[Liblas-commits] hg: refactor the zip point support code; add laszip VLR reading/...
liblas-commits at liblas.org liblas-commits at liblas.org
Mon Jan 3 13:37:27 EST 2011
details:   http://hg.liblas.orghg/rev/fa6834d7fbf1
changeset: 2669:fa6834d7fbf1
user:      Michael P. Gerlek <mpg at flaxen.com>
date:      Mon Jan 03 09:53:30 2011 -0800
description:
refactor the zip point support code; add laszip VLR reading/writing
Subject: hg: cleanup I/O, added endiannessing
details:   http://hg.liblas.orghg/rev/61dcbb1101c4
changeset: 2670:61dcbb1101c4
date:      Mon Jan 03 10:16:57 2011 -0800
description:
Subject: hg: pull-merge
details:   http://hg.liblas.orghg/rev/c43faf6300aa
changeset: 2671:c43faf6300aa
date:      Mon Jan 03 10:17:30 2011 -0800
description:
pull-merge
Subject: hg: VS2010 lint
details:   http://hg.liblas.orghg/rev/5fae42ddbc14
changeset: 2672:5fae42ddbc14
date:      Mon Jan 03 10:35:29 2011 -0800
description:
VS2010 lint
diffstat:
 CMakeLists.txt                             |    5 +-
 apps/CMakeLists.txt                        |   12 +-
 apps/lasblock.cpp                          |    2 +-
 apps/liblas-config.in                      |    4 +-
 include/liblas/detail/reader/zipreader.hpp |    9 +-
 include/liblas/detail/writer/zipwriter.hpp |    9 +-
 include/liblas/detail/zippoint.hpp         |   90 ++++++
 include/liblas/spatialreference.hpp        |    2 +-
 src/CMakeLists.txt                         |    6 +-
 src/c_api.cpp                              |    9 +-
 src/detail/reader/header.cpp               |   13 +-
 src/detail/reader/zipreader.cpp            |   94 +------
 src/detail/writer/header.cpp               |   14 +
 src/detail/writer/zipwriter.cpp            |   85 +-----
 src/detail/zippoint.cpp                    |  375 +++++++++++++++++++++++++++++
 src/spatialreference.cpp                   |    8 +-
 16 files changed, 549 insertions(+), 188 deletions(-)
diffs (truncated from 1061 to 300 lines):
diff -r 20328697f704 -r 5fae42ddbc14 CMakeLists.txt
--- a/CMakeLists.txt	Thu Dec 30 15:25:24 2010 -0600
+++ b/CMakeLists.txt	Mon Jan 03 10:35:29 2011 -0800
@@ -400,9 +400,10 @@
 SET(CPACK_CMAKE_GENERATOR "Unix Makefiles")
 set(CPACK_SOURCE_PACKAGE_FILE_NAME
-  "${CMAKE_PROJECT_NAME}-${CPACK_PACKAGE_VERSION_MAJOR}.${CPACK_PACKAGE_VERSION_MINOR}.${CPACK_PACKAGE_VERSION_PATCH}")
+  "${CMAKE_PROJECT_NAME}-${VERSION}")
 list(APPEND CPACK_SOURCE_IGNORE_FILES "/test/data/TO_core_last_zoom.las")
 list(APPEND CPACK_SOURCE_IGNORE_FILES "_CPack_Packages")
 list(APPEND CPACK_SOURCE_IGNORE_FILES ".gz")
diff -r 20328697f704 -r 5fae42ddbc14 apps/CMakeLists.txt
--- a/apps/CMakeLists.txt	Thu Dec 30 15:25:24 2010 -0600
+++ b/apps/CMakeLists.txt	Mon Jan 03 10:35:29 2011 -0800
@@ -218,10 +218,18 @@
     set(prefix ${CMAKE_INSTALL_PREFIX})
     set(exec_prefix ${CMAKE_INSTALL_PREFIX}/bin)
     set(libdir ${CMAKE_INSTALL_PREFIX}/lib)
+    GET_DIRECTORY_PROPERTY(LIBLAS_DEFINITIONS DIRECTORY ${libLAS_SOURCE_DIR}/ COMPILE_DEFINITIONS)
+    set(LIBLAS_CONFIG_DEFINITIONS "")
+    foreach(definition ${LIBLAS_DEFINITIONS})
+        set(LIBLAS_CONFIG_DEFINITIONS "${LIBLAS_CONFIG_DEFINITIONS} -D${definition}")
+    endforeach()
     configure_file(${CMAKE_CURRENT_SOURCE_DIR}/liblas-config.in
       ${CMAKE_CURRENT_BINARY_DIR}/liblas-config @ONLY)
     install(FILES ${CMAKE_CURRENT_BINARY_DIR}/liblas-config
       DESTINATION bin/
       PERMISSIONS
diff -r 20328697f704 -r 5fae42ddbc14 apps/lasblock.cpp
--- a/apps/lasblock.cpp	Thu Dec 30 15:25:24 2010 -0600
+++ b/apps/lasblock.cpp	Mon Jan 03 10:35:29 2011 -0800
@@ -144,7 +144,7 @@
 void write_index(std::string& output,
                  liblas::chipper::Chipper& c,
-                 liblas::Reader& reader,
+                 liblas::Reader& /*reader*/,
                  long precision,
                  bool verbose)
