[Liblas-commits] hg: start on LAS 1.4 WKT doc
liblas-commits at liblas.org liblas-commits at liblas.org
Wed Feb 16 14:03:23 EST 2011
details:   http://hg.liblas.orghg/rev/643f53b86216
changeset: 2858:643f53b86216
user:      Howard Butler <hobu.inc at gmail.com>
date:      Wed Feb 16 13:03:18 2011 -0600
description:
diffstat:
 doc/development/index.txt |   1 +
 doc/development/wkt.txt   |  99 +++++++++++++++++++++++++++++++++++++++++++++++
 2 files changed, 100 insertions(+), 0 deletions(-)
diffs (114 lines):
diff -r 28e9558c5062 -r 643f53b86216 doc/development/index.txt
--- a/doc/development/index.txt	Mon Feb 14 13:10:19 2011 -0600
+++ b/doc/development/index.txt	Wed Feb 16 13:03:18 2011 -0600
@@ -18,6 +18,7 @@
    Motivation <http://www.youtube.com/watch?v=u6XAPnuFjJc>
    2010 Annual Report <annual_report_2010>
    RFCs <rfc/index>
+   LAS 1.4 WKT Proposal <wkt>
 Authors
diff -r 28e9558c5062 -r 643f53b86216 doc/development/wkt.txt
--- /dev/null	Thu Jan 01 00:00:00 1970 +0000
+++ b/doc/development/wkt.txt	Wed Feb 16 13:03:18 2011 -0600
@@ -0,0 +1,99 @@
+.. _srs_wkt:
+Georeferencing LAS files with LAS 1.4
+:Author: Howard Butler
+:Contact: hobu.inc at gmail dot com
+:Date: 2/16/2011
+Summary
+This document proposes how to handle describing spatial reference systems
+in `ASRPS LAS`_ 1.4. LAS 1.4 prescribes that software developers add and
+prefer to use OGC WKT coordinate system description in the form of VLR
+records in LAS files.  Softwares can choose to continue to write GeoTIFF keys
+to support older applications, but they should prefer the OGC WKT if it is
+found in the file.
+Rationale
+LAS 1.3 and below have used `GeoTIFF`_ keys as described by the `GeoTIFF
+specification`_, but use of the GeoTIFF keys within LAS has a number of
+deficiencies:
+* GeoTIFF is typically tied to the `EPSG database`_ and does not provide
+  simple mechanisms for extended definitions.
+* Only a few softwares provide support for working with GeoTIFF keys directly.
+* The GeoTIFF specification has no organization backing its continued
+  development.
+* GeoTIFF does not offer a mechanism to represent transformations between
+  datums, while OGC WKT offers the TOWGS84[] mechanism
+OGC WKT
+The `OGC Simple Feature Access`_ specification provides the "Well-known Text
+Representation of Spatial Reference Systems" (WKT) language in section nine.
+WKT is much more expressive than GeoTIFF keys, has an organization providing
+institutional heft and progress behind it, and a number of open source and
+commercial softwares are available to support parsing and interpreting WKT
+output.
+There are a few dialects of WKT of which to be aware. The most common dialect
+is the "ESRI WKT" dialect, which does not include TOWGS84 and authority nodes,
+but there are others including "GDAL", "CSMap", "Oracle 9", "Oracle 10", and
+"GeoTools." It should be assumed that all WKT provided in LAS files should be
+of a dialect that is not the "ESRI WKT" dialect, which lacks some important
+features -- notably TOWGS84 and AUTHORITY nodes. If you have questions about
+how to produce WKT, please participate on the `MetaCRS`_ mailing list.
+Examples of WKT may also be found on the http://spatialreference.org website.
+.. `OGC Simple Feature Access`: http://www.opengeospatial.org/standards/sfa
+.. `MetaCRS`: http://trac.osgeo.org/metacrs/
+Transition
+Older softwares may want to continue to use GeoTIFF keys, and it is not
+desirable to have an abrupt discontinuity in the description of coordinate
+systems for LAS data. Additionally, while many softwares may not need the
+features of OGC WKT, its usage represents the strongest case for
+interoperability with other software -- especially software in the GIS and CAD
+domains that take advantage of the OGC WKT specification.
+Softwares that currently write GeoTIFF VLR records into LAS files can continue
+to do so in LAS 1.4. It is acceptable to write *only* GeoTIFF VLR records into
+an LAS file, while softwares that choose to write OGC WKT VLRs should also
+write GeoTIFF VLRs to promote backward compatibility If a file is found to
+have both OGC WKT and GeoTIFF VLRs, the OGC WKT description, which is more
+expressive, should be preferred if possible.
+Implementation
+OGC WKT strings shall be provided in a VLR with the following attributes:
+* User ID: LASF_Projection
+* Record ID: 2112
+The following conditions should also apply:
+* Because VLRs can only be 65536 size, an OGC WKT string in a VLR data block
+  is functionally limited to 64K in size.
+* The OGC WKT VLR data shall be a null-terminated string.
+* The OGC WKT VLR data shall be considered UTF-8.
+* The OGC WKT VLR data shall be considered ``C`` locale-based, and no
+  localization of the numeric strings within the WKT should be performed.
+.. _`ASPRS LAS`: http://www.asprs.org/society/committees/standards/lidar_exchange_format.html
+.. _`GeoTIFF specification`: ftp://ftp.remotesensing.org/pub/geotiff/spec/geotiff.rtf
+.. _`GeoTIFF`: http://trac.osgeo.org/geotiff/
+.. _`EPSG database`: http://www.epsg-registry.org/
More information about the Liblas-commits mailing list
