[Liblas-commits] libpc: copied from liblas
liblas-commits at liblas.org liblas-commits at liblas.org
Wed Feb 9 23:14:57 EST 2011
details:   http://hg.liblas.orglibpc/rev/d440e67b1c4b
changeset: 23:d440e67b1c4b
user:      Michael P. Gerlek <mpg at flaxen.com>
date:      Wed Feb 09 19:08:06 2011 -0800
description:
copied from liblas
Subject: libpc: obsolete
details:   http://hg.liblas.orglibpc/rev/9a232f70e1a8
changeset: 24:9a232f70e1a8
date:      Wed Feb 09 19:49:50 2011 -0800
description:
obsolete
Subject: libpc: starting to turn on cmake builds
details:   http://hg.liblas.orglibpc/rev/3bacf3c7db9e
changeset: 25:3bacf3c7db9e
date:      Wed Feb 09 20:07:18 2011 -0800
description:
Subject: libpc: unix name fix
details:   http://hg.liblas.orglibpc/rev/67e919879ba4
changeset: 26:67e919879ba4
date:      Wed Feb 09 20:14:17 2011 -0800
description:
unix name fix
Subject: libpc: comment everything out for now
details:   http://hg.liblas.orglibpc/rev/c60e5261cfc2
changeset: 27:c60e5261cfc2
date:      Wed Feb 09 20:14:32 2011 -0800
description:
diffstat:
 .hgignore                              |   11 +
 CMakeLists.txt                         |  856 ++++++++++++++++----------------
 apps/CMakeLists.txt                    |  133 +++++
 apps/pc2pc.cpp                         |  387 ++++++++++++++
 apps/pcinfo.cpp                        |  302 +++++++++++
 mpg-config.bat                         |   38 +-
 prototype.sln                          |   25 -
 src/CMakeLists.txt                     |  127 ++++
 src/PointLayout.cpp                    |    6 +-
 src/main.cpp                           |   92 ---
 test/CMakeLists.txt                    |    8 +
 test/data/1.2-with-color.las           |    0
 test/data/1.2-with-color.laz           |    0
 test/unit/CMakeLists.txt               |   32 +
 test/unit/libpc_test.hpp               |   18 +
 test/unit/libpc_test_suite.cpp         |   53 ++
 test/unit/tut/README                   |  516 +++++++++++++++++++
 test/unit/tut/tut.hpp                  |  572 ++++++++++++++++++++++
 test/unit/tut/tut_assert.hpp           |  306 +++++++++++
 test/unit/tut/tut_config.hpp           |    6 +
 test/unit/tut/tut_console_reporter.hpp |  274 ++++++++++
 test/unit/tut/tut_exception.hpp        |  237 +++++++++
 test/unit/tut/tut_posix.hpp            |  485 ++++++++++++++++++
 test/unit/tut/tut_reporter.hpp         |   11 +
 test/unit/tut/tut_restartable.hpp      |  410 +++++++++++++++
 test/unit/tut/tut_result.hpp           |  174 ++++++
 test/unit/tut/tut_runner.hpp           |  388 ++++++++++++++
 test/unit/zipreader_test.cpp           |   38 +
 28 files changed, 4925 insertions(+), 580 deletions(-)
diffs (truncated from 5660 to 300 lines):
diff -r 615db25be65b -r c60e5261cfc2 .hgignore
--- a/.hgignore	Wed Feb 09 12:33:36 2011 -0800
+++ b/.hgignore	Wed Feb 09 20:14:32 2011 -0800
@@ -3,11 +3,22 @@
 # rst outputs
 *.pdf
+# cmake stuff
+CMakeCache.txt
+CMakeFiles/
+CPackConfig.cmake