diff -r 20328697f704 -r 5fae42ddbc14 apps/liblas-config.in
--- a/apps/liblas-config.in	Thu Dec 30 15:25:24 2010 -0600
+++ b/apps/liblas-config.in	Mon Jan 03 10:35:29 2011 -0800
@@ -95,7 +95,7 @@
   --defines)
-    echo
+    echo @LIBLAS_CONFIG_DEFINITIONS@
   --includes)
@@ -103,7 +103,7 @@
   --cflags)
-    echo -I${prefix}/include
+    echo @CMAKE_C_FLAGS@
   --cxxflags)
diff -r 20328697f704 -r 5fae42ddbc14 include/liblas/detail/reader/zipreader.hpp
--- a/include/liblas/detail/reader/zipreader.hpp	Thu Dec 30 15:25:24 2010 -0600
+++ b/include/liblas/detail/reader/zipreader.hpp	Mon Jan 03 10:35:29 2011 -0800
@@ -46,7 +46,6 @@
 #include <liblas/detail/fwd.hpp>
 #include <liblas/detail/reader/header.hpp>
-#include <liblas/liblas.hpp>
 // boost
 #include <boost/cstdint.hpp>
 // std
@@ -59,6 +58,7 @@
 namespace liblas { namespace detail {
+class ZipPoint;
 typedef boost::shared_ptr< reader::Header > HeaderReaderPtr;
 class ZipReaderImpl : public ReaderI
@@ -101,15 +101,10 @@
     std::vector<liblas::TransformPtr> m_transforms;
 private:
-    void ConstructItems();
     void ReadIdiom();
     LASunzipper* m_unzipper;
-    unsigned int m_num_items;
-    LASitem* m_items;
-    unsigned char** m_lz_point;
-    unsigned char* m_lz_point_data;
-    unsigned int m_lz_point_size;
+    ZipPoint* m_zipPoint;
     // Blocked copying operations, declared but not defined.
     ZipReaderImpl(ZipReaderImpl const& other);
diff -r 20328697f704 -r 5fae42ddbc14 include/liblas/detail/writer/zipwriter.hpp
--- a/include/liblas/detail/writer/zipwriter.hpp	Thu Dec 30 15:25:24 2010 -0600
+++ b/include/liblas/detail/writer/zipwriter.hpp	Mon Jan 03 10:35:29 2011 -0800
@@ -58,6 +58,7 @@
+class ZipPoint;
 typedef boost::shared_ptr< writer::Point > PointWriterPtr;
 typedef boost::shared_ptr< writer::Header > HeaderWriterPtr;
@@ -94,14 +95,8 @@
 private:
     boost::uint32_t m_pointCount;
     LASzipper* m_zipper;
-    LASitem* m_items;
     // block copying operations
     ZipWriterImpl(ZipWriterImpl const& other);
diff -r 20328697f704 -r 5fae42ddbc14 include/liblas/detail/zippoint.hpp
--- /dev/null	Thu Jan 01 00:00:00 1970 +0000
+++ b/include/liblas/detail/zippoint.hpp	Mon Jan 03 10:35:29 2011 -0800
@@ -0,0 +1,90 @@
+ * $Id$
+ * Project:  libLAS - http://liblas.org - A BSD library for LAS format data.
+ * Purpose:  laszip helper functions for C++ libLAS
+ * Author:   Michael P. Gerlek (mpg at flaxen.com)
+ * Copyright (c) 2010, Michael P. Gerlek
+ * All rights reserved.
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following
+ * conditions are met:
+ *     * Redistributions of source code must retain the above copyright
+ *       notice, this list of conditions and the following disclaimer.
+ *     * Redistributions in binary form must reproduce the above copyright
+ *       notice, this list of conditions and the following disclaimer in
+ *       the documentation and/or other materials provided
+ *       with the distribution.
+ *     * Neither the name of the Martin Isenburg or Iowa Department
+ *       of Natural Resources nor the names of its contributors may be
+ *       used to endorse or promote products derived from this software
+ *       without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+ * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+ * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
+ * FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
+ * COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
+ * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
+ * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
+ * OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
+ * AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+ * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+ * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
+ * OF SUCH DAMAGE.
