[Liblas-commits] libpc: bunch of unit test work
liblas-commits at liblas.org liblas-commits at liblas.org
Wed Feb 23 11:39:41 EST 2011
details:   http://hg.liblas.orglibpc/rev/925d511b465c
changeset: 73:925d511b465c
user:      Michael P. Gerlek <mpg at flaxen.com>
date:      Tue Feb 22 10:38:12 2011 -0800
description:
Subject: libpc: checkpoint
details:   http://hg.liblas.orglibpc/rev/5bed80c7c3cd
changeset: 74:5bed80c7c3cd
date:      Tue Feb 22 13:49:03 2011 -0800
description:
checkpoint
Subject: libpc: more unit tests
details:   http://hg.liblas.orglibpc/rev/c6e80ef5f98c
changeset: 75:c6e80ef5f98c
date:      Wed Feb 23 08:39:29 2011 -0800
description:
more unit tests
diffstat:
 .hgignore                   |    2 +
 apps/pc2pc.cpp              |   10 +-
 include/libpc/Bounds.hpp    |   44 +++---
 include/libpc/Color.hpp     |   12 +-
 include/libpc/Dimension.hpp |  100 +++++++++------
 include/libpc/PointData.hpp |   20 +-
 include/libpc/Range.hpp     |    7 +
 include/libpc/Schema.hpp    |   60 ++++++++-
 include/libpc/Utils.hpp     |   48 +++++--
 include/libpc/Vector.hpp    |    6 +-
 mpg-config.bat              |    6 +-
 src/Color.cpp               |    6 +-
 src/ColorFilter.cpp         |    9 +-
 src/CropFilter.cpp          |    3 +-
 src/Dimension.cpp           |  271 ++++++++++++++++++++++++++++---------------
 src/FauxReader.cpp          |   11 +-
 src/Header.cpp              |    2 +-
 src/LasHeader.cpp           |   53 ++++----
 src/LasReader.cpp           |   38 ++---
 src/LasWriter.cpp           |   38 ++---
 src/MosaicFilter.cpp        |    8 +-
 src/PointData.cpp           |   78 ++++++++----
 src/Schema.cpp              |  183 ++++++++++++++++++++++------
 src/Utils.cpp               |   48 +++++++-
 test/unit/BoundsTest.cpp    |  103 ++++++++++++++++-
 test/unit/CMakeLists.txt    |    5 +
 test/unit/ColorTest.cpp     |   54 ++++++++
 test/unit/DimensionTest.cpp |   60 +++++++++
 test/unit/PointDataTest.cpp |  135 +++++++++++++++++++++
 test/unit/RangeTest.cpp     |   11 +-
 test/unit/SchemaTest.cpp    |   84 +++++++++++++
 test/unit/UtilsTest.cpp     |  135 +++++++++++++++++++++
 test/unit/VectorTest.cpp    |   13 +-
 33 files changed, 1289 insertions(+), 374 deletions(-)
diffs (truncated from 2680 to 300 lines):
diff -r 674deb620627 -r c6e80ef5f98c .hgignore
--- a/.hgignore	Mon Feb 21 08:59:21 2011 -0800
+++ b/.hgignore	Wed Feb 23 08:39:29 2011 -0800
@@ -1,5 +1,7 @@
 syntax: glob
+libpc_defines.h
 # rst outputs
 *.pdf
diff -r 674deb620627 -r c6e80ef5f98c apps/pc2pc.cpp
--- a/apps/pc2pc.cpp	Mon Feb 21 08:59:21 2011 -0800
+++ b/apps/pc2pc.cpp	Wed Feb 23 08:39:29 2011 -0800
@@ -69,7 +69,7 @@
 static void test3()
-  std::istream* ifs = Utils::Open("test/data/1.2-with-color.las");
+  std::istream* ifs = Utils::openFile("test/data/1.2-with-color.las");
   LasReader reader(*ifs);
@@ -77,14 +77,14 @@
   std::cout << (const LasHeader&)header;
-  std::ostream* ofs = Utils::Create("temp.las");
+  std::ostream* ofs = Utils::createFile("temp.las");
   LasWriter lasWriter(reader, *ofs);
   lasWriter.write();
-  Utils::Cleanup(ofs);
+  Utils::closeFile(ofs);
-  Utils::Cleanup(ifs);
+  Utils::closeFile(ifs);
   return;
@@ -114,7 +114,7 @@
-        Dimension dim("foo", Dimension::uint8_t);
+        Dimension dim("foo", Dimension::Uint8);
         std::cout << dim << std::endl;
diff -r 674deb620627 -r c6e80ef5f98c include/libpc/Bounds.hpp
--- a/include/libpc/Bounds.hpp	Mon Feb 21 08:59:21 2011 -0800
+++ b/include/libpc/Bounds.hpp	Wed Feb 23 08:39:29 2011 -0800
@@ -236,29 +236,30 @@
         return m_ranges.size();
-    ///// Resize the dimensionality of the Bounds to d
-    //void resize(size_type d)
-    //    if (m_ranges.size() < d)
-    //        m_ranges.resize(d);
     /// Is this Bounds equal to other?
     bool equal(Bounds<T> const& other) const
+        if (size() != other.size())
+          return false;
         for (std::size_t i = 0; i < size(); i++)
-            if ( m_ranges[i] != other.m_ranges[i] )
+            if (m_ranges[i] != other.m_ranges[i])
                 return false;
         return true;
-    /// Does this Bounds intersect other?
