[Liblas-commits] hg: cut down on unnecessary rescaling of data by checking header...
liblas-commits at liblas.org liblas-commits at liblas.org
Tue Feb 22 15:09:53 EST 2011
details:   http://hg.liblas.orghg/rev/4e42df8ed310
changeset: 2886:4e42df8ed310
user:      Howard Butler <hobu.inc at gmail.com>
date:      Tue Feb 22 14:06:31 2011 -0600
description:
cut down on unnecessary rescaling of data by checking header offset/scale first
Subject: hg: add method to override ReprojectionTransform's header after it is instantiated
details:   http://hg.liblas.orghg/rev/fb04cf7dd990
changeset: 2887:fb04cf7dd990
date:      Tue Feb 22 14:06:57 2011 -0600
description:
Subject: hg: fix #216 mis-scaling of data with --min-offset and a reprojection operation
details:   http://hg.liblas.orghg/rev/08ce44e1af3d
changeset: 2888:08ce44e1af3d
date:      Tue Feb 22 14:09:47 2011 -0600
description:
diffstat:
 apps/las2las.cpp             |  35 ++++++++++++++++++++++++++++----
 include/liblas/transform.hpp |   1 +
 src/point.cpp                |  46 +++++++++++++++++++++++++++++++++++++------
 3 files changed, 70 insertions(+), 12 deletions(-)
diffs (138 lines):
diff -r b7c79f4eec6f -r 08ce44e1af3d apps/las2las.cpp
--- a/apps/las2las.cpp	Tue Feb 22 10:57:51 2011 -0600
+++ b/apps/las2las.cpp	Tue Feb 22 14:09:47 2011 -0600
@@ -88,6 +88,20 @@
             std::cout << std::endl;
         reader.Reset();
+        std::vector<liblas::TransformPtr> transforms = reader.GetTransforms();
+        std::vector<liblas::TransformPtr> new_transforms;
+        for (std::size_t i = 0; i < transforms.size(); i++)
+            liblas::TransformPtr transform = transforms[i];
+            if (dynamic_cast<liblas::ReprojectionTransform*>(transform.get()))
+                dynamic_cast<liblas::ReprojectionTransform*>(transform.get())->SetHeaderPtr(liblas::HeaderPtr(new liblas::Header(header)));
+            new_transforms.push_back(transform);
+        reader.SetTransforms(new_transforms);
     std::ostream* ofs = NULL;
@@ -118,13 +132,24 @@
     boost::int32_t split_bytes_count = 1024*1024*split_mb;
     boost::uint32_t split_points_count = 0;
     int fileno = 2;
+    liblas::HeaderPtr ptr = liblas::HeaderPtr(new liblas::Header(header));
     while (reader.ReadNextPoint())
-        liblas::Point const& p = reader.GetPoint();
-        summary->AddPoint(p);
-        writer->WritePoint(p);
+        if (min_offset)
+            liblas::Point p = reader.GetPoint();
+            summary->AddPoint(p);
+            p.SetHeaderPtr(ptr);
+            writer->WritePoint(p);
+        else
+            liblas::Point const& p = reader.GetPoint();
         if (verbose)
             term_progress(std::cout, (i + 1) / static_cast<double>(size));
         i++;
diff -r b7c79f4eec6f -r 08ce44e1af3d include/liblas/transform.hpp
--- a/include/liblas/transform.hpp	Tue Feb 22 10:57:51 2011 -0600
+++ b/include/liblas/transform.hpp	Tue Feb 22 14:09:47 2011 -0600
@@ -76,6 +76,7 @@
     ~ReprojectionTransform();
     bool transform(Point& point);
+    void SetHeaderPtr(liblas::HeaderPtr header) {m_new_header = header;}
     bool ModifiesHeader() { return true; }
 private:
diff -r b7c79f4eec6f -r 08ce44e1af3d src/point.cpp
--- a/src/point.cpp	Tue Feb 22 10:57:51 2011 -0600
+++ b/src/point.cpp	Tue Feb 22 14:09:47 2011 -0600
@@ -190,11 +190,33 @@
     boost::uint16_t wanted_length;
+    bool bSetCoordinates = true;
     const liblas::Schema* schema;
     if (header.get()) {
         wanted_length = header->GetDataRecordLength();
         schema = &header->GetSchema();
+        if (m_header.get())
+            if (detail::compare_distance(header->GetScaleX(), m_header->GetScaleX()) ||
+                detail::compare_distance(header->GetScaleY(), m_header->GetScaleY()) ||
+                detail::compare_distance(header->GetScaleZ(), m_header->GetScaleZ()))
+                bSetCoordinates = false;
+            else
+                bSetCoordinates = true;
+            if (detail::compare_distance(header->GetOffsetX(), m_header->GetOffsetX()) ||
+                detail::compare_distance(header->GetOffsetY(), m_header->GetOffsetY()) ||
+                detail::compare_distance(header->GetOffsetZ(), m_header->GetOffsetZ()))
+            else
+            // if (!bSetCoordinates)
+            //     std::cout << "Scales and offsets are equal, not resetting coordinates" << std::endl;
     else
@@ -255,18 +277,28 @@
         m_header = header;
         return;
+    double x;
+    double y;
+    double z;
-    double x = GetX();
-    double y = GetY();
-    double z = GetZ();
+    if (bSetCoordinates)
+        x = GetX();
+        y = GetY();
+        z = GetZ();
     // The header's scale/offset can change the raw storage of xyz.
     // SetHeaderPtr can result in a rescaling of the data.
     m_header = header;
-    SetX(x);
-    SetY(y);
-    SetZ(z);
+        SetX(x);
+        SetY(y);
+        SetZ(z);
 HeaderPtr Point::GetHeaderPtr() const
More information about the Liblas-commits mailing list