+#ifndef LIBLAS_DETAIL_ZIPPOINT_HPP_INCLUDED
+#define LIBLAS_DETAIL_ZIPPOINT_HPP_INCLUDED
+#ifdef HAVE_LASZIP
+#include <liblas/detail/fwd.hpp>
+#include <liblas/liblas.hpp>
+// boost
+#include <boost/cstdint.hpp>
+#include <boost/shared_ptr.hpp>
+// liblaszip
+class LASzipper;
+class LASitem;
+namespace liblas { namespace detail {
+class ZipPoint
+public:
+    ZipPoint(PointFormatName);
+    ~ZipPoint();
+    void ConstructVLR(VariableRecord&) const;
+    // these will return false iff we find a laszip VLR and it doesn't match
+    // the point format this object wasd constructed with
+    bool ValidateVLR(std::vector<VariableRecord> const& vlrs) const;
+    bool ValidateVLR(const VariableRecord& vlr) const;
+    bool IsZipVLR(const VariableRecord& vlr) const;
+private:
+    void ConstructItems(PointFormatName);
+public: // for now
+    unsigned int m_num_items;
+    LASitem* m_items;
+    unsigned char** m_lz_point;
+    unsigned char* m_lz_point_data;
+    unsigned int m_lz_point_size;
+}} // namespace liblas::detail
+#endif // HAVE_LASZIP
+#endif // LIBLAS_DETAIL_ZIPPOINT_HPP_INCLUDED
diff -r 20328697f704 -r 5fae42ddbc14 include/liblas/spatialreference.hpp
--- a/include/liblas/spatialreference.hpp	Thu Dec 30 15:25:24 2010 -0600
+++ b/include/liblas/spatialreference.hpp	Mon Jan 03 10:35:29 2011 -0800
@@ -101,7 +101,7 @@
     /// you have libgeotiff linked in.
     const GTIF* GetGTIF();
-    void SetGTIF(const GTIF* pgtiff, const ST_TIFF* ptiff);
+    void SetGTIF(GTIF* pgtiff, ST_TIFF* ptiff);
     /// Returns the OGC WKT describing Spatial Reference System.
     /// If GDAL is linked, it uses GDAL's operations and methods to determine
diff -r 20328697f704 -r 5fae42ddbc14 src/CMakeLists.txt
--- a/src/CMakeLists.txt	Thu Dec 30 15:25:24 2010 -0600
+++ b/src/CMakeLists.txt	Mon Jan 03 10:35:29 2011 -0800
@@ -88,7 +88,8 @@
   ${LIBLAS_HEADERS_DIR}/detail/pointrecord.hpp
   ${LIBLAS_HEADERS_DIR}/detail/sha1.hpp
   ${LIBLAS_HEADERS_DIR}/detail/timer.hpp
-  ${LIBLAS_HEADERS_DIR}/detail/private_utility.hpp)
+  ${LIBLAS_HEADERS_DIR}/detail/private_utility.hpp
+  ${LIBLAS_HEADERS_DIR}/detail/zippoint.hpp)
 set(LIBLAS_DETAIL_INDEX_HPP
   ${LIBLAS_HEADERS_DIR}/detail/index/indexoutput.hpp
@@ -129,7 +130,8 @@
   version.cpp)
 set(LIBLAS_DETAIL_CPP
-  detail/utility.cpp)
+  detail/utility.cpp
+  detail/zippoint.cpp)
 set(LIBLAS_DETAIL_INDEX_CPP
   detail/index/indexcell.cpp
diff -r 20328697f704 -r 5fae42ddbc14 src/c_api.cpp
--- a/src/c_api.cpp	Thu Dec 30 15:25:24 2010 -0600
+++ b/src/c_api.cpp	Mon Jan 03 10:35:29 2011 -0800
@@ -136,6 +136,7 @@
 #ifdef _MSC_VER
 # pragma warning(disable: 4127) // warning C4127: conditional expression is constant
+# pragma warning(disable: 4702)  // unreachable code
 #endif
 #define VALIDATE_LAS_POINTER0(ptr, func) \
@@ -1900,7 +1901,12 @@
     VALIDATE_LAS_POINTER1(pgtiff, "LASSRS_SetGTIF", LE_Failure);
     VALIDATE_LAS_POINTER1(ptiff, "LASSRS_SetGTIF", LE_Failure);
     try {
-        ((liblas::SpatialReference*) hSRS)->SetGTIF((const GTIF*)pgtiff, (const ST_TIFF*) ptiff);
+        const GTIF* cgtiff = static_cast<const GTIF*>(pgtiff);
+        const ST_TIFF* ctiff = static_cast<const ST_TIFF*>(ptiff);
+        GTIF* gtiff = const_cast<GTIF*>(cgtiff);
+        ST_TIFF* tiff = const_cast<ST_TIFF*>(ctiff);
+        ((liblas::SpatialReference*) hSRS)->SetGTIF(gtiff, tiff);
     catch (std::exception const& e) {
         LASError_PushError(LE_Failure, e.what(), "LASSRS_SetGTIF");
@@ -2126,4 +2132,5 @@
 #ifdef _MSC_VER
 # pragma warning(default: 4127) // enable warning C4127: conditional expression is constant
+# pragma warning(default: 4702)  // unreachable code
 #endif
diff -r 20328697f704 -r 5fae42ddbc14 src/detail/reader/header.cpp
--- a/src/detail/reader/header.cpp	Thu Dec 30 15:25:24 2010 -0600
+++ b/src/detail/reader/header.cpp	Mon Jan 03 10:35:29 2011 -0800
@@ -43,6 +43,7 @@
More information about the Liblas-commits mailing list
