[Liblas-commits] hg-main-tree: add some app tests that actually work
liblas-commits at liblas.org
Mon Aug 15 15:22:09 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/4c606c33b9c6
changeset: 1098:4c606c33b9c6
user: mpg
date: Mon Aug 15 12:21:54 2011 -0700
description:
diffstat:
test/unit/pc2pcTest.cpp | 18 +++++++++++++++++-
test/unit/pcinfoTest.cpp | 18 +++++++++++++++++-
test/unit/pcpipelineTest.cpp | 19 ++++++++++++++++++-
3 files changed, 52 insertions(+), 3 deletions(-)
diffs (101 lines):
diff -r 19e41307eaa8 -r 4c606c33b9c6 test/unit/pc2pcTest.cpp
--- a/test/unit/pc2pcTest.cpp Mon Aug 15 12:15:08 2011 -0700
+++ b/test/unit/pc2pcTest.cpp Mon Aug 15 12:21:54 2011 -0700
@@ -53,7 +53,7 @@
#ifdef PDAL_COMPILER_MSVC
-BOOST_AUTO_TEST_CASE(pc2pcTest_test1)
+BOOST_AUTO_TEST_CASE(pc2pcTest_test_no_input)
const std::string cmd = appName();
@@ -68,4 +68,20 @@
#endif
+BOOST_AUTO_TEST_CASE(pc2pcTest_test_common_opts)
+ const std::string cmd = appName();
+ std::string output;
+ int stat = Support::run_command(cmd + " -h", output);
+ BOOST_CHECK_EQUAL(stat, 0);
+ stat = Support::run_command(cmd + " --version", output);
+ return;
BOOST_AUTO_TEST_SUITE_END()
diff -r 19e41307eaa8 -r 4c606c33b9c6 test/unit/pcinfoTest.cpp
--- a/test/unit/pcinfoTest.cpp Mon Aug 15 12:15:08 2011 -0700
+++ b/test/unit/pcinfoTest.cpp Mon Aug 15 12:21:54 2011 -0700
@@ -53,7 +53,7 @@
-BOOST_AUTO_TEST_CASE(pcinfoTest_1)
+BOOST_AUTO_TEST_CASE(pcinfoTest_no_input)
@@ -68,5 +68,21 @@
#endif
+BOOST_AUTO_TEST_CASE(pcinfo_test_common_opts)
+ return;
diff -r 19e41307eaa8 -r 4c606c33b9c6 test/unit/pcpipelineTest.cpp
--- a/test/unit/pcpipelineTest.cpp Mon Aug 15 12:15:08 2011 -0700
+++ b/test/unit/pcpipelineTest.cpp Mon Aug 15 12:21:54 2011 -0700
@@ -53,7 +53,7 @@
-BOOST_AUTO_TEST_CASE(pcpipelineTest_1)
+BOOST_AUTO_TEST_CASE(pcpipelineTest_no_input)
@@ -68,4 +68,21 @@
#endif
+BOOST_AUTO_TEST_CASE(pcpipelineTest_test_common_opts)
+ return;
More information about the Liblas-commits
