[Liblas-commits] hg: add operator== for liblas::SpatialReference #227
liblas-commits at liblas.org liblas-commits at liblas.org
Tue Jun 21 10:49:44 EDT 2011
details:   http://hg.liblas.orghg/rev/0fa04dd9d461
changeset: 2961:0fa04dd9d461
user:      Howard Butler <hobu.inc at gmail.com>
date:      Tue Jun 21 09:49:30 2011 -0500
description:
diffstat:
 include/liblas/spatialreference.hpp |   2 ++
 src/spatialreference.cpp            |  20 ++++++++++++++++++++
 test/unit/spatialreference_test.cpp |  28 +++++++++++++++++++++++-----
 3 files changed, 45 insertions(+), 5 deletions(-)
diffs (102 lines):
diff -r 3189332cc23d -r 0fa04dd9d461 include/liblas/spatialreference.hpp
--- a/include/liblas/spatialreference.hpp	Mon Jun 20 10:27:46 2011 -0500
+++ b/include/liblas/spatialreference.hpp	Tue Jun 21 09:49:30 2011 -0500
@@ -96,6 +96,8 @@
     /// Assignment operator.
     SpatialReference& operator=(SpatialReference const& rhs);
+    bool operator==(const SpatialReference& other) const;
     /// Returns a pointer to the internal GTIF*.  Only available if
     /// you have libgeotiff linked in.
diff -r 3189332cc23d -r 0fa04dd9d461 src/spatialreference.cpp
--- a/src/spatialreference.cpp	Mon Jun 20 10:27:46 2011 -0500
+++ b/src/spatialreference.cpp	Tue Jun 21 09:49:30 2011 -0500
@@ -121,6 +121,26 @@
     return *this;
+bool SpatialReference::operator==(const SpatialReference& input) const
+#ifdef HAVE_GDAL
+    OGRSpatialReferenceH current = OSRNewSpatialReference(getWKT(eCompoundOK, false).c_str());
+    OGRSpatialReferenceH other = OSRNewSpatialReference(input.getWKT(eCompoundOK, false).c_str());
+    int output = OSRIsSame(current, other);
+    OSRDestroySpatialReference( current );
+    OSRDestroySpatialReference( other );
+    return bool(output);
+#else
+    throw std::runtime_error ("SpatialReference equality testing not available without GDAL+libgeotiff support");
+#endif
 SpatialReference::~SpatialReference()
 #ifdef HAVE_LIBGEOTIFF
diff -r 3189332cc23d -r 0fa04dd9d461 test/unit/spatialreference_test.cpp
--- a/test/unit/spatialreference_test.cpp	Mon Jun 20 10:27:46 2011 -0500
+++ b/test/unit/spatialreference_test.cpp	Tue Jun 21 09:49:30 2011 -0500
@@ -72,8 +72,13 @@
         liblas::SpatialReference ref;
         const char* proj4_c = "+proj=utm +zone=15 +datum=WGS84 +units=m +no_defs ";
         ref.SetProj4(proj4_c);
+        liblas::SpatialReference ref2;
+        ref2.SetProj4(ref.GetProj4());
-        ensure_equals("Proj.4 comparison", ref.GetProj4(), proj4_c);
+        ensure_equals("Proj.4 i/o", ref, ref2);
+        // ensure_equals("Proj.4 comparison", ref.GetProj4(), proj4_c);
@@ -112,7 +117,10 @@
         liblas::SpatialReference out_ref;
         out_ref.SetWKT(epsg4326_wkt);
-        ensure_equals("Output WKT comparison", out_ref.GetWKT(), epsg4326_wkt);
+        liblas::SpatialReference test_ref;
+        test_ref.SetWKT(out_ref.GetWKT());
+        ensure_equals("Output WKT comparison", out_ref, test_ref);
         liblas::Header out_hdr(header);
         out_hdr.SetScale(0.00000001, 0.00000001, 0.01);
@@ -205,8 +213,10 @@
         const char* exp_gtiff = "Geotiff_Information:\n   Version: 1\n   Key_Revision: 1.0\n   Tagged_Information:\n      End_Of_Tags.\n   Keyed_Information:\n      GTRasterTypeGeoKey (Short,1): RasterPixelIsArea\n      GTModelTypeGeoKey (Short,1): ModelTypeGeographic\n      GeogAngularUnitsGeoKey (Short,1): Angular_Degree\n      GeogCitationGeoKey (Ascii,7): \"WGS 84\"\n      GeographicTypeGeoKey (Short,1): GCS_WGS_84\n      GeogInvFlatteningGeoKey (Double,1): 298.257223563    \n      GeogSemiMajorAxisGeoKey (Double,1): 6378137          \n      VerticalCitationGeoKey (Ascii,14): \"NAVD88 height\"\n      VerticalCSTypeGeoKey (Short,1): Unknown-5703\n      VerticalDatumGeoKey (Short,1): Unknown-5103\n      VerticalUnitsGeoKey (Short,1): Linear_Meter\n      End_Of_Keys.\n   End_Of_Geotiff.\n";
         ref.SetFromUserInput(wkt_c);
-        ensure_equals("WKT comparison", ref.GetWKT(liblas::SpatialReference::eCompoundOK), wkt_c );
+        test_ref.SetWKT(ref.GetWKT());
+        ensure_equals("WKT comparison", ref, test_ref );
         std::vector<liblas::VariableRecord> const& vlrs = ref.GetVLRs();
         ensure_equals("VLR count", vlrs.size(), boost::uint32_t(4));
@@ -222,7 +232,15 @@
         ref.ClearVLRs( liblas::SpatialReference::eOGRWKT );
         wkt_c = "COMPD_CS[\"unknown\",GEOGCS[\"WGS 84\",DATUM[\"WGS_1984\",SPHEROID[\"WGS 84\",6378137,298.257223563,AUTHORITY[\"EPSG\",\"7030\"]],AUTHORITY[\"EPSG\",\"6326\"]],PRIMEM[\"Greenwich\",0],UNIT[\"degree\",0.0174532925199433],AUTHORITY[\"EPSG\",\"4326\"]],VERT_CS[\"NAVD88 height\",VERT_DATUM[\"North American Vertical Datum 1988\",2005,AUTHORITY[\"EPSG\",\"5103\"],EXTENSION[\"PROJ4_GRIDS\",\"g2003conus.gtx,g2003alaska.gtx,g2003h01.gtx,g2003p01.gtx\"]],UNIT[\"metre\",1,AUTHORITY[\"EPSG\",\"9001\"]],AXIS[\"Up\",UP],AUTHORITY[\"EPSG\",\"5703\"]]]";
-        ensure_equals("non OGR WKT comparison", ref.GetWKT(liblas::SpatialReference::eCompoundOK), wkt_c );
+        // ensure_equals("non OGR WKT comparison", ref.GetWKT(liblas::SpatialReference::eCompoundOK), wkt_c );
+        ref2.SetWKT(wkt_c);
+        test_ref.SetWKT(ref2.GetWKT());
+        ensure_equals("WKT comparison from geotiff", ref2, test_ref2 );
     // Try writing a compound coordinate system to file and ensure we get back
More information about the Liblas-commits mailing list