+CPackSourceConfig.cmake
+cmake_install.cmake
+CTestTestfile.cmake
 # visual studio cruft
 Debug/
 ipch/
+*.sln
+*.vcxproj
 *.vcxproj.filters
 *.vcxproj.user
+*.vcproj.*.user
 *.sdf
 *.suo
 *.opensdf
diff -r 615db25be65b -r c60e5261cfc2 CMakeLists.txt
--- a/CMakeLists.txt	Wed Feb 09 12:33:36 2011 -0800
+++ b/CMakeLists.txt	Wed Feb 09 20:14:32 2011 -0800
@@ -1,438 +1,418 @@
-# Main CMake configuration file for libLAS
-# Author: Mateusz Loskot <mateusz at loskot.net>
-# libLAS general settings
-project(libLAS)
-SET(LIBLAS_VERSION_MAJOR "1")
-SET(LIBLAS_VERSION_MINOR "6")
-SET(LIBLAS_VERSION_PATCH "0")
-set(VERSION "${LIBLAS_VERSION_MAJOR}.${LIBLAS_VERSION_MINOR}.${LIBLAS_VERSION_PATCH}")
-SET(LIBLAS_LIB_SOVERSION "2.0.0")
-SET(LIBLAS_C_LIB_SOVERSION "2.0.0")
-SET(OSGEO4W_UPSTREAM_RELEASE "1")
-if(WIN32)
-  # Name of C++ library
-  set(LIBLAS_LIB_NAME liblas)
-  # Name of C library
-  set(LIBLAS_C_LIB_NAME liblas_c)
-  # Name of Chipper library
-  set(LASCHIP_LIB_NAME liblas_chipper )
-  # Name of Kernel libray
-  set(LASKERNEL_LIB_NAME liblas_kernel )
-else()
-  set(LIBLAS_LIB_NAME las)
-  set(LIBLAS_C_LIB_NAME las_c)
-  set(LASCHIP_LIB_NAME las_chipper )
-  set(LASKERNEL_LIB_NAME las_kernel )
-endif()
-# Name of test suite runner
-set(LIBLAS_UNIT_TEST liblas_test)
-set(CMAKE_INCLUDE_DIRECTORIES_PROJECT_BEFORE ON)
-# Choose package components
-set(WITH_UTILITIES TRUE CACHE BOOL "Choose if libLAS utilities should be built")
-set(WITH_TESTS TRUE CACHE BOOL "Choose if libLAS unit tests should be built")
-# Choose to use pkg-config or not
-set(WITH_PKGCONFIG FALSE CACHE BOOL
-  "Choose whether a pkgconfig file (libLAS.pc) should be installed")
-set(WITH_ENDIANAWARE FALSE CACHE BOOL "Choose whether or not libLAS should do runtime endianness switching.  Note that this can slow things down considerably if enabled by default")
-# Enable CTest and submissions to libLAS dashboard at CDash
-# http://my.cdash.org/index.php?project=libLAS
-set(ENABLE_CTEST FALSE CACHE BOOL
-  "Enable CTest to support submissions of results to CDash at http://cdash.org")
-# CMake settings
-cmake_minimum_required(VERSION 2.6.0)
-set(CMAKE_COLOR_MAKEFILE ON)
-# Allow advanced users to generate Makefiles printing detailed commands
-mark_as_advanced(CMAKE_VERBOSE_MAKEFILE)
-# Path to additional CMake modules
-set(CMAKE_MODULE_PATH ${libLAS_SOURCE_DIR}/cmake/modules ${CMAKE_MODULE_PATH})
-# General build settings
-# Default to debug mode until final 1.6.0 release
-if(NOT MSVC_IDE)
-  if(NOT CMAKE_BUILD_TYPE)
-  set(CMAKE_BUILD_TYPE Debug CACHE STRING
-    "Choose the type of build, options are: None Debug Release RelWithDebInfo MinSizeRel" FORCE)
-  endif()
-    message(STATUS "Setting libLAS build type - ${CMAKE_BUILD_TYPE}")
-endif()
-# TODO: Still testing the output paths --mloskot
-set(LIBLAS_BUILD_OUTPUT_DIRECTORY ${PROJECT_BINARY_DIR}/bin/${CMAKE_BUILD_TYPE})
-# Output directory in which to build RUNTIME target files.