-    bool intersects(Bounds const& other) const
+    /// Synonym for intersects for now
+    bool overlaps(Bounds const& other) const
+        if (other.size() != size())
+            return false;
@@ -267,13 +268,6 @@
         return false;
-    /// Synonym for intersects for now
-    bool overlaps(Bounds const& other) const
-        return intersects(other);
     /// Does this Bounds contain a point?
@@ -303,11 +297,11 @@
         return true;
-    /// Shift each dimension by a vector of detlas
+    /// Shift each dimension by a vector of deltas
     void shift(std::vector<T> deltas)
         std::size_t i;
-        if( size() <= deltas.size())
+        if( size() != deltas.size())
             std::ostringstream msg;
             msg << "liblas::Bounds::shift: Delta vector size, " << deltas.size()
@@ -324,7 +318,7 @@
     void scale(std::vector<T> deltas)
         std::size_t i;
             msg << "liblas::Bounds::scale: Delta vector size, " << deltas.size()
@@ -369,7 +363,7 @@
     T volume() const
-        T output = T();
+        T output = T(1);
             output = output * m_ranges[i].length();
@@ -430,12 +424,14 @@
 template<class T>
 std::ostream& operator<<(std::ostream& ostr, const Bounds<T>& bounds)
+    ostr << "(";
     for (std::size_t d = 0; d < bounds.size(); ++d)
         const Range<T>& r = bounds.dimensions()[d];
-        ostr << "[" <<  r.getMinimum() << ", " << r.getMaximum() << "]";
+        ostr << r;
         if (d!=bounds.size()-1) ostr << ", ";
+    ostr << ")";
     return ostr;
diff -r 674deb620627 -r c6e80ef5f98c include/libpc/Color.hpp
--- a/include/libpc/Color.hpp	Mon Feb 21 08:59:21 2011 -0800
+++ b/include/libpc/Color.hpp	Wed Feb 23 08:39:29 2011 -0800
@@ -78,37 +78,37 @@
     Color& operator=(Color const& rhs);
     /// Fetch value of the red image channel
-    value_type GetRed() const
+    value_type getRed() const
         return m_color[0];
     /// Set value of the red image channel
-    void SetRed(value_type const& value)
+    void setRed(value_type const& value)
         m_color[0] = value;
     /// Fetch value of the green image channel
-    value_type GetGreen() const
+    value_type getGreen() const
         return m_color[1];
-    void SetGreen(value_type const& value)
+    void setGreen(value_type const& value)
         m_color[1] = value;
     /// Fetch value of the blue image channel
-    value_type GetBlue() const
+    value_type getBlue() const
         return m_color[2];
     /// Set value of the blue image channel
-    void SetBlue(value_type const& value)
+    void setBlue(value_type const& value)
         m_color[2] = value;
diff -r 674deb620627 -r c6e80ef5f98c include/libpc/Dimension.hpp
--- a/include/libpc/Dimension.hpp	Mon Feb 21 08:59:21 2011 -0800
+++ b/include/libpc/Dimension.hpp	Wed Feb 23 08:39:29 2011 -0800
@@ -66,16 +66,16 @@
 public:
     enum DataType
-        int8_t,
-        uint8_t,
-        int16_t,
-        uint16_t,
-        int32_t,
-        uint32_t,
-        int64_t,
-        uint64_t,
-        float_t,       // 32 bits
-        double_t      // 64 bits
+        Int8,
+        Uint8,
+        Int16,
+        Uint16,
+        Int32,
+        Uint32,
+        Int64,
+        Uint64,
+        Float,       // 32 bits
+        Double       // 64 bits
 public:
@@ -84,8 +84,7 @@
     Dimension(Dimension const& other);
     bool operator==(const Dimension& other) const;
-    virtual ~Dimension() {}
+    bool operator!=(const Dimension& other) const;
     inline std::string const& getName() const
@@ -111,20 +110,6 @@
        return m_byteSize;
-    /// The byte location to start reading/writing
-    /// point data from in a composited schema.  liblas::Schema
-    /// will set these values for you when liblas::Dimension are
-    /// added to the liblas::Schema.
-    inline std::size_t getByteOffset() const
-        return m_byteOffset;
-    inline void setByteOffset(std::size_t v)
-        m_byteOffset = v;
     inline std::string getDescription() const
         return m_description;
@@ -175,19 +160,6 @@
         m_max = max;
-    /// The index position of the index.  In a standard ePointFormat0
-    /// data record, the X dimension would have a position of 0, while
-    /// the Y dimension would have a position of 1, for example.
-    inline std::size_t getPosition() const
-        return m_position;
-    inline void setPosition(std::size_t v)
-        m_position = v;
     /// The scaling value for this dimension as a double.  This should
     /// be positive or negative powers of ten.
     inline double getNumericScale() const
@@ -229,17 +201,63 @@
     DataType m_dataType;
     std::string m_name;
     std::size_t m_byteSize;
-    std::size_t m_byteOffset;
     std::string m_description;
     double m_min;
     double m_max;
-    std::size_t m_position;
     bool m_precise;
     double m_numericScale;
     double m_numericOffset;
More information about the Liblas-commits mailing list
