[Liblas-commits] libpc: attempt to answer some questions and fill in more stuff
liblas-commits at liblas.org liblas-commits at liblas.org
Fri Feb 4 12:02:00 EST 2011
details:   http://hg.liblas.orglibpc/rev/114842894daf
changeset: 2:114842894daf
user:      Howard Butler <hobu.inc at gmail.com>
date:      Fri Feb 04 11:01:53 2011 -0600
description:
diffstat:
 doc/notes/apps.txt   |  24 ++++++++++++++++++++----
 doc/notes/goals.txt  |   2 +-
 doc/notes/io.txt     |  15 +++++++++++++++
 doc/notes/misc.txt   |  40 +++++++++++++++++++++++++++-------------
 doc/notes/stages.txt |  13 +++++++++++--
 5 files changed, 74 insertions(+), 20 deletions(-)
diffs (222 lines):
diff -r b909e7ef42a9 -r 114842894daf doc/notes/apps.txt
--- a/doc/notes/apps.txt	Thu Feb 03 15:37:07 2011 -0800
+++ b/doc/notes/apps.txt	Fri Feb 04 11:01:53 2011 -0600
@@ -14,6 +14,10 @@
 Converts from one file format to another, optionally with some (relatively
 simple) filtering or processing.
+Input format detection should reside in the app, not in the library.  There
+will be no equivalent meta GDALOpen-like function to do this work for you.
+Too expensive and too easy to screw up.
 pcinfo
@@ -28,10 +32,16 @@
 * summary statistics about the points
+* the plain text format should be reStructured text if possible to allow
+  a user to retransform the output into whatever they want with ease
+* the xml format needs an XSD or XMLSchema for validation.
 The dump should go the stdout, but options should be provided to dump to
 XML or similar, where it makes sense to do so.
 pcview
@@ -40,19 +50,25 @@
 wants to do something too.
 pcindex
-Creates a spatial index for a point cloud.  (Could be moved into pc2pc.)
+Creates a serialized spatial index for a point cloud. First pass at this
+is to repurpose liblas::Index which supports serialization.
 pcmosaic
-Merges multiple files together.  (Could be moved into pc2pc.)
+Merges multiple files together.
+Does mosaic imply something that merge doesn't?
-pcdemosaic
+pctile
-Chops one file up into multiple files.  (Could be moved into pc2pc.)
+Chops one file up into multiple files.  This could be the liblas::Chipper,
+leaf nodes of an index like an R-tree, or a simple quadtree build.
diff -r b909e7ef42a9 -r 114842894daf doc/notes/goals.txt
--- a/doc/notes/goals.txt	Thu Feb 03 15:37:07 2011 -0800
+++ b/doc/notes/goals.txt	Fri Feb 04 11:01:53 2011 -0600
@@ -12,7 +12,7 @@
 2. It is a library which provides APIs for reading, writing, and processing
    point cloud data of various formats.  As GDAL is to 2D pixels, libPC is
-   to 3D points.
+   to xD points.
 3. It has high performance, yet remains flexible.  We recognize that
    these two goals will conflict at times and will weigh the tradeoffs
diff -r b909e7ef42a9 -r 114842894daf doc/notes/io.txt
--- a/doc/notes/io.txt	Thu Feb 03 15:37:07 2011 -0800
+++ b/doc/notes/io.txt	Fri Feb 04 11:01:53 2011 -0600
@@ -9,12 +9,27 @@
 * Is C's unix-style I/O generally faster/slower/same-as C++'s stream-style
   I/O?
+  They should be equivalent if used "right".  Mateusz did a bunch of work
+  on this last summer to check for comparison.  std::fstream was found to be
+  sensitive to setting its buffer, but that was it.
 * Are boost's streams any faster than the native compiler's streams?
+No.  Boost's streams provide a consistent interface to the native compiler's
+streams.  They also provide additional functionality like a gzip stream, etc.
 * Is it worth providing our own simple unix-style binary stream interface,
   which we use internally, and then letting the choice of underlying
   implementation be made up at the app level?  (LizardTech does this.
