 22:06:34 2011 -0500
+++ b/test/unit/ChipperTest.cpp	Mon Aug 15 07:12:43 2011 -0700
@@ -42,6 +42,10 @@
 #include "Support.hpp"
+#endif
 BOOST_AUTO_TEST_SUITE(ChipperTest)
diff -r 91c4509b5ec5 -r 796b179c92df test/unit/FauxReaderTest.cpp
--- a/test/unit/FauxReaderTest.cpp	Sun Aug 14 22:06:34 2011 -0500
+++ b/test/unit/FauxReaderTest.cpp	Mon Aug 15 07:12:43 2011 -0700
@@ -42,6 +42,11 @@
 #include <iostream>
+#pragma GCC diagnostic ignored "-Wsign-compare"
+#endif
 BOOST_AUTO_TEST_SUITE(FauxReaderTest)
diff -r 91c4509b5ec5 -r 796b179c92df test/unit/QFITReaderTest.cpp
--- a/test/unit/QFITReaderTest.cpp	Sun Aug 14 22:06:34 2011 -0500
+++ b/test/unit/QFITReaderTest.cpp	Mon Aug 15 07:12:43 2011 -0700
@@ -45,6 +45,10 @@
 #include <iostream>
+#endif
 BOOST_AUTO_TEST_SUITE(QfitReaderTest)
diff -r 91c4509b5ec5 -r 796b179c92df test/unit/ReprojectionFilterTest.cpp
--- a/test/unit/ReprojectionFilterTest.cpp	Sun Aug 14 22:06:34 2011 -0500
+++ b/test/unit/ReprojectionFilterTest.cpp	Mon Aug 15 07:12:43 2011 -0700
@@ -49,6 +49,8 @@
 BOOST_AUTO_TEST_SUITE(ReprojectionFilterTest)
+#ifdef PDAL_SRS_ENABLED
 static void getPoint(const pdal::PointBuffer& data, double& x, double& y, double& z, double scaleX, double scaleY, double scaleZ)
@@ -70,7 +72,6 @@
     return;
-#ifdef PDAL_SRS_ENABLED
 // Test reprojecting UTM 15 to DD with a filter
 BOOST_AUTO_TEST_CASE(ReprojectionFilterTest_test_1)
diff -r 91c4509b5ec5 -r 796b179c92df test/unit/ScalingFilterTest.cpp
--- a/test/unit/ScalingFilterTest.cpp	Sun Aug 14 22:06:34 2011 -0500
+++ b/test/unit/ScalingFilterTest.cpp	Mon Aug 15 07:12:43 2011 -0700
@@ -46,6 +46,10 @@
+#endif
 BOOST_AUTO_TEST_SUITE(ScalingFilterTest)
diff -r 91c4509b5ec5 -r 796b179c92df test/unit/Support.cpp
--- a/test/unit/Support.cpp	Sun Aug 14 22:06:34 2011 -0500
+++ b/test/unit/Support.cpp	Mon Aug 15 07:12:43 2011 -0700
@@ -51,6 +51,11 @@
 #include <pdal/exceptions.hpp>
 #include "TestConfig.hpp"
+//#pragma GCC diagnostic ignored "-Wsign-compare"
+#endif
 std::string Support::datapath()
@@ -416,6 +421,7 @@
+#ifdef PDAL_COMPILER_MSVC
 // http://www.codepedia.com/1/CppStringReplace
 static std::string replaceAll(std::string result,
                               const std::string& replaceWhat,
@@ -429,6 +435,7 @@
     return result;
+#endif
 int Support::run_command(const std::string& rawcmd, std::string& output)
diff -r 91c4509b5ec5 -r 796b179c92df test/unit/TerraSolidTest.cpp
--- a/test/unit/TerraSolidTest.cpp	Sun Aug 14 22:06:34 2011 -0500
+++ b/test/unit/TerraSolidTest.cpp	Mon Aug 15 07:12:43 2011 -0700
@@ -45,6 +45,11 @@
 #include <iostream>
+#endif
 BOOST_AUTO_TEST_SUITE(TerraSolidReaderTest)
More information about the Liblas-commits mailing list