-set(CMAKE_RUNTIME_OUTPUT_DIRECTORY ${LIBLAS_BUILD_OUTPUT_DIRECTORY})
-# Output directory in which to build LIBRARY target files
-set(CMAKE_LIBRARY_OUTPUT_DIRECTORY ${LIBLAS_BUILD_OUTPUT_DIRECTORY})
-# Output directory in which to build ARCHIVE target files.
-set(CMAKE_ARCHIVE_OUTPUT_DIRECTORY ${LIBLAS_BUILD_OUTPUT_DIRECTORY})
-file(READ "doc/index.txt" README )
-file(WRITE "README.txt" "${README}")
-# Platform and compiler specific settings
-if(WIN32)
-  if (MSVC)
-    if (MSVC80 OR MSVC90 OR MSVC10)
-      add_definitions(-D_CRT_SECURE_NO_DEPRECATE)
-      add_definitions(-D_CRT_SECURE_NO_WARNINGS)
-      add_definitions(-D_CRT_NONSTDC_NO_WARNING)
-      add_definitions(-D_SCL_SECURE_NO_WARNINGS)
-    endif()
-    if(CMAKE_CXX_FLAGS MATCHES "/W[0-4]")
-      string(REGEX REPLACE "/W[0-4]" "/W4"
-        CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS}")
-    else()
-      set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} /W4")
-    endif()
-    # Generate dot-user file with user-specific settings for
-    # Visual Studio project
-    set(MSVC_ENVIRONMENT_PATH "" CACHE STRING
-      "Custom PATH for Environment property in Visual Studio for project")
-    mark_as_advanced(MSVC_ENVIRONMENT_PATH)
-    set(VCPROJ_USER_ENVIRONMENT_PATH_DEBUG "${ENVIRONMENT_PATH}")
-    mark_as_advanced(VCPROJ_USER_ENVIRONMENT_PATH_DEBUG)
-  endif()
-  set(CMAKE_INCLUDE_PATH c:/osgeo4w/include;$ENV{CMAKE_INCLUDE_PATH})
-  set(CMAKE_LIBRARY_PATH c:/osgeo4w/lib;$ENV{CMAKE_LIBRARY_PATH})
-else()
-  # Recommended C++ compilation flags
-  # -Weffc++
-  set(LIBLAS_COMMON_CXX_FLAGS
-	"-pedantic -ansi -Wall -Wpointer-arith -Wcast-align -Wcast-qual -Wfloat-equal -Wredundant-decls -Wno-long-long")
-  if(CMAKE_COMPILER_IS_GNUCC OR CMAKE_COMPILER_IS_GNUCXX)
-    set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} ${LIBLAS_COMMON_CXX_FLAGS}")
-    if (CMAKE_COMPILER_IS_GNUCXX)
-      set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -std=c++98")
-    endif()
-  elseif("${CMAKE_CXX_COMPILER_ID}" MATCHES "Clang" OR "${CMAKE_CXX_COMPILER}" MATCHES "clang")
-  endif()
-endif(WIN32)
-if (APPLE)
-  set(SO_EXT dylib)
-  set(CMAKE_FIND_FRAMEWORK "LAST")
-elseif(WIN32)
-  set(SO_EXT dll)
-else()
-  set(SO_EXT so)
-endif(APPLE)
-# Search for dependencies
-# Boost C++ Libraries support - required
-message(STATUS "Searching for Boost 1.38+ - done")
-# Default to using static, multithreaded libraries for
-# linking under MSVC.  This is because we show users how to
-# use boostpro.com installer and install those options when linking
-# on windows in the compilation documentation.