   Maybe GDAL too sometimes?)
+  I'd rather offload this to boost's iostreams if we can.  What do we
+  get for the extra pain of adding another layer here?  Can we have the boost
+  take on the maintenance of this layer for us?
 * Do we want to spend some time investigating this issue up front?
+  libLAS does not use boost's streams because it didn't have the boost
+  dependency until later in its life.  To do it again, I would assume boost
+  was in the mix and would use boost's iostreams by default.
diff -r b909e7ef42a9 -r 114842894daf doc/notes/misc.txt
--- a/doc/notes/misc.txt	Thu Feb 03 15:37:07 2011 -0800
+++ b/doc/notes/misc.txt	Fri Feb 04 11:01:53 2011 -0600
@@ -41,20 +41,24 @@
 libPC will use these libraries:
-* GDAL - for spatial reference support (and rasterization)
-* Boost - for C++ library needs, such as streams or parsers
+* Boost - for C++ library needs, such as streams or parsers (required)
-* laszip - for compressed LAS support
+* libxml2 - Schema description, validation, and serialization (required)
-* MrSID - for LizardTech's MG4 lidar format
+* GDAL - for spatial reference support (and rasterization) (optional)
-* Oracle - ...?
+* libLAS - for LAS (compressed if available to libLAS) support. (optional)
+* MrSID - for LizardTech's MG4 lidar format (optional)
+* Oracle - OCI (optional)
+* libspatialindex - Rtree support, maybe quadtree if someone implements it for libspatialindex (optional)
 * *others?*
-Some of these libraries may be required (such as Boost); some may be
-configurable at build time, such as laszip.
+Some of these libraries may be required (such as Boost).
 Project Dependencies - Builds/Infrastructure
@@ -95,11 +99,11 @@
 We will support these platforms initially, corresponding to what the
 developers are using regularly:
-* Windows - VS2010 (32- and 64-bit)
+* Windows - VS2010 (32- and 64-bit) - 2008 32-bit
-* Linux - *gcc x.y?*
+* Linux - gcc 4.x+
-* Mac - *stuff*
+* Mac - gcc 4.0.1+
 By virtue of CMake, other platforms may be supported such as VS 2008 or
 Solaris, but we aren't targeting those specifically.
@@ -123,10 +127,16 @@
 * filenames must match class name
-* *layout/organization of source tree?*
+* *layout/organization of source tree?*
+    public headers in ./include
+    private headers alongside source files in src/
-* *use of namespaces?*
+* *use of namespaces?* (copy boost)
+    libpc::
+    libpc::detail::
 libPC Position on (Non)conformance
@@ -152,6 +162,10 @@
 option would never be the default behavior, however.
 *We should also have a guiding principle about files that are conformant but
-which lie, such as the extents in the header being wrong.  Specifically, is
+which lie, such as the extents in the header being wrong.
+Specifically, is
 our default path to propagate the wrong info or to helpfully correct it on
 the fly?*
+    Do both, but more often than not try to helpfully correct it.
diff -r b909e7ef42a9 -r 114842894daf doc/notes/stages.txt
--- a/doc/notes/stages.txt	Thu Feb 03 15:37:07 2011 -0800
+++ b/doc/notes/stages.txt	Fri Feb 04 11:01:53 2011 -0600
@@ -21,7 +21,11 @@
 * MrSID/MG4
-* Oracle database
+* Oracle Point Cloud
+* BAG, Fledermaus, other bathy formats
+* Pointools?
 * Auto - creates points randomly, or as a constant pattern; used only for
   testing
@@ -40,7 +44,9 @@
 * MrSID/MG4
-* Oracle database
 * Null - dumps output to /dev/null; used only for testing
@@ -59,6 +65,9 @@
 * Cache - maintains points in memory, only reaching "behind" to the previous
   stage if the point needed is not in the cache
+* Expression engine - "classification=3;0<=x<=100"
+* Transformation engine - "intensity=classification * 2; x = x*3.2808399"
More information about the Liblas-commits mailing list
