[Liblas-commits] hg-1.6: fix #207 extra work in files with invalid point counts
liblas-commits at liblas.org liblas-commits at liblas.org
Thu Feb 17 13:43:25 EST 2011
details:   http://hg.liblas.orghg-1.6/rev/a9289ac44e6a
changeset: 2846:a9289ac44e6a
user:      Howard Butler <hobu.inc at gmail.com>
date:      Mon Feb 14 13:07:06 2011 -0600
description:
Subject: hg-1.6: fix #208 display of header summary in lasinfo
details:   http://hg.liblas.orghg-1.6/rev/3b86b3eaafd4
changeset: 2847:3b86b3eaafd4
date:      Mon Feb 14 13:10:19 2011 -0600
description:
Subject: hg-1.6: output of a single point's XML is not valid XML #210
details:   http://hg.liblas.orghg-1.6/rev/7bc6b2de480c
changeset: 2848:7bc6b2de480c
date:      Thu Feb 17 11:33:38 2011 -0600
description:
Subject: hg-1.6: fix #213, liblas::Cleanup methods no using the proper cast to determine if they have a file-based stream
details:   http://hg.liblas.orghg-1.6/rev/d3de717cd0b7
changeset: 2849:d3de717cd0b7
date:      Thu Feb 17 12:41:02 2011 -0600
description:
diffstat:
 apps/lasinfo.cpp             |   4 ++--
 include/liblas/liblas.hpp    |  35 +++++++++++++++++++++++++++++++----
 src/detail/reader/reader.cpp |   3 ++-
 3 files changed, 35 insertions(+), 7 deletions(-)
diffs (92 lines):
diff -r 12230c12cca9 -r d3de717cd0b7 apps/lasinfo.cpp
--- a/apps/lasinfo.cpp	Tue Feb 01 13:40:39 2011 -0600
+++ b/apps/lasinfo.cpp	Thu Feb 17 12:41:02 2011 -0600
@@ -204,7 +204,7 @@
                 liblas::Point const& p = reader.GetPoint();
                 if (output_xml) {
                     liblas::property_tree::ptree tree;
-                    tree = p.GetPTree();
+                    tree.add_child("points.point", p.GetPTree());
                     liblas::property_tree::write_xml(std::cout, tree);
                     exit(0);
@@ -236,7 +236,7 @@
                             verbose
-        liblas::Header const& header = reader.GetHeader();
+        header = reader.GetHeader();
         // Add the header to the summary so we can get more detailed
         // info
diff -r 12230c12cca9 -r d3de717cd0b7 include/liblas/liblas.hpp
--- a/include/liblas/liblas.hpp	Tue Feb 01 13:40:39 2011 -0600
+++ b/include/liblas/liblas.hpp	Thu Feb 17 12:41:02 2011 -0600
@@ -166,11 +166,25 @@
     // An ofstream is closeable and deletable, but
     // an ostream like &std::cout isn't.
     if (!ofs) return;
-    if (static_cast<std::ofstream&>(*ofs))
+#ifdef USE_BOOST_IO
+    namespace io = boost::iostreams;
+    io::stream<io::file_sink>* source = dynamic_cast<io::stream<io::file_sink>*>(ofs);
+    if (source)
-        static_cast<std::ofstream&>(*ofs).close();
+        source->close();
         delete ofs;
+#else
+    std::ofstream* source = dynamic_cast<std::ofstream*>(ofs);
+    if (source)
+        source->close();
+        delete ofs;
+#endif
 inline void Cleanup(std::istream* ifs)
@@ -178,11 +192,24 @@
     // An ifstream is closeable and deletable, but
     // an istream like &std::cin isn't.
     if (!ifs) return;
-    if (static_cast<std::ifstream&>(*ifs))
+    io::stream<io::file_source>* source = dynamic_cast<io::stream<io::file_source>*>(ifs);
+    if (source)
-        static_cast<std::ifstream&>(*ifs).close();
+        source->close();
         delete ifs;
+#else
+    std::ifstream* source = dynamic_cast<std::ifstream*>(ifs);
+    if (source)
+        source->close();
+        delete ifs;
+#endif
 class ReaderI
diff -r 12230c12cca9 -r d3de717cd0b7 src/detail/reader/reader.cpp
--- a/src/detail/reader/reader.cpp	Tue Feb 01 13:40:39 2011 -0600
+++ b/src/detail/reader/reader.cpp	Thu Feb 17 12:41:02 2011 -0600
@@ -172,7 +172,8 @@
     } catch (std::runtime_error&)
         // If the stream is no good anymore, we're done reading points
-        return;
+        throw std::out_of_range("ReadNextPoint: file has no more points to read, end of file reached");
     // Filter the points and continue reading until we either find
More information about the Liblas-commits mailing list