-if(WIN32)
-  if (MSVC)
-    set(Boost_USE_STATIC_LIBS   ON)
-    set(Boost_USE_MULTITHREADED ON)
-  endif(MSVC)
-endif(WIN32)
-# NOTE: Add iostreams to COMPONENTS list to enable bigfile_boost_iostreams_test
-find_package(Boost 1.38 COMPONENTS program_options thread REQUIRED)
-if(Boost_FOUND AND Boost_PROGRAM_OPTIONS_FOUND)
-  include_directories(${Boost_INCLUDE_DIRS})
-endif()
-# make these available for the user to set.
-mark_as_advanced(CLEAR Boost_INCLUDE_DIR)
-mark_as_advanced(CLEAR Boost_LIBRARY_DIRS)
-link_directories(${Boost_LIBRARY_DIRS})
-# libxml2 support - optional, default=ON
-set(WITH_LIBXML2 FALSE CACHE BOOL "Choose if libxml2 support should be built ")
-if(WITH_LIBXML2)
-    find_package(LibXml2)
-    mark_as_advanced(CLEAR LIBXML2_INCLUDE_DIR)
-    mark_as_advanced(CLEAR LIBXML2_LIBRARIES)
-    if(LIBXML2_FOUND)
-        include_directories(${LIBXML2_INCLUDE_DIR})
-        add_definitions(-DHAVE_LIBXML2=1)
-    endif()
-endif()
-# GDAL/OGR support - optional, default=OFF
-set(WITH_GDAL FALSE CACHE BOOL "Choose if GDAL support should be built")
-if(WITH_GDAL)
-  find_package(GDAL 1.6.0)
-  # if(GDAL_FOUND)
-  #   # Confirm required API is available
-  #   include(CheckFunctionExists)
-  #   set(CMAKE_REQUIRED_LIBRARIES ${GDAL_LIBRARY})
-  #   check_function_exists(OSRSetEquirectangular2 HAVE_OSRSETEQUIRECTANGULAR2)
-  #   if(NOT HAVE_OSRSETEQUIRECTANGULAR2)
-  #     # Reset to NOT found for GDAL/OGR
-  #     set(GDAL_FOUND)
-  #     message(FATAL_ERROR
-  #       "Unable to find OSRSetEquirectangular2 within GDAL library at ${GDAL_INCLUDE_DIR} ${GDAL_LIBRARY}")
-  #   else()
-      include_directories(${GDAL_INCLUDE_DIR})
-      add_definitions(-DHAVE_GDAL=1)
-  #   endif()
-  # endif()
-  mark_as_advanced(CLEAR GDAL_INCLUDE_DIR)
-  mark_as_advanced(CLEAR GDAL_LIBRARY)
-endif()
-# GeoTIFF support - optional, default=OFF
-set(WITH_GEOTIFF FALSE CACHE BOOL "Choose if GeoTIFF support should be built")
-if(WITH_GEOTIFF)
-  find_package(GeoTIFF 1.2.5)
-  if(GEOTIFF_FOUND)
-    # Confirm required API is available
-    include(CheckFunctionExists)
-    set(CMAKE_REQUIRED_LIBRARIES ${GEOTIFF_LIBRARY})
-    #       check_function_exists(ST_Create HAVE_ST_CREATE)
-    #        if(NOT HAVE_ST_CREATE)
-    #            set(GEOTIFF_FOUND) # Reset to NOT found for GeoTIFF
-    #            message(FATAL_ERROR "GeoTIFF support requires libgeotiff 1.2.5 or newer.")
-    #        else()
-    include_directories(${GEOTIFF_INCLUDE_DIR})
-    add_definitions(-DHAVE_LIBGEOTIFF=1)
-    #        endif()
-  endif()
-  # Determine libTIFF availability, required
-  if (GEOTIFF_FOUND)
-    mark_as_advanced(CLEAR TIFF_INCLUDE_DIR)
-    mark_as_advanced(CLEAR TIFF_LIBRARY)
-    if (WIN32)
-        set(TIFF_NAMES libtiff_i)
-    endif(WIN32)
-    find_package(TIFF)
-    if (TIFF_FOUND)
More information about the Liblas-commits mailing list
